997 : 2004- 67
996 : 1997-2005 34
Boxster : 1997- 21
Cayenne : 2003- 3
ok51mon
PostPosted: Mon Feb 25, 2019 5:43 pm    Post subject: Turbo Tiptronic Gearbox Info- 722.653- 590ft/lbs-800nm Reply with quote
The Porsche Turbo (996) Tiptronic box is actually a Mercedes 722.653 box (590 ft/lbs 800 nm holding capacity).
In fact I'm pretty sure all the Tip boxes are actually Merc 722 box variations.
It's also the same box used in the McLaren SLR only with different clutch packs . All of which a retrofittable to our Tiptronics if you want to run big power.
I decided on a Holibox for mine for competition but during my research travels I had a look into the capabilities of the 722.
You can do loads with the 722 and the Mercedes forums are leaps and bounds ahead with this box compared to the Porsche enthusiasts;
Add another clutch pack in between gear 3-4, rebuild with uprated clutch packs , Rev match on downshift, Shift much faster. There is DIY's for all of these if you can find them.
Here let me throw you some bones.
https://docs.google.com/document/d/1_WiBay-rg3oWv8VhuVyUuVJ-f22PwEzD5N_LuAQHUNI/edit
https://www.benzworld.org/forums/w210-e-class/1463460-mercedes-benz-722-6-transmission-faq.html
http://www.superturbodiesel.com/std/forumdisplay.php?fid=9&page=10
https://www.benzworld.org/forums/w210-e-class/1574684-advice-722-6-trans-removed-diy.html
https://www.atsg.us/atsg/mercedes-722-6-nag-1.html
https://www.atsg.us/atsg/mercedes-722-6-dvd-video-companion-manual.html
https://yourcovers.com/transpan_11117.php
Update ; NAG1 , W5A850 are all the same box
722.6 Manual: http://www.w124performance.com/docs/mb/transmission/722.6/trans_722.6_ATSG_2004.pdf
4.1L Incoming
ok51mon
PostPosted: Mon Feb 25, 2019 7:13 pm    Post subject: Reply with quote
This was initially just a response to a post in a separate thread guys so S ,P and G aren't exactly my finest.
Happy to re-write this if the Admin feels the forum would benefit from this post.
Any questions fire away!
4.1L Incoming
PostPosted: Mon Feb 25, 2019 7:29 pm    Post subject: Reply with quote
I was a little confused by this thread but i assume its part of some other thread and is now seperate ?
original thread if so please .. id like to have a read .
All i can add ..
The Turbo was released in the second half of 2000 but as such it is a 2001 model .. so technically the first Turbo is a 2001 .
They had the Merc box as standard , the ZF was used in other models up until 2002 when they switched to the Merc boxes .
Back in the late 1990,s and Porsche were almost bankrupt .. they couldn,t afford to design their own boxes .
The Merc box is fine for the Turbo and a limited increase in power .. if you start pushing the limits though then modification is required ..
Clutch packs and i think brake bands , not sure as its not my area im afraid but it is logicall ..
You upgrade the clutch on a manual .. well a Tip is not really any different in a sense .
i would also agree its probably an over looked item when increaseing BHP on the engines so a thread on it is well worth it Thumb
PostPosted: Mon Feb 25, 2019 11:47 pm    Post subject: Reply with quote
It was split out from another thread because it wasn't at all relevant to the original topic or anything that had been discussed within it.
Original thread => http://911uk.com/viewtopic.php?t=78825&start=20&postdays=0&postorder=asc&highlight=
911tom
Watkins Glen
PostPosted: Tue Feb 26, 2019 8:48 am    Post subject: Reply with quote
Excellent research Si! All very informative. Thank you for sharing thumbsup
2011 Cayenne
718 Cayman GTS
ok51mon
PostPosted: Tue Feb 26, 2019 11:58 am    Post subject: Reply with quote
Explanation Of Clutch Slip
A quick touch on people with clutches slipping as some of you have messaged me on this.
I’ll try and give an explanation of what is happening.
The Engine needs to get the power it creates to the driving wheels of your car so it needs to make literally, a hand shake deal.
We will call (1)The Engine Barbara and (2) The Driving Wheels Geoffrey for the purpose of this explanation.
When Barbara and Geoff make their deal they exclusively shake hands in the Gearbox.
However, if for example Barbara is making too much power (above 590ft/lbs) she cannot shake hands with Geoffrey for very long before their hands slip out of the hand shake.
If any of their hands slip, both of their hands will become permanently blistered meaning that the next time they shake hand they aren’t able to apply as much force as last time as a result of the pain and/ or damage.
This is what is happening when your gearbox is slipping. Its also will get more frequent once it has slipped the first time.
So What Is Some Of The Solutions?
(1)
Geoff and Barbara drastically increase their hand shake pressure (Essentially they squeeze their hands together more tightly.)
-This is known as increasing the Valve Body Pressure . This can be done electronically via a standalone such as the one above or Physically through means of porting which is much more invasive.
(2)
Geoff and Barbara wear special sticky gloves to prevent slippage
-This is known as fitting aftermarket clutches for increased grip.
Best
S
4.1L Incoming
PostPosted: Tue Feb 26, 2019 8:14 pm    Post subject: Reply with quote
logical and a clever analogy .
Dammit
Watkins Glen
PostPosted: Wed Feb 27, 2019 6:03 pm    Post subject: Reply with quote
I believe my 2007 C55 AMG has this gearbox, I’d love it if it rev-matched on the downshift.
Halcyon
PostPosted: Wed Feb 27, 2019 6:58 pm    Post subject: Reply with quote
I may be wrong, but I believe yours would have the 722.9 "7G Tronic" - that's what was in my 05 CLK AMG at least...
#randombitofinfo
Dammit
Watkins Glen
PostPosted: Sun Mar 03, 2019 8:56 am    Post subject: Reply with quote
Contemporary C classes had the 7G-tronic but IIRC the C55 had the older unit as it was thought to be too near the torque limit of the 7.
ok51mon
PostPosted: Wed Mar 06, 2019 1:58 pm    Post subject: Reply with quote
Rev Matching On The Downshift- 722.9
https://www.youtube.com/watch?v=mIIvEnR3KUA
4.1L Incoming
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Mar 06, 2019 2:04 pm    Post subject: Reply with quote
That was certainly the case on the R230 SL55. It runs a 5 speed auto whereas others run 7 speed.
ok51mon
PostPosted: Wed Mar 06, 2019 2:14 pm    Post subject: Reply with quote
Martin does your SL63 run the same or similiar 722 gearbox?
4.1L Incoming
MisterCorn
PostPosted: Wed Mar 06, 2019 3:03 pm    Post subject: Reply with quote
ok51mon wrote:
Mine is an SL55 with the F1 pack, hence it looks like an SL65 from the front. I am not sure which model of gearbox it is, but it is definitely a 5 speed with comfort and sports setting, starts off in second gear on comfort mode and has flappy paddles. It is ponderously slow and suits the nature of the supercharged V8 with massive torque.
ragpicker
Reims
PostPosted: Wed Mar 06, 2019 4:07 pm    Post subject: Reply with quote
MC's will be the 722.6 in his SL which is the same as the one in the 996/7 turbos.
This is different to the 722.9 which has 7 speed and can have the blip shift mod done. The 722.9 is the more modern variant.
