991 : 2011- 19
996 : 1997-2005 33
993 : 1993-1998 7
Boxster : 1997- 33
Cayman : 2005- 20
Lenny39
PostPosted: Wed Jan 16, 2019 12:13 pm    Post subject: PCM3 - Iphone 6 Issues Reply with quote
Morning all,
Starting with the good news I took my 997.2 in for its first service (since I've owned it, only a few weeks) and the Porsche dealer didn't find any issues with the car.
However, I'm having problems connecting my phone to the PCM3. Dealer tried as well and received the same message which is as follows:
Connection Unsuccessful
Make sure 'PCM' is turned on and in range.
The salesman tried his own Galaxy phone and it connected straight away. Is it an issue with the iPhone 6?
Any help would be appreciated.
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Wed Jan 16, 2019 5:35 pm    Post subject: Reply with quote
Sorry, can’t help, mine works fine. Late 2009 without 2015 map update
PostPosted: Wed Jan 16, 2019 5:49 pm    Post subject: Reply with quote
lenny have you tried turning the phone off completely then turn it on and let it search for the bluetooth PCM while the pcm is in search mode
Lenny39
PostPosted: Sun Jan 20, 2019 7:54 pm    Post subject: Reply with quote
Tried this but still doesn’t work. It states it’s looking for a phone with SIM Access Profile - which I think could be the issue.
silvermilnec
PostPosted: Tue Jan 22, 2019 11:35 pm    Post subject: Reply with quote
I had the same problem and it was the software, I can’t remember the version I had but the car a 2009. Worked fine after the upgrade I’m surprised the dealer didn’t know about it.
I’ll try and find my old thread Thumb
1998 968
2000 996 C2
2006 997 4S
2009 997 1.5 Turbo basalt black on black
silvermilnec
PostPosted: Tue Jan 22, 2019 11:49 pm    Post subject: Reply with quote
See if this helps
http://911uk.com/viewtopic.php?t=112960&highlight=
1998 968
2000 996 C2
2006 997 4S
Lenny39
PostPosted: Thu Jan 24, 2019 8:52 am    Post subject: Reply with quote
Thanks for this I will look at which version I'm running.
FZP
PostPosted: Thu Jan 24, 2019 9:15 am    Post subject: Reply with quote
I'd also try connecting via SIM only profile and see if that works. I had issues with a galaxy and from memory on SIM only it would work, but not on Hands-free profile.
I can't remember which profile is which, but one of them uses the car's mobile antenna and ends up storing sms messages on the PCM where the other profile is just a Bluetooth broker. I'm not sure if it made a difference to the call quality either.
Good luck
Lenny39
PostPosted: Sat Jan 26, 2019 4:48 pm    Post subject: Reply with quote
My software version is 1.41 which looking at different posts is not good!!
FZP
PostPosted: Sat Jan 26, 2019 5:21 pm    Post subject: Reply with quote
I'd suggest taking plenty of lube with you when you go to get the price for the update at your OPC ......this is going to sting a little.
PostPosted: Sat Jan 26, 2019 5:27 pm    Post subject: Reply with quote
I dont really know the phone but i assume its newer than the car ?
You can have the soft ware updated on the pcm which may fix this fault .
I remember when these first came out and not all phones would connect at the time , we had a list of ones that wouldn,t .
There is a setting you can alter with a tester but its been so long im afraid i cant remember .. i would need to sit looking at the coding to figure it out .
The above is about all you can try as its just a case of your phone speaking a different launguage than the PCM so they are not comunicateing where as the Galaxy is speaking the same launguage .
