997 : 2004- 74
996 : 1997-2005 29
Early 911 : 1964-1977 2
Boxster : 1997- 14
Cayman : 2005- 16
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Fri Nov 30, 2018 12:24 pm    Post subject: Reply with quote
They’re cheap for a reason as stated above. And even with a Hartech bells and whistles rebuild they’re STILL cheap. Win win.
I had four years of classic G Wagen ownership, with a very good friend swinging the spanner at mates rates, the bills were still horrendous - many multiples of a full on 996 engine rebuild... On a truck that has a name for incredible durability.
Just plan on an engine rebuild and half as much again for other bits and you’re sorted, bonus if the money stays in your wallet.
All IMH but The biggest problem is the 996 has, for the last ten years, been in the price range of those who want a 911 but don’t have anything left to keep it in shape.
Ex. '99 996 C2 manual coupe.
GMG
PostPosted: Fri Nov 30, 2018 4:47 pm    Post subject: Reply with quote
...agree and share this view; keep a £15,000 ish 'chocolate engine fund' and you need worry not...
[/list]
Bluebird911
PostPosted: Fri Nov 30, 2018 6:08 pm    Post subject: Reply with quote
Hi Mike, so sorry to hear your horrendous experience of engine failure and pleased you have shared this with us. It has the makings of a very interesting thread. Has a full fault diagnosis been carried out to ascertain the cause? You are in the best hands for that!!
@GMG I wouldn’t take the comments you are receiving too personally; even though you have been accused of pedalling lies and not being very helpful to the forum members, it is the message of failure that people don’t want to hear. You are in good company though, Baz got flamed when he reported a high number of engines that Hartech have opened up have signs of crankshaft journal wear at 100k miles and Ken has also been torched for some of his cautionary comments. They all have good experienced based information, but people didn’t want to read / believe this about their P&J so attack it and try to disprove it. We are on a 996 forum after all, you are hardly likely to get a good reception or balanced treatment.
Baz’s message was, ‘Guys, if you value your crankshaft, you should consider bearing replacement at 100k miles’ a stitch in time saves 9 etc! But that message wasn’t well received.
I thought @deMort nailed it with his comments which I and I’m sure other member value highly and Mr Corn’s balanced and experienced based comments.
IMS failure or bore scoring occurrence is relatively rare, but when it happens it hurts – it really hurts. That should be remembered. So in conclusion, you have as much right to post and share your experience as anybody, and your experienced based opinions may be considered extreme by some, but others may say that to do nothing, don’t worry, it won’t happen is equally extreme.
You do what you believe to be right!
Just my 2p!
Apologies Mike, your thread has probably been hijacked!!
GMG
PostPosted: Fri Nov 30, 2018 8:01 pm    Post subject: Reply with quote
...thanks bud and given we live in a democracy I am comfortable with speaking my mind and tbh don't really give a toss about the 'feedback' ...
What I know is that Hartech and every specialist I spoke with were rebuilding engines that had ***** themselves, that such occurrences aren't rare, that these failures are beyond the expected wear and tear for older performance cars and nothing can be done to mitigate or predict...
...and anyone stating that 100k miles cars are just run in are deluding themselves! The internals in the majority of opened engines will be significantly worn...my specialist commented on how 'good' my car was at 69k miles but I still required the replacement of everything from the tandem pumps,oil pumps,varicams etc etc ! Oh and he had three more M96 engines to fix!!
PostPosted: Fri Nov 30, 2018 8:07 pm    Post subject: Reply with quote
Still more robust than the M97 Grin
cossiemike
PostPosted: Fri Nov 30, 2018 8:47 pm    Post subject: Reply with quote
With reference to wear on my engine,bottom end was definately gone,but I did hear it starting to tingle,I know from race experience to stop immediatley but did'nt.That would have saved the crank & rod. Grant said the pistons were savagable.I just went the 3.7 route because you can't have enough torque or power.I am not gentle with any car I have and have a scrap box with destroyed engines from Alfa 16v flat 4's,inline factory race 2 litre twin cam. Cosworth turbo with cracked blocks.Rods through the side in Cooper S. All engines do go bang if you take to the limit. I did have the 996 round Millbrook one day for exercise.The bill for the engine is compareable with the engine I am having built for my Cosworth.I have been told not to take the 996 on track when done and enjoy it as a road car.Will update with progress.Mike.
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Sat Dec 01, 2018 11:29 pm    Post subject: Reply with quote
Quote:
..I am not gentle with any car I have and have a scrap box with destroyed engines..
Surprised this may explain a lot..
asterix_the_gaul
Maybe a custom hard cut limiter next time?
coullstar
PostPosted: Sat Dec 01, 2018 11:56 pm    Post subject: Reply with quote
That's not the issue, oil starvation is from what I read. Not uncommon with 996 on track.
asterix_the_gaul
PostPosted: Sun Dec 02, 2018 12:14 am    Post subject: Reply with quote
Yes, that too, I was more thinking of the box of miscellaneous broken engines having a common theme
I would hope the 3.7 redesign addresses the oil starvation in long high g corners, I think I read hartech do something to counter that design flaw?
cossiemike
PostPosted: Sun Dec 02, 2018 3:26 pm    Post subject: Reply with quote
I have to say in my defence that most of my blown engines have been during races. The 996 was I am pretty sure oil surge. I haven't tracked it,just did one day at Millbrook wit CAT training.Mike.
Dammit
Watkins Glen
PostPosted: Sun Dec 02, 2018 3:27 pm    Post subject: Reply with quote
I have been wondering what it would to dry-sump one of these.
cossiemike
PostPosted: Sun Dec 02, 2018 3:38 pm    Post subject: Reply with quote
You can dry sump them,just replace the bottom end with an early 991/964 bottom end.
Dammit
Watkins Glen
PostPosted: Sun Dec 02, 2018 3:51 pm    Post subject: Reply with quote
Hah, simple.
I didn't realise that the 964/993/Mezger was staggered in the opposite direction to the M96/97. Underlines how different they are.
cossiemike
PostPosted: Thu Dec 20, 2018 5:48 pm    Post subject: Reply with quote
Hi,picked the engine up today from Hartech. Had a full rebuild,3.7upgrade,race sump so hopefully no oil surge.Will start putting the engine in tomorrow. I have new AOS,new manifolds + Topgear exhaust amongst other parts. Hopefully have it done for christmas to play with. Mike.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Dec 20, 2018 6:04 pm    Post subject: Reply with quote
Happy Christmas, what a great project to do when you have a few days off work. Enjoy.
PostPosted: Thu Dec 20, 2018 6:20 pm    Post subject: Reply with quote
+1
911tom
Watkins Glen
PostPosted: Thu Dec 20, 2018 8:08 pm    Post subject: Reply with quote
Nice choice choosing to upgrade to 3.7! What was the original fault in the end?
2011 Cayenne
718 Cayman GTS
Paynewright
What did they find was wrong?
Ian
cossiemike
PostPosted: Thu Dec 20, 2018 9:35 pm    Post subject: Reply with quote
Hi,it had run a big end,buggered the rod & crank. We decided to let Hartech have the pleasure of rebuilding it. Steve is used to Cossie turbos & M3's.He will refit the engine etc & get it running. Will let you know how it goes. Mike.
Goto page Previous  1, 2, 3, 4  Next
Page 3 of 4
