991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
love154
PostPosted: Sun Jan 27, 2019 5:48 pm    Post subject: Reply with quote
Had the car inspected 6weeks Ago and he said it had a new condenser so do think it’s that was also Colling well then not tested it since
PostPosted: Sun Jan 27, 2019 7:56 pm    Post subject: Reply with quote
That noise due to low a/c gass is a new one on me .. you would need to get it regassed as thats what causes noises with a/c systems.
sp1ke seems like you were bang on the money there worship
love154
PostPosted: Sun Jan 27, 2019 10:11 pm    Post subject: Reply with quote
Well done spike 👍🏼 I’ll get a re gas and see what happens. Is it an opc job
TonyC911
PostPosted: Mon Jan 28, 2019 7:12 pm    Post subject: Reply with quote
Most reputable garages can give you a re-gas and check the system for leaks. I have used kwik fit a couple of times, as I like the fixed price option.
2012 Carrera S - Agate Grey / Pebble
Ex 2007 Carrerra S
Ex 2005 Boxster S
Ex 2003 Boxster 2.7
Ex 1998 Boxster 2.5
PostPosted: Mon Jan 28, 2019 7:37 pm    Post subject: Reply with quote
Quick -fit , halfords .. anywhere thats cheap basically .. all you are doing is adding gass .. most machines these days do a leak test so if it fails that they wont gass it but advise it needs to be checked for leaks .
i still find it a bit of a strange noise for a low a/c gass fault .. im well used to them but if the noise goes when its turned off then that is the logical conclusion .
I will be interested to know if a regass fixes it though so please update here .. i learn new things everyday and things like this not only teach me but help others in the long run !
love154
PostPosted: Sat Feb 16, 2019 8:23 pm    Post subject: Reply with quote
Update. So had the car re gassed today and was out for a fair bit and the knocking has seem to have gone. So thanks for the help If it comes back I’ll update again but for no problem solved 👍🏼
Goto page Previous  1, 2
Page 2 of 2
