***Non-Turbo 996 owners - Please read - IMS DATA REQUIRED***
date inputted: 18/6/18
member: rdodger
model: 996.2 C2
engine size: 3.6
purchase date: 03/05/18
date registered: 01/05/2004
mileage (at purchase):68,214
mileage (now): 68,746
bearing (orig./replacement): Original
failure data (if applicable):N/A
comment: Seal removed at 68,214
date inputted: 22/6/18
member: stotty
model: 996 C2
engine size: 3.4
purchase date: 01/04/08
date registered: 01/01/00
mileage (at purchase):57,000
mileage (now): 169,000
comment: Bearing checked when RMS replaced Feb '18. Seal has gone, but bearing well lubricated and showing no outward signs of failure. Discussed option with Indy and decided to leave well alone.
Date inputted 23/6/2018
Member Nytol
Model C2
Engine 3.4
Date purchased Summer 2012
Year 1999
Mileage at purchase 92k
Current mileage 125k
Bearing original
No failure
date inputted: 30/06/2018
member: moodytunes
model: 996.1 C4
engine size: 3.4
purchase date: 10/2016
date registered: 14/01/2000
mileage (at purchase): 83,693
mileage (now): 89,000
failure data (if applicable): N/A
comment: No issues to date
date inputted: 2/7/18
member: sbhassall
model: 9961 C2
engine size: 3.4
purchase date: 24/6/18
date registered: 1/6/2001
mileage (at purchase): 109300
mileage (now): 109485
comment: RMS and clutch changed at 94,000 miles by Cath Burrows,IMS not changed
IMS failure 1998 C4
Hi l was reading the update on IMS failures and thought I should share my experience in November last year..
I had bought the car a year earlier and had gone thro a mixed experience with specialists including one listening to the bearing with a stethoscope and it seemed fine. In November I took it to the same specialist and asked them to cut open the oil filter when they changed the oil. Shiny bits of metal in the filter and I posted on here at the time . I got three specialists to respond the one above said go and run it for 1000 miles and check again , one said don't run the car again until the bearing is changed the last said drive it to us , about 130 miles , but no more.
I used the last one and when they took the engine out the bearing was so degenerated they reckoned it would have failed in 10 miles. The sump had bits of broken bearing in it.
So at 70000 they bearing failed.
The car had had very limited use for 4 years before I bought it at 62000 miles and while the low mileage was attractive the downside may well have been the effect of this on the bearing.
So these cars do still fail from this potentially defective component.
...mine collapsed at 69k miles...no warning... dwarf and bearing debris found throughout the engine when stripped down...
Can you post your full details up then:
date inputted:
member:
model:
engine size:
purchase date:
date registered:
mileage (now):
comment:
date inputted: 20/11/18
member: 996 Simon
model: 9961 C2
engine size: 3.4
purchase date: June 2014
date registered: March 1998
mileage (at purchase): 80,000
mileage (now): 108529
bearing (orig./replacement): Original (nothing in the service history)
comment:
:thumbs:
I'll try and get my spreadsheet updated over the weekend. Well over 100 cars now.
date inputted: 1 Dec 2018
member: Griffter
model: 996.1 C4
engine size: 3400
purchase date: Oct 2015
date registered: April 2001
mileage (at purchase): 42000
mileage (now): 48000
bearing (orig./replacement): original as far as I know
comment: squeaky clean underneath
date inputted: 2/12/18
member:SaintsPaul
model:996.1 C2
engine size: 3.4
purchase date: 17/11/18
date registered: 8/3/00
mileage (at purchase):76,000
mileage (now): 85,550
bearing (orig./replacement):eek:riginal
comment: A bit late to the party but thought I should add my data. Gearbox rebuilt in the summer so had bearing checked. Original bearing in great condition and I had the dust shield removed on the bearing.
124,562
1,441,538
48,977
GT3161
