997 : 2004- 74
Early 911 : 1964-1977 2
Boxster : 1997- 14
Cayman : 2005- 16
davidjf7
PostPosted: Fri Nov 30, 2018 6:31 pm    Post subject: What dampers? Reply with quote
Hi all,
Just been up to Centre Gravity today (who were amazing - everyone should pay them a visit!).
Need new dampers as one of mine is leaking, and going to replace all 4 plus springs to future proof the car as it's likely a keeper.
What would the advice be on what to get?
I have the DSC module installed and after talking with CG am looking at either Bilstein B6s with Eibach lowering springs, or B16s.
The car is used primarily on b roads and a bit of m-way driving, but no track use.
Will the B16s be worth the additional cost if i don't track the car?
Thanks guys Thumb
MaxA
PostPosted: Sat Dec 01, 2018 5:12 am    Post subject: Reply with quote
If you're going to fit and forget, then go for the B6s, but if you want to optimise the set up and want all the adjustability, then run B16s.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
hermes
PostPosted: Sat Dec 01, 2018 6:57 am    Post subject: Reply with quote
I'm in a similar position - I wanted to lower the car a bit so took CG's advice
and ordered the Eibachs (I also have the DSC module), along with Bilstein
B4s as it seemed sensible to fit new ones at the same time (although I'm still
waiting for stock!)
davidjf7
PostPosted: Mon Dec 03, 2018 10:43 am    Post subject: Reply with quote
Thanks chaps - not likely to tinker with settings so think I'll go B6 + Eibachs
Just wondering whether spacers might also be a good idea to finish off the look...
Dont know
hermes
PostPosted: Thu Dec 06, 2018 1:32 am    Post subject: Reply with quote
What was the reasoning behind B6s out of interest?
I have Oz wheels on mine, with non standard offsets on the fronts, but I’m using OEM 5mm spacers on the rear, giving +5 rear and +4 front. Will see if a bit more is needed once the car is lower on the Eibachs.
PostPosted: Thu Dec 06, 2018 8:27 am    Post subject: Reply with quote
My car is currently at 9e having B16's fitted. It currently has Eibachs which were fitted in April this year. I've done less than 500 miles on them, PM me if you are interested but I do not think the new ones are too expensive Smile
Black 997 9e Turbo Manual
Black 997 C4S Manual - Sold
davidjf7
PostPosted: Thu Dec 06, 2018 9:58 am    Post subject: Reply with quote
B6 is monotube v twin tube for the B4, so better performance and control.
CG only advised them as I'm already running the DSC module, otherwise on the harder PASM setting it would be even stiffer (and so probably undriveable except on track!)
I managed to get a cracking deal on Design 911 for all 4 dampers at just over £1,500.
Also found someone on eBay selling a new set of springs for £200, so have done quite well
Appreciate the offer though apollokre1d!
PostPosted: Thu Dec 06, 2018 10:02 am    Post subject: Reply with quote
Pleasure mate, good luck and let us know what it is like after it is all done Smile
davidjf7
PostPosted: Thu Dec 06, 2018 10:18 am    Post subject: Reply with quote
Will do Thumb
CG visit is next Thursday - can't wait to drive it after everything is done!
