964 : 1989-1993 5
Boxster : 1997- 18
Cayenne : 2003- 3
Macan : 2014- 1
rich07
PostPosted: Tue Feb 19, 2019 4:21 pm    Post subject: ride height Reply with quote
Hi guys, while I am waiting for new alternator pulley I wanted to ask a few questions re suspension. When I say suspension I mean ride height, i'm looking to lower the ride height, my 993 sits much lower at the rear is this normal? if I change just the springs can I achieve a level lower ride without adjustable suspension?
i'd post a pic but all my pics are over 2mb
thanks rich
Tobesetc
PostPosted: Tue Feb 19, 2019 4:49 pm    Post subject: Reply with quote
Others will answer with specifics but my understanding from a recent visit to the suspension deity at CG is that road use is normally level and track sometimes adds 5mm or so of rake to raise the rear (or lower the front). Not heard of rear being lower - doesn't mean it isn't valid, though.
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Endoman
PostPosted: Tue Feb 19, 2019 6:03 pm    Post subject: Reply with quote
Here are some specifics:-
If you want to reduce file size easiest way is edit with Paint, resize by reducing pixels say 750 by whatever, save as new name so you keep your original.
Mine is set at RS front and RS+5 mm rear.
i.e. 124mm front 112 mm rear, nominal, adjusted for corner weight balance by the wizards at CoG.
Usual advice is no lower than RS +10 unless you fit RS front uprights.
Ride Height by option & spring pt number Pub Rennlist.pdf
Download
 Filename:  Ride Height by option & spring pt number Pub Rennlist.pdf
 Filesize:  284.2 KB
 Downloaded:  12 Time(s)
