Wh1t3Kn1ght
- Joined
- 22 Aug 2018
- Messages
- 573
HSC911 said:That's a lot of paper clips :grin:
Yes indeedy - they must have thought I was into some dodgy S&M when I purchased a bulk load of them! :floor:
Saw the idea whilst perusing other car restoration projects on the web. Unfortunately the roof and window trim is showing its 30 years of age and is brittle and ripped in places so I didn't have much to clip over the edge. Used some of that Alpha Thixofix contact adhesive to glue it down, will come in handy when I finish the interior off and glue the carpet edges back down.
Spent a few hours on New Years day and managed to do a few more things -
1. Removed the inlet manifold (after procuring a deep offset spanner to reach one of the awkwardly placed retaining bolts)
2. Removed the water pump (surprisingly easily after reading all the horror stories about snapped bolts and studs)
3. Drained the oil
4. Had a mare with the oil filter which the garage must have over-tightened when the oil was last changed.
So the water pump didn't actually look that bad and the bearing feels as good as the new pump (was a Laso) but after going through my receipts it was changed during the later months of 2007 so going on for 11 years old and just over 60k miles. I was looking at the Geba pump on Design911's website the other night and must have clicked the order button by mistake :grin:
Now the oil is a bit of a horror... it has a strong smell of petrol in it but still has some viscosity. The colour looks very odd, almost like milk chocolate but the original oil was purple... last change was Royal Purple fully synthetic and I can't quite remember what used Royal Purple looks like, so it could be perfectly normal. The magnetic plug was covered in goo I set about spreading it out on a paper towel and couldn't see any metallic particles in it so wondering why it was stuck to the plug like that. Also I'm hoping that the petrol smell and perhaps the colour are more or less down to the car being off the road for 4-5 years and then the storage people flooding the engine when they tried to start it a few months ago (they never did get it started and claimed the battery was dead - which wasn't strictly true as I managed to charge it up with my CTEK conditioner fine). I've got some Shell Helix HX7 10W40 semi-synthetic ready to put in as a temporary flush oil when it is all back together.
Once I am done with the front end engine seal and all the standard service items I will be doing a fuel pressure check to make sure the fuel pressure regulator hasn't gone bad (hoping not as they seem to be around £300!). I will keep an eye on the new spark plugs to see if any of the cylinders is getting overfueled. The picture of the spark plug in the posts above is from cylinder #1 and was very black and sooty, I haven't checked the others yet...
And then there was the goddamn oil filter that Jeff Capes tightened up... I tried a oil filter socket wrench (that just slipped). Then I tried my oil filter chain wrench (it moved about a mm or two and then proceeded to start squashing the filter and punctured it). I then resorted to the screwdriver stabbed through the side method and still couldn't get enough torque to get it to turn (perhaps needed an extra long screwdriver). So now I've decided to sacrifice my oil filter socket wrench and stuck it to the top of the oil filter with some araldite. Going to let it cure for a good couple of days and then give it another go. I'm hoping that should do the trick as I've had good results with araldite before. If that fails than hell knows what I will do - probably cry! :sad:
