997 : 2004- 70
Boxster : 1997- 22
Cayman : 2005- 15
weejimmy
PostPosted: Mon Jan 28, 2019 10:42 am    Post subject: Wiper blades Reply with quote
I've been having major issues with the screen on my GTS. Initially it was smearing horribly at night such that I was pretty much driving blind. I think somehow I got some silicon on it... possibly off my road bikes which I transport on the roof.
As part of sorting that I replaced the blades just in case they were impregnated and now I have the opposite problem. No smearing but I am getting awful judder as the there is too much friction!
I replaced the original factory blades with a pair of Bosch Aerotwin A698s which area allegedly the correct ones. Anyone know if these are the OEM units? They were pretty cheap at £25 or so. I got them from wiperblades.co.uk who were great and actually replaced the first set they sent when I complained of judder ... unfortunately the replacement do the same!
From what I can see via online 911 parts sellers 'genuine' Porsche parts are more like £50. Are they the same? I'm not trying to be a cheapskate - it was just easier to order them online and fit them myself than have to deal with my OPC for what I figured was the same part. Maybe I got that wrong!
Unsure what to do. The screen is super clean. I could apply a rain repellent to try and lower the friction or maybe just get some OEM blades from my OPC.
Anyone ever had anything similar? I am a bit fussy on keeping my screen spotless and I hate any kind of wiper smear.
frustrated
Current: 991.2 C4GTS
Past: 991.1 C4S
TonyC911
PostPosted: Sun Jul 21, 2019 7:49 am    Post subject: Reply with quote
I like to keep my cars stock and might also want to renew the warranty.
Porsche want over £60 for a pair of OEM wipers Surprised
Anyone know which company manufactures these wipers?
2012 Carrera S - Agate Grey / Pebble
Ex 2007 Carrerra S
Ex 2005 Boxster S
Ex 2003 Boxster 2.7
Ex 1998 Boxster 2.5
TonyC911
PostPosted: Sun Jul 21, 2019 9:02 am    Post subject: Re: Wiper blades Reply with quote
frustrated
I have seen this problem when the wiper arms are badly adjusted or have been bent slightly, which changes the angle of attack and how the blade sits on the window.
Did you find a fix?
Ex 2007 Carrerra S
Ex 2005 Boxster S
Ex 2003 Boxster 2.7
Ex 1998 Boxster 2.5
MLB9911
PostPosted: Sun Jul 21, 2019 11:42 am    Post subject: Reply with quote
i had smearing also on my 911 and changed factory blades at about 13k miles to Bosch ones from Halfords - sorted. Although prior to that I had also put RainX on and that still works a treat.
archied
PostPosted: Sun Jul 21, 2019 7:20 pm    Post subject: Reply with quote
Ive noticed on my GTS that the washer on the passenger side doesn't actually hit the window fully as the RHS does, it grazes the LHS wiper arm and then disperses onto the screen, my OPC said nothing to worry about its how they operate and the nozzles cant be adjusted. It was one of those explantions that defy logic but you end up trying to digest it given you cant mess with the nozzle or fear doing anything to harm the warranty on an area you've already flagged with the dealer.
TonyC911
PostPosted: Sun Jul 21, 2019 7:31 pm    Post subject: Reply with quote
Newbie question, which side should have the longer wiper fitted? Drivers or passenger side?
Ex 2007 Carrerra S
Ex 2005 Boxster S
Ex 2003 Boxster 2.7
Ex 1998 Boxster 2.5
Rhodris-dad
2015 Porsche 991 Carrera 4 GTS
PostPosted: Mon Jul 22, 2019 1:47 pm    Post subject: Reply with quote
If you don't put OEM blades on you can forget renewing your warranty....unless you are prepared to replace them at the 111point check.
I put Bosch blades on my 997 (Bosch parts are used on these cars e.g throttle body housing)...........come renewal of warranty time, I had to have them replaced with originals.
One year it failed the 111 point check due to a non OEM battery.
2015 991.1 C4GTS PDK
2010 997 C4S PDK sold
2003 996 C2 Tip sold
TonyC911
PostPosted: Mon Jul 22, 2019 6:49 pm    Post subject: Reply with quote
I had exactly the same problem with my 997.
However my 991 is not under warranty so this is less of an issue for me, but I would still like the same look as OEM if possible.
Looking closely at my wipers, I can only see a very small 991 part number and no makers mark. However, the wipers do appear to be very similar to the Bosch Aerotwin model in the pictures I have seen? With the 997, the wipers were a completely different design to the Bosch options.
Dont know
Ex 2007 Carrerra S
Ex 2005 Boxster S
Ex 2003 Boxster 2.7
Ex 1998 Boxster 2.5
