997 : 2004- 62
Boxster : 1997- 24
Cayman : 2005- 20
PostPosted: Thu Jan 24, 2019 11:51 pm    Post subject: LN Engineering IMS 'UPGRADE' Reply with quote
Just spotted this on Facebook:
https://www.facebook.com/porscherepairservice/posts/2274718302746848?__tn__=C-RH-R
bakerboy4s
PostPosted: Fri Jan 25, 2019 1:21 pm    Post subject: Reply with quote
Hi Alex
No doubt LN will point out the quantity sold versus quantity failed, it would be interesting to know if the percentage failure of retro fitted ims is similar to original ims failure!
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Fri Jan 25, 2019 1:41 pm    Post subject: Reply with quote
bakerboy4s wrote:
Hi Alex
An educated guess would say the failure rate of retro fits should be higher than factory due to the risk of damage during install. Will the bearing go in straight? what are you pressing against at the other end to get the bearing in? etc etc.
No need to replace a perfectly functioning bearing really. Inspect it for sure, but I wonder if bore score is more common nowadays than IMS bearing failure.
996 parts cache sell off
PostPosted: Fri Jan 25, 2019 4:18 pm    Post subject: Reply with quote
About 50%
bakerboy4s
PostPosted: Fri Jan 25, 2019 4:45 pm    Post subject: Reply with quote
wasz wrote:
bakerboy4s wrote:
Hi Alex
I guess the general consensus now is inspect bearing, removal of seal and if a new bearing is required a strip down of the engine and replace the offending article is the way to go, but do you replace with a ball race, roller bearings or the non bearing LM version?
I'm not looking to open another long tirade of posts just a quick survey from the engineers among us.
Hopefully it'll be along time until I have to make the decision!
PostPosted: Fri Jan 25, 2019 4:50 pm    Post subject: Reply with quote
One of them there £30 washing machine bearings infrasilver fits in his.
Magic919
PostPosted: Fri Jan 25, 2019 5:19 pm    Post subject: Reply with quote
LN Engineering were quite clear about their failure rate when we put one in a 996 some years ago. It wasn’t a fit for life fix by any means.
997.2 C4S PDK
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Fri Jan 25, 2019 5:31 pm    Post subject: Reply with quote
Mine is actually a Hartech washing machine (same spec) bearing.
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Fri Jan 25, 2019 5:32 pm    Post subject: Reply with quote
They actually denied for years saying it was installation errors but then had to admit it was no better or worse than a standard bearing but only when the lawyer's came a knocking.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Jan 25, 2019 6:30 pm    Post subject: Reply with quote
My own thinking is that the failure rate of original bearings was say 5%.
Over time, the % gets smaller on a Darwinian basis as the ones that were faulty have failed.
If you replace a perfectly good bearing that’s survived this long you are increasing, not decreasing the chance of failure.
The only genuine improvement that I can see is the modded 997 bearing.
Chris_in_the_UK
PostPosted: Fri Jan 25, 2019 8:50 pm    Post subject: Reply with quote
Indeed - always been a 'snake oil' item.
2006 Cayman S PCCB's
kas750
Shanghai
2006 Porsche 911
PostPosted: Fri Jan 25, 2019 8:58 pm    Post subject: Reply with quote
thumbsup
PostPosted: Fri Jan 25, 2019 9:22 pm    Post subject: Reply with quote
This is one of those do i or dont i answer topics ..
You are all aware of what i do and What i do Here .
Garage checks said bearing and says there is no play and its fine .. customer wants it replaced , hes read the forums these things go bang and he wants a new one .
It doesnt matter how many times i tell him the bearing is fine he wants a new one .
Garages are here to provide a service , we advise the customer but if he wants a new bearing being which ever make we do what is asked of us .
Now and then we find a shagged bearing .. excessive play .. we give the customer the option , fit an aftermarket bearing at say £1200 or do the proper repair .. circa £6k .. its pretty obvious what they choose .. we can argue the benifits but if the customer cant afford it then its irrelevant .
i do know the ealy LN bearing problems were down to the fitting process which has now been modified .. well .. its been explained to me shall we say .
I Dont know if these are a long term fix .. none we have fitted have ever come back .. LN offeres a warrenty .. not sure if its good for anything as we have never had a problem ... is there a choice that customers can afford though .
At the end of the day .. if your bearing has play then something needs to be done and cost is the factor on what you have done .
Customers decides .
Forums are a mine of information but they also cause issues like this ,
My opinion anyways .
EDIT ... we dont fit very many per year .. perhaps 3
Indy Mechanic .
PostPosted: Fri Jan 25, 2019 10:35 pm    Post subject: Reply with quote
thumbsup
thumbsup thumbsup
Infant Mortality. If this graph had a scale, the letter 'e' of Time would be around 100k miles
Chris_in_the_UK
PostPosted: Fri Jan 25, 2019 10:39 pm    Post subject: Reply with quote
The engineer in me still maintains this is (was) the wrong solution (type of bearing) for what is a low % issue.
I respect why professionals in the Porsche repair business may take a neutral view - particularly as it might affect customer perception and money through the door. The internet has some influence and lots of folk have next to no mechanical savvy (lot on here seem to have, thankfully).
mid
PostPosted: Mon Jan 28, 2019 1:51 pm    Post subject: Reply with quote
so here's my dilema - my brother has had his 996 about 3 years, was spooked by all the internet stories and had the LN ceramic fitted to his car within the first week of ownership....he was running at about 95K at the time but the car had seen little use over the previous few years.
on inspection he made a good choice as the removed original was almost seized solid! so he was happy...
fast forward 18 months or so and about 2K miles (if that) and BANG! engine self destructs in a BIG way... but it wasn't the IMS causing the failure.
in the meantime, i've bought myself a 100K mile 996 still running the original bearing...
i have the LN out of his old engine (removed with the proper tools etc) and it seems perfect. LN insist that it should never be reinstalled after removal and i need to buy a new one.
so do i fit it?
wasz
Paul Ricard
PostPosted: Mon Jan 28, 2019 2:19 pm    Post subject: Reply with quote
mid wrote:
so do i fit it?
Noooo. Next time you need a clutch I would inspect the bearing. If its silky smooth with no play as it probably is, flip the seal off and stitch it all back up.
This just proves it. You could do all that unnecessary work and still something else will fail. Its a 100k 15 year old engine, lots of things wear out / age.
You might damage the old one on removal, damage it or something else on the way in, or be out of line on reassembly.
You'd be even more miffed if the replacement bearing failed....
I've never ever heard of anyone using second hand press fit cartridge bearings in any application, they are single use surely.
If it will help you sleep at night put a new bearing in! Doesn't have to be an overpriced one.
But ooooh what about your main bearings won't they be worn at that mileage? Bores starting to score? Or your vary cam pads? chains stretched much? May as well rebuild and be completely at ease.
If it were me - full rebuild now and future proofing, or inspect and enjoy it till it dies. It might never happen (in your ownership).
kas750
Shanghai
2006 Porsche 911
PostPosted: Mon Jan 28, 2019 3:13 pm    Post subject: Reply with quote
Equally it could of been collateral damage caused by the replacement that instigated the failure I.E damaged chains/tensioners.
What part failed?
PostPosted: Mon Jan 28, 2019 7:47 pm    Post subject: Reply with quote
so do i fit it?
Never ever in a million years use it .. and i fit these things from new !!!
Indy Mechanic .
mid
PostPosted: Tue Jan 29, 2019 3:25 pm    Post subject: Reply with quote
What part failed?
we're not actually 100% sure what was the primary cause... my theory is that one piston siezed... i think a ring slipped. this was the only piston that didnt contact valves. the resultant mess makes it difficult to pinpoint any one particular area!
re the LN ims.... i'd pretty much talked myself into leaving alone - and enjoying it until if or when it goes bang... i've always planned on mine being a keeper so even if i park it up for a while and work on it myself its not a problem.
