ABS and PSM disco lightshow
peterzoom
25 Jul 2016
281
We have a bit of snow and ice like most of the country and it seemed like good fun to get the 911 out and play on the sub optimal road surfaces nearby.
Great fun and I would thoroughly recommend it, I had a blast
:thumbs:
However there was a recurring oddity in so much that when an enthusiastic bit of wheelspin or slightly sideways motoring occurred :puh: The ABS and PSM plus handbrake warning light all lit up and stayed on. However if I stopped and switched the motor off and waited 5 minutes they all went out and stayed out until the next sideways or broken traction moment occurred. Then the same process, switch off wait 5 minutes, switch on, all fine :?:
Question is... Is this normal/usual or is there a hint of a failing sensor/reluctor etc etc??
I have read the car for fault codes and there are none logged at all, which seems strange to me.
Anyone got a clue what might be going on?
I think Alex Yates had a play in the snow last winter and he turned off the pasm and abs
I did try it with the electronic assistance all off and it was fine and probably a lot more fun too!
However I am curious as to why the warning lights would all be triggered when the systems were live and be reset with a switch off :?:
That doesnt sound quite normal to me .. psm cutting in will illuminate to warn you but then should go out .. not need a ign off and on .. and certainly not for 5 mins ..
i would start with a fault code readout .. if there is a fault it will be logged and we can go from there .
No fault codes indicate the car is doing what it thinks is correct .. doesnt mean its correct though .. just means its a harder fault to find as its something failing within the limits .
abs pasm
I had this problem with mine , I did some research and it was the brake light switch on the pedal that failed , cheapest part to start with, replaced that and not had any issues since ,
abs pasm
Re: abs pasm
Thanks for the info everyone, the brake light switch sounds like a good place to start as I recently had to replace the clutch switch and as they are most likely to be similar vintage it might just be on it's way out like its cousin :thumb:
124,610
1,442,060
49,043
MartynT
