997 : 2004- 76
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
naikam
PostPosted: Thu Apr 19, 2012 9:52 pm    Post subject: Wet door carpets Reply with quote
Last year I noticed the carpet on the bottom of both doors on my 997 cab were soaking wet after a rainstorm, I took it to a independant porsche specialist who told me it was a common problem,and said silicone sealant was the answer and it was for 6 months but now it is happening again,has this happened to anybody else.[/img]
GT4
Nordschleife
Nordschleife
PostPosted: Thu Apr 19, 2012 9:55 pm    Post subject: Reply with quote
Very common problem (especially if the car lives outside or is used in the rain, road debris gets washed down the drain holes and blocks them, then the next time it rains the drain holes overflow and water gets in the car).
Rod your drain holes (or rather, get OPC to)
Door membranes:
Not a 996 or 997, but this is basically what the membrane is/does:
Do this when any debris may be soft and moist (ie after extended rain, or at a pinch after a decent washing drench).
Use an airline to blow clear, or old springy type plastic coated curtain "rod" (net-curtain wire) - you want it firm enough to push, but flexible enough to go round radii and not puncture the drain tubes with sharp edges:
(remove the hook or eyes!!)
alpinaman
PostPosted: Fri Apr 20, 2012 7:11 am    Post subject: Reply with quote
GT4..
How do you gain access to top of rear drain channel and tube,is it under the roof cover..?
GT4
Nordschleife
Nordschleife
PostPosted: Fri Apr 20, 2012 7:40 am    Post subject: Reply with quote
According to Porsche, access is from the bottom (unless you have a sunroof).
kevtina
PostPosted: Mon May 14, 2012 6:58 pm    Post subject: Drain tubes cabrio Reply with quote
Hi GT4 Do you know how to access drain tubes on 996 Cabrio With soft top half way down can't see them. thumbsup
911 996 1998 Cabrio Tiptronic
Trek Touring Bike
2001 Renault Clio
1984 Metro Turbo
Various Minis
GT4
Nordschleife
Nordschleife
PostPosted: Mon May 14, 2012 7:17 pm    Post subject: Reply with quote
Only what is on the diagrams.
You may have easier access via the lower exits rather than top side.
martutd
PostPosted: Tue May 15, 2012 1:27 pm    Post subject: Reply with quote
have a look at this previous post, it may help
http://911uk.com/viewtopic.php?t=49406
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Tue May 15, 2012 2:30 pm    Post subject: Re: Drain tubes cabrio Reply with quote
They are there. Just gently pour a jug of water with your roof half up and you will see where it flows too.
It then goes into a collector not far from your rear speakers, and from there will either overflow onto your carpet or drain behind the wheel arch, depending on whether your drain is blocked or not.
It'll be the lower part that is blocked.
GT4
Nordschleife
Nordschleife
PostPosted: Sat May 19, 2012 1:05 pm    Post subject: Reply with quote
Just to clarify, the positions of some of the drain holes are behind the wheel arch liner.
This is illustrated in the diagrams and the photo of the wheel arch (!) earlier in the thread.
The exits you need to clear look like grommets.
slaav
PostPosted: Sun Dec 30, 2012 4:28 pm    Post subject: Wet rear footwell! (AGAIN) Reply with quote
Having read (mainly) your excellent pointers on this issue, I have to clear my roof drains - presumably the ones that drain in to the rear arches?
As per: http://www.911uk.com/viewtopic.php?t=72957
I am guessing that I need to take off teh whole arch liner on side that is wet and clear the drain 'grommet' as per your piccy? HAve never done this before - something that Porsche Assist or AA would help with?
Or stick it in to OPC and ask them?
Bit of a two left thumbs chap wrt my car Smile
Thanks in advance
sam21
PostPosted: Sat Jun 16, 2018 7:47 am    Post subject: Rregarding the wet carpet Reply with quote
In every rainy season, I often observe that carpets of my car are getting wet and I am very irritated with this please suggest me some ideas to prevent it.
shabs
PostPosted: Sat Jun 16, 2018 9:21 am    Post subject: Reply with quote
Sam, it is all explained in the thread, read it from the beginning and follow the links mate.
PostPosted: Sat Jun 16, 2018 3:11 pm    Post subject: Reply with quote
If you can say what model of car you have then i can help point out the usual places .
Also which carpets are actually getting wet .
sam21
PostPosted: Wed Jun 20, 2018 6:52 am    Post subject: Re: Rregarding the wet carpet Reply with quote
sam21 wrote:
Please suggest me asap
PostPosted: Wed Jun 20, 2018 6:51 pm    Post subject: Reply with quote
Same question .. what car do you have .. coupe , with sunroof or cabriolet or Targa .. where is it getting wet .. front or rear ?
frodo12
PostPosted: Fri Nov 23, 2018 8:09 am    Post subject: Wet door carpets Reply with quote
Hello, Gt4,
Thanks for sharing car carpet images is very nice I glad you. But any situation creates a problem to contact my company. Because of My company provide carpet services so, please reply to this thread.
Thanks, again!
