997 : 2004- 76
996 : 1997-2005 34
Boxster : 1997- 21
Cayman : 2005- 15
Cayenne : 2003- 3
Sutton
PostPosted: Tue Nov 06, 2018 11:26 am    Post subject: Reply with quote
This is a fantastic thread. I doff my hat to you!
Do you happen to know how much the engine lid and ancillaries (spoiler, motor etc) weigh? Thanks.
1994 993 C4
Millomboy
1997 Porsche 993 Targa
PostPosted: Tue Nov 06, 2018 6:30 pm    Post subject: Reply with quote
Just sent you a Whatsapp from a service manual. If that doesn't help, a grown up will be along shortly, I'm sure.
ATB
Ian
Ocean blue targa.
The only true freedom, is freedom from the heart's desires. And the only true happiness, this way lies.
ehcsrop
PostPosted: Tue Nov 06, 2018 10:28 pm    Post subject: Reply with quote
Have you fitted new CATs or are they original 400cell units ?
PostPosted: Wed Nov 07, 2018 2:19 am    Post subject: Reply with quote
Floor
Cameltoe & Heel
PostPosted: Wed Nov 07, 2018 9:22 am    Post subject: Reply with quote
They're original 400cel cats, I may upgrade to 200cel at some point Smile
Trev
Endoman
PostPosted: Wed Nov 07, 2018 9:54 am    Post subject: Reply with quote
Do you mean the olives Trev?
Depends whether they are Bishcoff or Gillet, can't remember which way round it is one uses them the other doesn't
A bit like Round heads and Cavaliers.
They are interchangeable apart from header/cat flange.
Cameltoe & Heel
PostPosted: Wed Nov 07, 2018 10:43 am    Post subject: Reply with quote
That's them John, I have two that I obviously took from the car when dismantling however I cannot fathom where they're used in my new set-up. I'm running Gillet mufflers and tips.
I've dug up this thread from a while back that appears to discuss a similar topic:
http://www.911uk.com/viewtopic.php?t=113473&sid=2c4a6dff90ccb151f1ed50194f723fb4
It suggests that I don't need the olives as the Gillets already have that built into them. That would make sense from what I'm seeing whilst building it up however I'm confused as to where they were used on my car in the past, I've replaced like for like so confused.com:?:
Trev
Endoman
PostPosted: Wed Nov 07, 2018 1:42 pm    Post subject: Reply with quote
Pretty good thread that one. Perhaps the new RSRs are Gillet and the old were Bischoff. When I sent Gert my old old Bischoffs he sent me Gillets back a minor weight saving but it all counts. I loved my old RSRs but a tail pipe fell off and melted rear pu with the hot exhaust gases, an expensive trip.
The tone of the Fabspeed cans currently fitted is a lot deeper the the RSRs and slightly louder, interestingly no provision for heat shields.
tyinsky
1997 Porsche 993 Carrera 2S
PostPosted: Wed Nov 07, 2018 6:48 pm    Post subject: Reply with quote
This looks amazing. Like a new car, possibly better!!!
tyinsky
PostPosted: Wed Nov 07, 2018 6:51 pm    Post subject: Reply with quote
Cameltoe & Heel wrote:
Millomboy wrote:
Brilliant Trev. Do you post on Instagram?
I do indeed so if anyone would like to follow, I'm at: Juansheeet
I'll try pst a few more there too.
Trev
Just found some great stuff searching 'cameltoe' looking for this Grin
Cameltoe & Heel
PostPosted: Wed Nov 14, 2018 8:49 am    Post subject: Reply with quote
Managed to fit the Golden rod and RS SSK now after purchasing new shims for the mechanism below, shift does feel great, sat in the garage it does anyways Smile
Bought a new bonnet badge and Targa logo for rear, mostly because everything else was new but I'm glad I did the bonnet badge has seen better days, I did wonder if there was anyone out there that could revive it?.
Also had a bunch of bits zinc plated to help bring up the engine bay, used Karas in Leigh, they did a great job:
Here are the pulleys installed:
This is going to Jack at Royals for a refurb:
Trev
Endoman
PostPosted: Wed Nov 14, 2018 9:42 am    Post subject: Reply with quote
I'm collecting a few bits for replating those look good and on my doorstep.
May I recommend 91160312701 for the altenator nut.
Have you considered a black wheel with blue piping?
 Filesize:  26.92 KB
 Viewed:  1650 Time(s)
ch3tman
1995 Porsche 911
PostPosted: Wed Nov 28, 2018 6:33 pm    Post subject: Reply with quote
^ that! Such impressive work thumbsup
Photos | instagram.com/ch3tman
For Sale | OEM 17" Cup II Wheels + Tyres
Cameltoe & Heel
PostPosted: Thu Nov 29, 2018 9:37 pm    Post subject: Reply with quote
So I've moved to the front of the car now which to be honest is a little frustrating in that it was nice to deal with all the new stuff at the rear to now come to the front and be faced with dirt and grime again.
I had some slight damage on the offside front to the Oil cooler hanger and strut so these will be replaced. Oil cooler fan resister was shot:
Promptly replaced:
As you can see it's all pretty grimey in there and oddly enough I seem to have a wheel hub stud that is a 45mm and the others are all 52, I think someone has replaced one with the wrong spec bolt, naughty, so that will have to be pressed out of the carrier. The cups that the spring sits in were pretty rusty so I've given them a good wire brushing a painted them.
Pulling the kit together for coiler build, problem is the top nut requires a 22mm spanner that is super deep to reach within the mount, it has to be a spanner as you require an alan down the centre to hold the strut itself from turning, argh!!:
Luckily when i checked the front wishbone bushes they had been replaced with Superpro poly items so i'm going to leave these in place, I've removed the ball joints as they were super rusty, new ones on the way.
They look a bit better now:
Weekend should see me building up the offside front once I've been and emptied my wallet at OPC Bolton, again!!.
Trev
Cameltoe & Heel
PostPosted: Mon Jan 07, 2019 8:52 am    Post subject: Reply with quote
Guys a quick update, I managed to fire up the 993 at weekend, what a moment after 4 yrs of inactivity, with pretty much everything done to it short of a rebuild I guess I should expect it to be good but you just never know. I hadn't heard the car running when I bought it so such a huge relief.
The RSR's sound so soooooo good, I had a few false starts as my keyfob would not work even with a brand new battery, after a bit of investigation it turns out there was a dry joint in there, quick insertion of a jumper wire soon sorted that.
Post that, the immobiliser would turn off nicely however the car seemed to just try to turn over but couldn't, several attempts and no, then all of a sudden it bust into life, however for some unknown reason the alternator shaft was stuck solid and essentially the crank pulley destroyed the belt. Not sure why the alternator stuck solid as I disassembled the pulley and put it back on and it was fine Dont know , I was thinking there was an issue with alternator or something, quite strange, suffice to say a new alternator belt is required.
Other than that she purred like a kitten, no smoke no nothing, sounds fantastic, a couple of sticky tappits initially but soon quietened down.
All in all a result so far
thumbsup
Trev
PostPosted: Mon Jan 07, 2019 9:52 am    Post subject: Reply with quote
Have you done the bearing on the alternator shaft? Common issue especially if there is movement in the fan blade axis what
Cameltoe & Heel
PostPosted: Mon Jan 07, 2019 2:07 pm    Post subject: Reply with quote
Zingers absolutely replaced and smooth as silk.
I'm wondering if somehow I got the spacer wrong between the pulleys Question
Trev
Jet Jock
PostPosted: Mon Jan 07, 2019 8:47 pm    Post subject: Reply with quote
Great work Trev. Dropping the SSK and Golden Rod to my Indy tomorrow. Engine out on table at the min replacing all the usual stuff for a 100k miler. Your thread has got me excited again.
Baz
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, FD Motorsport SSK and Golden Rod, MPL Clutch Slave Cylinder, HID conversion...
instagram.com/bazzer_a
Endoman
PostPosted: Mon Jan 07, 2019 9:19 pm    Post subject: Reply with quote
Baz
That's how mine started and then grew Very Happy
Are you coming across for the Oulton Park Porsche track day with the rest of the Dublin crew?
Jet Jock
PostPosted: Mon Jan 07, 2019 9:40 pm    Post subject: Reply with quote
Endoman wrote:
Baz
I sure am. My 10th year(give or take a child being born, the nerve of him to be born March 10th Dont know ) Are you?
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Page 5 of 6
