996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
dt4
PostPosted: Sun Dec 09, 2018 8:04 pm    Post subject: Oil pressure sender replacement Reply with quote
The pressure on the gauge is constantly high (off the scale high)
I would like to replace the sensor / sender, is this a straight forward job?
Does any one have a good spare I could buy to prove the sender being at fault
cheers
PostPosted: Sun Dec 09, 2018 8:10 pm    Post subject: Reply with quote
Ignition on but engine not running .. if it reads over 0 bar then 9.5 times out of ten then its a faulty sender unit .
Ive never seen it being anything other than the sender but i never give a 10 out of 10 Very Happy
https://www.design911.co.uk/fu/prod13546/Oil-Pressure-Sensor---Switch-Porsche-996-Carrera-34L---36L-and-997-Carrera-36L---38L-99660620302-99660620302/
I would shop around though .. probably cheaper elsewhere .
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Sun Dec 09, 2018 9:09 pm    Post subject: Reply with quote
As per DM, it’s the way to go!
Mine was reading 5 bar key in position one, I’ve just had it changed, I was told it was a simple job to replace. I also picked mine up from design911.
Ex. '99 996 C2 manual coupe.
Stoo.c
PostPosted: Mon Dec 10, 2018 9:03 am    Post subject: Reply with quote
I think I paid £50 on eBay from one of the well known parts suppliers for a genuine Porsche one (don't think you can get pattern ones anyway).
Providing you have a narrow enough crows foot wrench its a very simple swap.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
maldren
PostPosted: Mon Dec 10, 2018 10:00 am    Post subject: Reply with quote
D911 do a 'URO brand' part for £41.95+VAT (-discount).
I would be surprised if Porsche had their own specific sender unit, it's rather an industry standard part, we need to find out where else it is used. Mind you it isn't very expensive and an alternative part may not be much cheaper.
Are there any manufacturer's marks on the old part?
Mike
Kingb4
PostPosted: Mon Dec 10, 2018 11:44 am    Post subject: Reply with quote
I just replaced mine - as said above its very easy, using a crows-foot spanner to reach it from the underside, loosen it, then once unscrew it from the top by hand - obviously remove the two wires first!
I paid £55 (incl postage) for a genuine Porsche one (VDO manufacturer mark on the original and the new one) - got it sent by Silverstone OPC.
I would personally go for OEM, rather than save a fiver. (If there was a bigger differential, then it makes sense to consider alternatives)
2002 996.2 C2 Cabriolet
dt4
PostPosted: Mon Dec 10, 2018 12:43 pm    Post subject: Reply with quote
Thanks for the tips chaps,
Could you advise on the crow foot spanner size please, I don't have one so will need to buy
cheers
Kingb4
PostPosted: Mon Dec 10, 2018 1:38 pm    Post subject: Reply with quote
You will need a 19mm crow-foot spanner.
As with all tools, you can pay lots or peanuts.
I got a cheapo silverline crow-foot spanner set for £12 off Amazon. As I haven't needed them before, so didn't want to spend a fortune, for tools I may only use once. I normally steer clear of cheap tools - these seem ok. Am sure they wouldnt take a lot of use/abuse.
dt4
PostPosted: Mon Dec 10, 2018 6:24 pm    Post subject: Reply with quote
cheers, I will look them up
dt4
PostPosted: Sat Jan 05, 2019 8:07 pm    Post subject: Reply with quote
So got the car up the air to see how easy access was from underneath etc... not too difficult
Whilst looking at the sensor from the top I noticed one of the connectors was detached from the sensor.
Great I think it may have worked loose and thats the problem, simply reconnect and alls is well. Unfortunately not, reconnected and still the oil pressure is off the scale with the key at the first position and at idle
One of the connectors is crimped with heat shrink tubing rather than the OE block connector suggesting some previous connection "issues"
PostPosted: Sat Jan 05, 2019 8:18 pm    Post subject: Reply with quote
That sensor is for no oil pressure and the oil pressure gauge .. if a wire was unplugged but the gauge reads oil pressure then i assume the no oil pressure side was disconnected ... thats just a light on the cluster .
Replace the sensor and see what happens on the gauge .. its normally just this .
Heat shrink fix .. normally done as the wire is starting to come out of the connection (bare wires at the top of the connection ) .. you can replace the connection or heat shrink as in this case .
dt4
PostPosted: Sun Jan 06, 2019 3:59 pm    Post subject: Reply with quote
Thank you
Its looking pretty past it, can they be tested,
 Filesize:  660 KB
 Viewed:  1119 Time(s)
dt4
PostPosted: Wed Jan 16, 2019 6:01 pm    Post subject: Reply with quote
So I bought a new sender from design911 and fitted it tonight
Having never had a working gauge what should a good one show on start up ?
P911X50
PostPosted: Fri Jan 18, 2019 10:53 pm    Post subject: Reply with quote
What reading are you getting now from the new sender?
Porsche 996 Turbo X50 with 9e exhaust,
BMW M6 V10,
Previous
Evo 4 with Evo 8 MR Engine 360 bhp - Road Legal Track car
Previous
MR2 Turbo 280 bhp - Road Legal Track Car
dt4
PostPosted: Sat Jan 19, 2019 8:56 am    Post subject: Reply with quote
photos here
http://911uk.com/viewtopic.php?t=131908&highlight=
