997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Tue Dec 04, 2018 9:29 am    Post subject: Tiptronic Question .. Reply with quote
My (1998) 3.4 moves off in first gear on initial start up, but within a half mile generally moves off from second gear unless floored.
HOWEVER! .. My pals (2003) 3.6 ALWAYS moves off in second gear unless floored.
Is there a design change on second gen 996’s?
Ex. '99 996 C2 manual coupe.
PostPosted: Tue Dec 04, 2018 9:51 am    Post subject: Reply with quote
My Gen2 car only ever pulled away in first the first time after being started up so it might be that he's just not noticing it.
ballcock
PostPosted: Tue Dec 04, 2018 11:05 am    Post subject: Reply with quote
Thanks T8. He doesn’t normally miss much!
I’ll get him to check again tho.
Rob996c2
PostPosted: Tue Dec 04, 2018 11:14 am    Post subject: Reply with quote
The 3.6 will use 1st when engine cold. Once it starts to warm up will default to using 2nd. I have always been told to manually change to 1st to pull away as this should help prevent bore scoring.
ok51mon
PostPosted: Wed Dec 05, 2018 11:16 pm    Post subject: Reply with quote
TCU revision
4.1L Incoming
diverzeusy
PostPosted: Wed Dec 05, 2018 11:26 pm    Post subject: Reply with quote
ok51mon wrote:
TCU revision
tcu ??
better to spend a lot and lose a little than spend a little and lose it all!
ok51mon
PostPosted: Wed Dec 05, 2018 11:30 pm    Post subject: Reply with quote
Transmission control unit.
4.1L Incoming
ballcock
PostPosted: Thu Dec 06, 2018 9:27 am    Post subject: Reply with quote
Hi there,
What changed with the revision?
4b4
PostPosted: Thu Dec 06, 2018 11:29 am    Post subject: Reply with quote
Me too, if I come to a complete halt.
2004 996.2 C4S Cabrio Tip in Arctic Silver
