Boxster : 1997- 18
Cayman : 2005- 20
wildej
PostPosted: Wed Feb 07, 2018 9:06 am    Post subject: Reply with quote
Nik wrote:
Before I put an ad in the classifieds, anyone interested in a wicked coatings carbon-coated centre console. As new, as it was only installed a few months back.
Sent you a PM Nik.
991.1 C4S, PDK, Carrara White
Previous
997.1 Turbo Tip, GT Silver
997.2 C4S, PDK, Carrara White
997.2 Carrera, PDK, Meteor Grey
Bund
PostPosted: Fri Feb 01, 2019 12:21 pm    Post subject: Reply with quote
I read there is a good thread on how to remove these on 911uk but I haven’t found it from searching. I haven’t gone through all 32 pages on this yet but if someone could point me to it I’d appreciate it.
I’ve found one on rennlist but I was hoping it could be done with less faff.
Or any good ones going for sale(oem or leather😉)?
Audi B7 RS4 avant, Mercedes W124 E320 Sportline cabriolet, Mercedes 560 SEC, Toyota LJ70 Land Cruiser
PostPosted: Fri Feb 01, 2019 12:42 pm    Post subject: Reply with quote
Does this one help?
http://www.macarbon.com/install_guides/Porsche/997/997%20CF%20Center%20Console%20Install%20Instructions.pdf
Bund
PostPosted: Fri Feb 01, 2019 1:26 pm    Post subject: Reply with quote
T8 wrote:
Does this one help?
Cheers T8!!👍🏼😆 that helps to confirm my fears that I do have to remove a fair few bits as that’d the one I’d found. Lol
I was hoping it could be done without removing Bose bits and whatnot.
PostPosted: Fri Feb 01, 2019 1:49 pm    Post subject: Reply with quote
Bund do you have a cab, is that why there are Bose bits to remove as I know the amp is in the pax footwell on a cab. Question
Bund
PostPosted: Fri Feb 01, 2019 2:54 pm    Post subject: Reply with quote
Hey Phil, it’s a coupe but the link i found last night and t8 kindly put forward the guy is explaining you disconnect the battery and Bose amp, this tutorial is for a gen 1 though. I’d read in one the 911uk posts there was a good write up on how to remove the rear centre console but I hoped it wasn’t the one we’re talking about and a bit simpler(sure it’s not difficult if you’re handy with a bit of trim).
G2
PostPosted: Fri Feb 01, 2019 7:52 pm    Post subject: Reply with quote
The MA carbon instructions (and YouTube vids) are easy to follow along as you do it. Does not take too long and never needs a lot of force so unlikely to break owt. The cubby tray is the only awkward bit as it has a tab on the top, but gentle pressure releases it.
Happy to talk it through at the fairmile meet, but I’m guessing you want it before april Question
997 Gen2 Turbo S - Speed.
991 C4S - Riviera.
PostPosted: Fri Feb 01, 2019 8:17 pm    Post subject: Reply with quote
Ah its a coupe , in that case theres nothing Bose connected that needs disconnecting we did mine on my drive in about 30mins sent it off to be painted and then refitted it in about 45 mins taking care not to damage the new paint , on the cab the Bose amp is fitted to the side of the centre console in the pax footwell , but in the coupe its on the rear parcel shelf. the only thing thats a bit time consuming is removing the gear knob as they can be stiff. the car is actually drivable with the centre console removed. heres a couple of pics of mine in bits after painting sorry they are not great pics.
 Filesize:  81.72 KB
 Viewed:  1156 Time(s)
 Filesize:  77.79 KB
Bund
PostPosted: Fri Feb 01, 2019 9:03 pm    Post subject: Reply with quote
Thanks G2 & Phil, the fairmile meet may work well for a talk through if I’m struggling as wont collect car till early March and I’d like to source and swap in the paddle shift first. 👍🏼
Were the types of plastic tools in the carbon tutorial required?
Bund
PostPosted: Fri Feb 01, 2019 9:05 pm    Post subject: Reply with quote
No need to disconnect the battery then?
G2
PostPosted: Fri Feb 01, 2019 9:38 pm    Post subject: Reply with quote
Yes. Torx for the screws of various sizes and better to use the plastic splitters when separating the gear knob surround bits. I bought a set off amazon for about £15 but was doing a few van installs etc around the same time.
I disconnected the battery with the key in position 1 for the alarm (not sure it’s 100% necessary but there are a few connectors to unplug so belt and braces and all that.
Phil might know if the battery is necessary.
Make sure you book the job in with wicked in advance (if using them) as it can take a while for them to schedule it around other work,
Edit: if PDK, make sure to leave the car in neutral before removing the console as it won’t clear the obstructions.
991 C4S - Riviera.
Bund
PostPosted: Fri Feb 01, 2019 11:44 pm    Post subject: Reply with quote
Thanks for the reminder to give them a shout as I wanted to check about prices/times etc.
After doing it do you have any advice on colour combos or oem finish as I've always proffered extended leather to the paint finish but the cost difference is about £500 it seems? Do they offer the leather stitched oem look?
G2
PostPosted: Sat Feb 02, 2019 7:40 am    Post subject: Reply with quote
[quote="Bund"]
Wicked don’t do leather. They are a specialist coatings company.
What colour is the car and interior ?
991 C4S - Riviera.
MattyR
PostPosted: Sat Feb 02, 2019 5:16 pm    Post subject: Reply with quote
Bund wrote:
Thanks G2 & Phil, the fairmile meet may work well for a talk through if I’m struggling as wont collect car till early March...
So what did you buy in the end!?..
Atlas Grau on Ocean Blue Gen 2 997 C2 Carrera
Sold: Aventura Grün 993 C2 Carrera
PostPosted: Sat Feb 02, 2019 8:09 pm    Post subject: Reply with quote
[quote="G2"]
they do a soft touch finish similar to oe but with any colour base so you could for instance have a dark or light grey soft touch or even red Grin or the standard high gloss finish to match the bodywork. or even a carbon dipped finish like the first one I had before going body colour , the one I had was a blue carbon dip but its avail in all colours Thumb
 Filesize:  81.84 KB
 Viewed:  933 Time(s)
 Filesize:  88.57 KB
 Viewed:  933 Time(s)
Bund
PostPosted: Sat Feb 02, 2019 8:29 pm    Post subject: Reply with quote
Meteor grey with black, would piano black match the surround of the sat Nav or look like I’ve taken a console out of a black car when you open the door and see grey shuts?
MattyR I gave a deposit on a private 4s car advertised on ph up in Scotland. Won’t get it this month though but early next.
PostPosted: Sat Feb 02, 2019 8:46 pm    Post subject: Reply with quote
personally I would do it meteor grey Thumb but its down to your personal taste .
After all I did this to my gen1 Grin Grin Grin
 Filesize:  75.91 KB
 Viewed:  916 Time(s)
Bund
PostPosted: Sat Feb 02, 2019 8:58 pm    Post subject: Reply with quote
I’ve got time for sure yet Meteor Grey 😆 is top of list at the moment.
Bund
PostPosted: Mon Feb 11, 2019 9:59 pm    Post subject: Reply with quote
Seems like the guys who got on the first time round had a very good deal as Lyle has told me he lost on each one due to a miscalculation.
This time round 10 jobs will get it to £215.
I’ll give it till next month if anyone is interested?
toddy2
PostPosted: Tue Feb 12, 2019 5:30 am    Post subject: Reply with quote
I'm in for my centre console, having missed out on the last round. Just need to decide what else to do Question
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944 (Sold)
Goto page Previous  1, 2, 3 ... 31, 32, 33, 34  Next
Page 32 of 34
