997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Pickse
PostPosted: Wed Nov 14, 2018 5:10 pm    Post subject: 996 Turbo Engine Bay light Reply with quote
I was away for a few days last week and came home Saturday to a flat battery. I mean dead flat.
My jump pack wouldn't switch on cos it didn't think it was connected to a battery so I had to go borrow a battery to connect to the fuse box point to even get the frunk lid open.
The battery was so dead the Ctek would not try and charge it!
So I connected the borrowed battery in parallel and it started charging both.
I've just been out to disconnect the borrowed battery so the Ctek can continue to charge mine and as it's now quite dark I saw the engine bay light was on even tho the lid was shut.
I've taken the bulb out for now but does anyone know where the switch is?
I'd guess the lower lock half but as I say it's quite dark now and I couldn't see a switch anywhere else.
Ideas anyone?
Thanks,
Pickse
2003 Arctic Silver 996 Turbo Tiptronic S
PostPosted: Wed Nov 14, 2018 7:40 pm    Post subject: Reply with quote
Its in the boot lock .. i think you can see the switch and its probably dropped out .. new lock ass. im thinking atm .
No.7 here ..
https://www.deroure.com/diagrams.asp?MAK=3&MDL=28&TBL=3321&SMA=&SMO=0&ST=&SC=0
It should beep when you lock the car though if its this.
Pickse
PostPosted: Wed Nov 14, 2018 8:21 pm    Post subject: Reply with quote
Thanks deMort,
No beeps when I locked it so maybe it's not the lock?
Anyway I'll take a look in daylight tomorrow and see what I can see.
Thanks again,
Cheers,
Pickse
911tom
Watkins Glen
PostPosted: Wed Nov 14, 2018 8:30 pm    Post subject: Reply with quote
I believe the frunk and engine bay lights come on together so it could be the frunk is open or either switch faulty. As demort says it should beep when you lock the car if this is the case. Also the relavent light should be on on the dash when you start the engine.
If not a switch it could be a wiring fault or just the car throwing a wobbly after the battery going flat. Might be worth disconnecting the battery for 30 seconds.
2011 Cayenne
718 Cayman GTS
PostPosted: Wed Nov 14, 2018 8:35 pm    Post subject: Reply with quote
I think for now then have a look at the lock in the daylight , see if the switch is intact and if you can press it that it makes a click noise .
I would use a tester to see the alarm cu can actually see its closed ..
Atm im a little confused as to why you dont get a beep to say its open ..
Try leaveing the passenger door open then lock the car . if you dont get a beep then .. then we are into a horn / siren fault .
This wont work with the drivers door .... it wont lock .
Tom made a good point .. it could be the front bonnet switch .. but again you should get a beep on locking .
Pickse
PostPosted: Wed Nov 14, 2018 8:48 pm    Post subject: Reply with quote
Thanks Tom, The Frunk was open so it's possible that was the cause. Having had a completely dead battery I'd assumed the rear light being on was a fault?
Thanks again deMort, I'll check again in daylight.
I have a durametric if needed to see what the cu sees.
Cheers,
Pickse
Paynewright
PostPosted: Thu Nov 15, 2018 8:16 am    Post subject: Reply with quote
Slight thread hijack...
Do all 996’s have an engine bay light? Don’t recall seeing one in my 996.2 C2?
Ian
Pickse
PostPosted: Thu Nov 15, 2018 9:02 pm    Post subject: Reply with quote
911Tom is spot on here, with the frunk open the engine bay light is on with the lid closed. But not vice versa.
Curious behaviour but it now means I did not find the cause of my dead battery Damn
At least I don't need a new lock c.£150 ouch.
Pickse
