996 : 1997-2005 29
Early 911 : 1964-1977 2
Boxster : 1997- 14
Cayman : 2005- 16
Paynewright
PostPosted: Tue Feb 26, 2019 1:29 pm    Post subject: What is this clip?? Reply with quote
Found in the drivers footwell near the forward end of the outside seat runner. Just had a look around under the seat and dash but cannot find an appropriate orifice or bit of trim flapping about.
Any suggestions??
 Filesize:  1.08 MB
 Viewed:  878 Time(s)
 Filesize:  1.4 MB
 Viewed:  878 Time(s)
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue Feb 26, 2019 3:16 pm    Post subject: Reply with quote
A clue is with the direction arrow and the O. I think T is missing from the other end of the arrow and is possibly the headlight beam adjuster for travelling abroad.
It does look different to the one on my headlights so I could be totally wrong?
PostPosted: Tue Feb 26, 2019 8:00 pm    Post subject: Reply with quote
Its actually part of the fixings for the PCM .. there are 4 of them and you insert an allen key , move it by about 40 degrees and it Pushes the locking tab in so you can remove the unit .
Ive never taken much notice of them to be honest and had'ent realised there were letters on them .. my guess would be O and probably T are a German words and this is an abbreviation for them ..
Clamp , un clamp .. do up undo .. Dont know
It is also on the head light adjusters but again i dont know what the letters actually stand for .
Paynewright
PostPosted: Tue Feb 26, 2019 8:46 pm    Post subject: Reply with quote
I have an annoying rattle coming from around the PCM / passenger air bag / dash top so I guess I know where I’ll be looking first. Plan is to remove the PCM, insulate any wires and have a drive around.
Ian
PostPosted: Tue Feb 26, 2019 8:51 pm    Post subject: Reply with quote
Noise will probably be the passenger air bag .. but i cant for the life of me remember the fix .. try tightening the bolts for it first.
PCM clip missing is very unlikely to cause a noise .. just an inconvienence when removeing the pcm .
Also Ian .. but spelt Iain Smile
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Tue Feb 26, 2019 9:15 pm    Post subject: Reply with quote
Told ya
pzero
PostPosted: Tue Feb 26, 2019 10:14 pm    Post subject: Reply with quote
The letters 'O' and 'T' on the headlight adjusters stand for Origin (of home country) and Tourist.
991.1 Carrera GTS
PostPosted: Wed Feb 27, 2019 7:41 pm    Post subject: Reply with quote
@ infrasilver .. a perfectly logical conclusion and one i at first thought was correct .. but ive not seen that type of fixing in a headlight ..
I had to think a bit to figure it out .. and i never new these had letters on them .. i need stronger glasses i think .
pzero .. worship .. i have wondered this for as long as ive been working on these !
Paynewright
PostPosted: Thu Feb 28, 2019 2:11 pm    Post subject: Reply with quote
So, popped the horseshoe, air vent and whole PCM cradle.
Firstly, one of the four cradle screws was missing so found a suilable replacement.
Secondly, there was a loose plug at the back of the PCM with a wire going into the loom, however there was an identical plug in the back of the PCM with a single (prob coax) wire disappearing into the dash.
Found a second, different clip, on the inside of the lower dash under the PCM.
Any clues on loose plug & clip?
Just going on a test drive to see if the rattle gone?
 Filesize:  1.45 MB
 Viewed:  547 Time(s)
 Filesize:  1.07 MB
 Viewed:  547 Time(s)
PostPosted: Thu Feb 28, 2019 7:57 pm    Post subject: Reply with quote
The blue plug .. i think is the gps antenna .. does the nav system work ?
It is a coax lead .
You have radio antenna , gps for nav and phone .. they all look similar but different colours .. which for the life of me i cant remember .
There should be the same colour plugs on the back of the PCM ... unless someone has removed a system or replaced the PCM.
Basically what doesnt work on your car from the above list ?
The black plastic clip .. thats a securing device for that type of plug connection (the blue one )
Paynewright
PostPosted: Thu Feb 28, 2019 8:53 pm    Post subject: Reply with quote
Thats the odd thing - there is the same plug, plugged into the back of the PCM on an individual wire - I wonder if there was a problem with the GPS antenna and the replacement had its own wire.
 Filesize:  1.34 MB
 Viewed:  467 Time(s)
