996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
adspencer
PostPosted: Sun Dec 30, 2018 4:48 pm    Post subject: Intermittent Wipers not Working Reply with quote
Hi All,
My intermittent wipers have stopped working. Full works fine and I have read checking the fuse and replacing the speed dial are common issues, any other suggestions before I do these ?
Adam.
PostPosted: Sun Dec 30, 2018 5:29 pm    Post subject: Reply with quote
Not sure what year your car is ....
Check fuse C6.
Move the wiper resistor (speed dial ) a few times .
Wiggle the wiper stalk when in Int. position.
relay for the Int wipers is relay support one so under the dash o/s/f and its position 16 (small numbers on the board to locate them )
Try a gentle tap on the relay.
My guess would be this relay but there are several things it could actually be so its a case of out with the volt meter and start testing if none of the above .
adspencer
PostPosted: Sun Dec 30, 2018 5:48 pm    Post subject: Reply with quote
Thanks will check them out, it's a 2002 Targa.
Ghianightmare
PostPosted: Mon Dec 31, 2018 12:23 am    Post subject: Reply with quote
i hate those intermittent problems Grin
Sorry, couldn’tl resist....
2002 Seal Grey C4S
adspencer
PostPosted: Mon Dec 31, 2018 7:19 am    Post subject: Reply with quote
thumbsup
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Mon Dec 31, 2018 12:31 pm    Post subject: Reply with quote
Floor
Ex. '99 996 C2 manual coupe.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Mon Dec 31, 2018 1:28 pm    Post subject: Reply with quote
I've had an issue with my intermittent actually working intermittently, it may work for days or weeks but all of a sudden it'll stop and not work for a little while, obviously it's always raining. I've never done anything about it as it's not really bothered me.
