mkoenigsheim
- Joined
- 8 Nov 2013
- Messages
- 182
Hi Segart - this is one of the most stupid and frustrating parts of the PCM system...
You are doing nothing wrong and the other guys are all correct but - What has happened is somebody has "hidden" the aux input for your car.
I had the same issue and the manual is useless.
This functionality exists so that when you press the source button - you don't have to cycle through non existent sources
The problem is that because all of the sources are hidden - you cant get to the menu to unhide them.
So what you need to do is:
1. Find a music CD
2. load the CD into the PCM and let it start playing music.
3. from the "disc" screen select the "option" tab at the top
4. you should see now in the option. area at the bottom right a button to "SET DISC/AUX"
press this
5. Choose the AUX ports you want to have available when you press the source button
6 make sure as a minimum the "AUX" box is checked or you will never see Aux as an option....
7. the other 2 AUX ports automatically become visible when you press SOURCE - if you tick the boxes here, they will be visible even is there is nothing connected to the ports
8. Follow the instructions in a previous post to connect your phone to whatever bluetooth adaptor you purchased
9. press the source button and choose the now miraculously available AUX button
10. Enjoy your Spotify!
11. Now turn that off and listen to your engine
12 Drive it like you stole it
This has me going crazy for weeks a year ago....
1. Find a music CD
press this
