Boxster : 1997- 18
Cayman : 2005- 20
Milo72
PostPosted: Fri Feb 01, 2019 7:53 pm    Post subject: Ooohhh Techart Springs arriving tomorrow... Reply with quote
Garage Heater set to come on early... tools all sorted.... pint of milk, coffee and a kettle.... and a packet of biscuits.
Perfect Saturday sorted..
997.1 C2S Cab Tip.
PostPosted: Fri Feb 01, 2019 7:54 pm    Post subject: Reply with quote
thumbsup
Don't forget the beers chilling in the fridge for later!
Milo72
PostPosted: Fri Feb 01, 2019 7:59 pm    Post subject: Reply with quote
alex yates wrote:
thumbsup
thumbsup
997.1 C2S Cab Tip.
PostPosted: Fri Feb 01, 2019 8:35 pm    Post subject: Reply with quote
Pics before and after mate Thumb Thumb Thumb
bricheun
PostPosted: Sat Feb 02, 2019 5:52 am    Post subject: Reply with quote
You will absolutely love them. Perfectly stanced, no droop and on the spot comfort vs sport. Height wise mine was 1 inch between fender and tyre top.
I had the H&R, and they were the worst springs you can get, they were too soft and too low. Meaning you scrape everything getting worse over time as they droop. The front rake made the car handle wierd.
Looks cool though cos it was raked and low.
One advise , there is a pasm controller available which transforms the pasm and sport springs, it is the best money I spent and solved my handling issues. You can Google that... Old
JonS
PostPosted: Sat Feb 02, 2019 8:23 pm    Post subject: Reply with quote
Great choice on the Tech art springs, I have them on my Gen2 C2S about 15mm lower, the ride still very good whilst not so stiff that the dampers are overwelmed even on the standard setting.
PostPosted: Sat Feb 02, 2019 8:59 pm    Post subject: Reply with quote
Do you mean the DSC module for upgrading PASM Thumb yes great bit of kit , but for the gen1 you also need the accelerometer so it ends up being about £1200
Thefinn
PostPosted: Sat Feb 02, 2019 9:01 pm    Post subject: Reply with quote
Worth it though as it transformed the car
997.1 C4S CAB
bricheun
PostPosted: Sun Feb 03, 2019 1:35 am    Post subject: Reply with quote
exactly, ✌
Alsov try the slightly firmer setting for the techart springs.
I found it less floaty and comfortable.
bricheun
Do you mean the DSC module for upgrading PASM Thumb yes great bit of kit , but for the gen1 you also need the accelerometer so it ends up being about £1200[/quote]
1200 quid is worth it considering a decent suspension system with adaptive damping with fitting and setting will.cost a lot more.
