964 : 1989-1993 5
Boxster : 1997- 18
Cayman : 2005- 12
Cayenne : 2003- 3
Macan : 2014- 1
C4-STORM
2004 Porsche 996 Carrera 4S
PostPosted: Sun Mar 03, 2019 12:16 am    Post subject: Header tank breather valve problems replacing Reply with quote
Evening all.
I need help with removing and replacing header tank breather valve please!!
Bolts are showing signs of minor surface rust but upon removal the bolt heads are literally falling off..
Can’t drill them out as they are housed in plastic.
Please don’t tell me I will need to drain the coolant, drop the engine and remove the header tank 😩
I am at the point where I can leave it alone but I am not happy knowing these bolts are all rusted away (and there’s only 4 left holding it on)...
Any other ideas guys??
2004 C4S Coupe 3.6 Tiptronic S ~ Basalt Black ~ Black Crested Sports Seats ~ Alcantara ~ S/R Delete ~ WEVO Engine Mounts ~ K&N Induction Filter ~ DesignTek Sports Exhausts ~ Quad Tips ~ RUF Hubcentrics ~ RUF Sports Springs ~ Paddle Shift Steering Upgrade ~ Rear Wiper Delete ~ Smoked Rear Indicators ~ Smoked 3rd Brake Light ~ Silver Dash Bar Hack™
 Filesize:  713.05 KB
 Viewed:  504 Time(s)
Mac996t
2004 Porsche 996 Turbo
PostPosted: Sun Mar 03, 2019 1:09 pm    Post subject: Reply with quote
Erm, that look like a right pain. It’s a bit hard to tell from the pic but if the bolts have snapped just below the heads there may be enough left sticking out once the black valve body is removed to get some grips on them. Trouble is you are committed once you do!
Ps what was your reason for removing them, it doesn’t look like the valve was leaking?
alex yates
PostPosted: Sun Mar 03, 2019 1:15 pm    Post subject: Reply with quote
Easy to remove. Can buy a decent used header tank for £75 or new for around £100. Personally I can't see rusty bolts seized in plastic and seizing. Most likely they're seized in a steel insert in the plastic.
https://www.ebay.co.uk/itm/PORSCHE-911-996-EXPANSION-TANK-PORSCHE-996-CARRERA-HEADER-TANK-/292848927214
Open Youtube Page
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Mar 03, 2019 2:02 pm    Post subject: Reply with quote
As said, it would be easier to change the header tank, there is every chance you fix this one and then the tank starts to split. Change the tank and eliminate any future issues.
C4-STORM
PostPosted: Sun Mar 03, 2019 7:06 pm    Post subject: Reply with quote
Thanks guys.
That video makes it look fairly straightforward..
The annoying thing is I don’t have a leak. Went to remove 1 bolt as it was rusty. Should have just left alone! My bad nooo
kurlykris
PostPosted: Sun Mar 03, 2019 7:41 pm    Post subject: Reply with quote
Looking at the parts if you buy a new bleed valve, they look like self tapping screws.
I would be inclined to have a go at getting them out, but then I am an engineer Grin
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
C4-STORM
PostPosted: Sun Mar 03, 2019 9:19 pm    Post subject: Reply with quote
Hi Kris.
That’s what I would like to do and I have the valve kit/new screws which you have shown.
I started to try and drill out one of the screws threads I could access the easiest but it wasn’t working out too well tbh.
Access is so limited that the header tank needs to come out really I think.
I’ve left it all alone for now, plugged the holes with gasket sealant and cleaned it all up - just to tidy.
Nothings leaking at the moment, I’ll keep an eye on it!
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sun Mar 03, 2019 9:28 pm    Post subject: Reply with quote
If you do just change only the.part that Kris posted just cut through the left over bolt heads and scrap everything that's not supplied in the kit, you can undo the screws shafts with mole grips then.
kurlykris
PostPosted: Sun Mar 03, 2019 9:33 pm    Post subject: Reply with quote
Yeah exactly what I was thinking Chris Grin
C4-STORM
PostPosted: Sun Mar 03, 2019 10:09 pm    Post subject: Reply with quote
I’ll give it a go, it’s hard to get in there though.
Thanks for the comments chaps Thumb
alex yates
PostPosted: Sun Mar 03, 2019 10:10 pm    Post subject: Reply with quote
Snap.
