991 : 2011-2019 0
997 : 2004-2012 1
Boxster : 1997- 22
Cayman : 2005- 14
Mr Rimmer
PostPosted: Mon Nov 26, 2018 8:43 pm    Post subject: 986 exhaust Reply with quote
Ok I was under my car at the weekend and noticed that the whole exhaust is pretty corroded. Also noticed a ratlle which I'm suspecting is coming from one of the cats, so looking at replacing the whole system with a stainless steel one. Would like a few recommendations or advice from folk that have done this. Thanks in advance.
Paul
kas750
Reims
2006 Porsche 911
PostPosted: Mon Nov 26, 2018 10:48 pm    Post subject: Reply with quote
The rattle can be the heat shield on the pipe near the cat.
This can be spot welded in place or others have secured it with a hose clip.
PostPosted: Tue Nov 27, 2018 8:05 pm    Post subject: Reply with quote
Agree
As long as the silencer seams are not corroded to the point of leaking then you are better off not replacing the system .. unless you want something different of cource .
Silencer blowing and you will end up with an eml due to lambda faults .
The rattles are either the cat heat sheilds .. you replace the fixings .. comon as muck .. if i had a penny for everyone of these ive replaced over the years ... Very Happy
Or its going to be the cowling on the section going to the cat .. just cut it off and bin it or stick a couple of jubilee clips around it .
Mr Rimmer
PostPosted: Wed Nov 28, 2018 12:46 am    Post subject: Reply with quote
Cheers guys, I'll take a better look. Thanks for the heads up.
The return of Marty Wild
PostPosted: Wed Nov 28, 2018 8:52 am    Post subject: Reply with quote
Mr Arnold Judas Rimmer?
Boxster S 986.1
Mr Rimmer
PostPosted: Wed Nov 28, 2018 10:22 am    Post subject: Reply with quote
I wondered how long! 🤣
PostPosted: Wed Nov 28, 2018 12:14 pm    Post subject: Reply with quote
https://www.youtube.com/watch?v=r-ZiI3iVgpM
Boxster S 986.1
Mr Rimmer
PostPosted: Fri Jan 11, 2019 1:30 pm    Post subject: Reply with quote
So finally got around to having a better look, it's definitely not heat shield as it's already been removed. It's definitely coming from inside the exhaust system because as you tap it with a hammer you can definitely hear the rattle. It's rather tinny.
