997 : 2004- 65
996 : 1997-2005 33
Cayman : 2005- 22
Macan : 2014- 8
BHZ661
PostPosted: Tue Feb 12, 2019 1:32 pm    Post subject: Airbag light - cup steering wheel MOT failure Reply with quote
Took the car for MOT and it failed on the airbag warning light not coming on , car is fitted with a cup steering wheel ,airbag light has been resistered out , Im told the law altered last May ,the light has to come on and then go out rather than not on at all
Seems as tho its going to be a annual thing for MOT in fitting old wheel and then swopping back , anybody else had problems
Gary
Stoo.c
PostPosted: Tue Feb 12, 2019 2:29 pm    Post subject: Reply with quote
That's true that the rules have changed although I dare say many testers will let it through still.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Feb 12, 2019 2:33 pm    Post subject: Reply with quote
If the resistor has been fitted and the bulb is working then the light should come on and go off as normal. Are you sure that is why it failed? It would also fail because an airbag which was originally fitted is not present. That would make a lot more sense.
BHZ661
PostPosted: Tue Feb 12, 2019 2:40 pm    Post subject: Reply with quote
He said because of the light , and the law change , still looks like going to be annual Mot prep job
MisterCorn
PostPosted: Tue Feb 12, 2019 2:42 pm    Post subject: Reply with quote
BHZ661 wrote:
Fair enough, but if your light isn't coming on now, I don't see how swapping your steering wheel back will change that? With the resistor fitted, as far as the airbag controller is concerned your airbag is present.
BHZ661
PostPosted: Tue Feb 12, 2019 2:50 pm    Post subject: Reply with quote
[quote="MisterCorn"]
BHZ661 wrote:
I meant i will have to go back to the airbag wheel and connect all wiring back up, get it tested and then swop back over with cup wheel and resster
MisterCorn
PostPosted: Tue Feb 12, 2019 2:59 pm    Post subject: Reply with quote
But if your light is not coming on now, what will make it come on when you swap the wheel and the wiring? The point of the resistor is to mimic the airbag. I.E. the light comes on and goes off as normal with the resistor fitted. If this isn't happening now I don't see how swapping your wheel will help?
BHZ661
PostPosted: Tue Feb 12, 2019 3:15 pm    Post subject: Reply with quote
Everything was ok before swop , unless ive put the resister in the wrong place if thats possible even , or there is another way to do it different to what ive done to minic light on and then off
Jay.
PostPosted: Tue Feb 12, 2019 4:04 pm    Post subject: Reply with quote
BHZ661 wrote:
Have you put the old wheel back on, and did that solve the problem?
The resistor can only really go in one place, so I'd be amazed to see if you had got it wrong.
As others have said, the light should still come on even with the resistor in place
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
BHZ661
PostPosted: Tue Feb 12, 2019 4:10 pm    Post subject: Reply with quote
I havent refitted yet Jay that will be a weekend job , there must be another problem some where then it appears Confused
NedHan79
PostPosted: Tue Feb 12, 2019 7:16 pm    Post subject: Reply with quote
I have just checked my car and my light dosnt come on either. It’ll be interesting to see how you get on with the original wheel back on
MisterCorn
PostPosted: Tue Feb 12, 2019 7:26 pm    Post subject: Reply with quote
I think it should be on for a few seconds on ignition position 1 then go off.
If it isn't doing that I would plug it in to diagnostics and read the codes. If you are near M1 J26 I'm happy to check for codes.
Marky911
PostPosted: Tue Feb 12, 2019 7:28 pm    Post subject: Reply with quote
Well I never. Mine doesn’t light up either.
Scrub that, it does.
It’s along at the right hand end of the row.
IanG1
PostPosted: Tue Feb 12, 2019 7:52 pm    Post subject: Reply with quote
Mine comes on and goes off just like it did before the bag was removed. If your doesnt come on at all my guess would be the bulb rather than anything you have done. If you got the resistor bit wrong more likely the light would stay on rather than off
1998 996.1 C2 manual/LSD with aero and a big smile
NedHan79
PostPosted: Tue Feb 12, 2019 8:19 pm    Post subject: Reply with quote
Got that mark. I flicked the key on and off a few times. It only seems to come on the first time you turn after putting the key in
Marky911
PostPosted: Tue Feb 12, 2019 9:07 pm    Post subject: Reply with quote
Yeah Ned, Mine must have lit up and gone out by the time I spotted where it was on the dash. Then subsequent cycles didn’t light it up, hence my first post.
I googled where the light should be, went back out and it came on and went off as it’s meant to.
BHZ661
PostPosted: Wed Feb 13, 2019 6:14 am    Post subject: Reply with quote
After searching Google and Porsche workshop manual , as has been said only works when key inserted in ingition comes on for a few seconds an then goes out , so it appears i dont have a problem just not been checked properly MOT time, annoying and frustrating Smile
Thank you everybody for imput thumbsup
MisterCorn
PostPosted: Wed Feb 13, 2019 6:48 am    Post subject: Reply with quote
At least there is no fault. If he is doing his job properly he will fail it for not having the airbag in place, so you aren't out of the woods yet. Given that it takes 10 minutes to swap it over, I would change it for the MOT anyway just to make sure.
