Author |
Message |
rich07 Newbie
Posted: Sun Feb 10, 2019 11:23 am Post subject: ordering replacement fan bearing, size?
Hi guys, just in the middle of alternator fan and shroud refurbishment, rather than pay a rediculous amount of money for the bearing and hub from porsche or aftermarket suppliers has anyone measured and ordered the bearing from a supplier? I don't trust my measuring skills.
Thanks rich
Zingari Donnington
Posted: Sun Feb 10, 2019 11:54 am Post subject:
I think Ninemeister carry them in stock. I found that out after mine was ordered from OPC and had to be couriered from Germany
Here is the one you want:
http://wmtbearings.co.uk/porsche-pulley-bearing-ld17-32-2rsr-an04/
Or £15 off eBay I think? That said they should be under £20
 _________________ Alfa Romeo’s 4C is everything a Italian sports-car should be: it’s gorgeous to the point of pornography, distinctive enough that nobody will ever mistake it for a Porsche, handles like it’s on rails and steers like a kart.
decgraham Barcelona
Posted: Sun Feb 10, 2019 2:40 pm Post subject:
Hi rich07,
We did a group buy back in June last year and as Zingari says WMTBearings is the company to go to.
Here's the link for your info.
http://911uk.com/viewtopic.php?t=128412&highlight=bearing
ATB  _________________ 1995 993 C2 Cab TipS in Guards Red
rich07 Newbie
Posted: Sun Feb 10, 2019 5:18 pm Post subject:
Thanks guys, great info, will get that ordered asap, especially as the start of warmer weather is on its way, brighter evenings etc.
rich07 Newbie
Posted: Mon Feb 18, 2019 10:40 pm Post subject: v belts
Hi guys, alternator all back together, new voltage regulator and fan bearing installed. I am having trouble with the belts, porsche have supplied two both the same, alternator and fan, the alternator belt is to slack even with all the shims removed?
Description: |
Filesize: |
1.95 MB |
Viewed: |
372 Time(s) |
Diddi Newbie
Posted: Mon Feb 18, 2019 11:50 pm Post subject:
Hi, which engine number is installed M64.?? there are different "Schmalkeilriemen" of the length for that. _________________ Grüsse, Diddi
Diddi Newbie
rich07 Newbie
Posted: Tue Feb 19, 2019 12:08 am Post subject:
Yes I think so, service book it says
M6405-63R G5021-10
Diddi Newbie
Posted: Tue Feb 19, 2019 12:39 am Post subject:
.......for M64.05 is 9.5 x 776 (999 192 338 50)
the next is 9.5 x 760 (999 192 343 50) and then 9.5 x 753 (999 192 373 50)
the order numbers for the belts in brackets _________________ Grüsse, Diddi
decgraham Barcelona
rich07 Newbie
Posted: Tue Feb 19, 2019 8:38 am Post subject:
Hi, it's a manual.....
so it looks like I have the right belt?
I emailed the parts guy at porsche, he says it may be to do with a tech update that mean the pully halves also need to be replaced. He's going look into it and let me know.
decgraham Barcelona
Posted: Tue Feb 19, 2019 8:46 am Post subject:
Hi Rich,
OK that sounds right to me. I'm attaching the "Pulley Update" from Porsche for your info.
Description: |
 Download |
Filename: |
Pulley_update.pdf |
Filesize: |
32.35 KB |
Downloaded: |
10 Time(s) |
rich07 Newbie
Posted: Tue Feb 19, 2019 4:06 pm Post subject:
Hi thanks for that, it's a shame porsche didn't realise that the pully needed to be changed when they gave me the new belt, pulley arrives on Thursday, so fingers crossed for a drive at the weekend.
decgraham Barcelona
Posted: Tue Feb 19, 2019 4:08 pm Post subject:
