997 : 2004- 76
Early 911 : 1964-1977 2
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
RUDDY
PostPosted: Tue Nov 20, 2018 2:44 pm    Post subject: Reply with quote
So the majority of the work underneath is now complete, I replaced the bolts/nuts and brackets that support the cats at the rear of the block, a bit fiddly without removing the pipes but do able. With help from my mrs working the pedal I bled the brakes, although the fluid is coming out of the calipers air free the pedal still feels awful although all the calipers do clamp firm, more work required there sometime.
Time for a break I think, will throw the cover over it until the new year, I still want to fit red seat belts and some 19” Lobsters although I think the wheel change would be better done with new lowered springs. The car is in original paint and therefore has a few minor stone chips to the front which I want to have corrected.
Obviously with all the suspension work the car now requires a full geo set up, its also booked on the ferry for Dinslaken, Cochem and Stuttgart next May.
So now to the wifes Boxster Sad
Cheers, Paul
 Filesize:  1.63 MB
 Viewed:  1840 Time(s)
jpsh120
PostPosted: Wed Nov 21, 2018 3:17 pm    Post subject: Reply with quote
RUDDY wrote:
jpsh120 wrote:
Impressive!
Excuse the daft question, but what are the dollops of colour on the spring for?
PS - Bish says hello Thumb
I would guess Bish was sitting with his feet up !
His retort.....BES?
2007 997 Carrera S - SOLD Sad
The return of Marty Wild
PostPosted: Wed Nov 21, 2018 3:43 pm    Post subject: Reply with quote
What a car, keep it coming! Thumb
Cayman S 987.1
stichill99
PostPosted: Wed Nov 21, 2018 4:53 pm    Post subject: Boxster Reply with quote
Let's just continue this thread with photo's of your wife's boxster! Thumb
RUDDY
PostPosted: Sat Jan 05, 2019 8:33 pm    Post subject: Reply with quote
So work on the Boxster never started and instead I started dismantling the house, kitchen out and a few walls and ceilings away for good measure, anyway with that now in the builders hands I've drawn up a list and ordered a few more parts for the 997.
Nothing that's screaming out to be done but better doing it as a planned job than an emergency WTF job Very Happy
So from my local main agent in Kendal I've ordered all the rear coolant pipes, hoses, clips, AOS, idler rollers, tensioner, belt, oil cooler seals (maybe get a new BEHR cooler though), I've got a low temp stat ready to fit also.
Water pump was done last year and clutch 1k miles ago.
Although I've no fear of dropping the motor myself space and health are limited so I'll entrust this job to the lads at D&G in North Shields and ask them to take plenty images, the car is being taken over in a covered trailer.
There is a very good detailing company on the same industrial estate so I may ask what they can quickly do with the engine whilst it's out changing the alloy pipes.
The car will get a full geo and brake bleed while its there.
All the best, Paul
RUDDY
PostPosted: Mon Feb 18, 2019 7:54 am    Post subject: Reply with quote
So early Fridsy morning my car was collected for a trip to DG Porsche to have the engine dropped and the rear coolant pipes/hoses replaced, as I have already said earlier while the motor is out it makes sense to change other items at the same time so AOS, low temp stat, oil cooler, engine mounts, belt and pulleys will be done.
I’ve also bought a set of -30mm Eibach coils so these are going on and the car will get a full geo before being trailered back home.
The lads have been asked to identify anything else that may need doing whilst its in.
Now, does anyone have a set of 19” Lobsters for sale, C2, 8” ET57 11”ET67 ?
Cheers, Paul
 Filesize:  253.97 KB
 Viewed:  1026 Time(s)
 Filesize:  1.77 MB
RUDDY
PostPosted: Sat Feb 23, 2019 1:56 am    Post subject: Reply with quote
Car came back from DG Porsche yesterday, all parts replaced as planned plus one further hose, the often corroded rear brake line accessible with the engine out was described as factory fresh so left well alone, couple of new handbrake springs fitted, expensive little buggers !
Eibach -30mm coils give the car a much better stance, before and after measurements show a reduction of around 34mm, I believe the C2 rides 10mm higher than an C2S so its not scraping its belly.
As the car arrived home so dod Parcel Force with a set of used lobsters, initial checks look promising so may not need a refurb, time will tell.
 Filesize:  1.87 MB
 Viewed:  874 Time(s)
 Filesize:  1.59 MB
 Viewed:  874 Time(s)
 Filesize:  1.98 MB
 Viewed:  874 Time(s)
BHZ661
PostPosted: Sat Feb 23, 2019 6:36 am    Post subject: Reply with quote
Wheels will look fantastic with dropped ride height thumbsup
Lambretta
PostPosted: Sun Mar 31, 2019 4:49 am    Post subject: Reply with quote
Just came across this post while searching for something else
Weldone you, thats some attention to detail Cool
Might catch you about oneday on a north east run out
Please be sure to post some after pics of the car on its new rims and springs, I am about to order the same springs for my C2
997 Seal Grey Manual
1966 912 under resto
Goto page Previous  1, 2, 3, 4
Page 4 of 4
