997 : 2004- 76
Early 911 : 1964-1977 2
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 3
Steff
PostPosted: Thu May 10, 2018 9:20 am    Post subject: horn sounding on its own Reply with quote
Hi All,
While at work on Monday I got a call from reception saying that my alarm was going off.
I went out and all was silent, no indicator flashing so just unlocked, locked and went back to my desk.
No one at work would no it was mine (daily driver is a company volvo) except for one engineering colleague (who also happens to have a 930 turbo in his garage awaiting restoration) so I messaged him.
He said it didn't sound like a normal alarm sound, more like the horn sounding intermittently over a short period and then sounding continuously for a while before going silent.
Since having the car I have always felt the horn is a bit sensitive, being easy to make it sound unintentionally.
I looked at the fuse with the intention of just removing it for now to ensure it didn't happen again and found the fuse wire broken. I put the spare fuse in and couldn't make the horn sound.
It had an MOT a few weeks ago so can only assume it worked then.
So, whats happened? is there some sort of dodgy connection causing the horn to sound randomly and then the continuous sounding has caused the fuse to blow? if so, I'm guessing I just need a new horn unit, any suggestions for the dodgy connection?
many thanks
Steff
PostPosted: Thu May 10, 2018 9:49 am    Post subject: Reply with quote
Your alarm also has a separate horn. Maybe it was that going off.
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu May 10, 2018 10:09 am    Post subject: Reply with quote
common problem with the 4 spoke wheel fitted to early 996
https://rennlist.com/forums/996-forum/485918-horn-problem.html
https://www.renntech.org/forums/topic/1728-horn-problem/?tab=comments#comment-11274
check these bushes and the horn relay and fuse
try hooking the horn directly to 12v to see if its blown, they do rust away
the alarm is a siren rather than horn, well my my99 is anyway
PostPosted: Thu May 10, 2018 10:14 am    Post subject: Reply with quote
The alarm has a siren and a horn. Alarm your car with the boot or centre glovebox open and you'll hear it beep.
Steff
PostPosted: Thu May 10, 2018 12:53 pm    Post subject: Reply with quote
ok cool. thanks both
IanG1
PostPosted: Thu May 10, 2018 5:22 pm    Post subject: Reply with quote
It's the steering wheel, mine started doing the same while stood on the tipec area at last week's Donington Historic. Also does it under hard braking.
stucart
PostPosted: Thu May 10, 2018 6:56 pm    Post subject: Reply with quote
I had a similar fault but on my 997, horn went off on its own in the middle of the night! When got to it it had stopped? After that the horn wouldn’t work at all, took it OPC and initially it baffled them, they replaced both horns and that cured it. Hope that might be of some use perhaps.
ps. The car only had one horn working prior to this, that had been picked up at its last service but I hadn’t got around to booking it it as it was sorned over winter, the lone horn worked till it went off on its own then the above.
Now - Jaguar F-Type 2014 3.0 S Quickshift ,White/ Red interior (theme here!) Loving it .
Previously - 997 C4S Tip-S, 2007, Silver/Red and Black Leather, PSE, Sports Chrono, Turbo wheels.
PostPosted: Thu May 10, 2018 7:46 pm    Post subject: Reply with quote
Do me a favour .. check under the passenger seat ... make sure theres no water bottles or that its wet under there .. if all good then perhaps the horn . steering wheel contact.
My reason ..
The alarm horn beeps and will do in an alarm trigger which fits the description .. the siren should go off but didnt hence im wondering water ingress to the alarm control unit .
It has a horn and a siren for the UK only markets .. horn is fitted to the o/s of the battery and on the brake servo bracket ... its for the CAT rateing at the time .
Steff
PostPosted: Fri May 11, 2018 10:43 am    Post subject: Reply with quote
Thanks all,
Will check for water ingress but pretty sure its ok and having now read up on the contacts/steering wheel issue it sounds very likely that's it.
searider
PostPosted: Fri Jul 27, 2018 9:43 am    Post subject: Reply with quote
Right chaps,
I had this problem. Call from work to say that the horn had been going off all on its own and then stopped.
I did the washer repair on the airbag frame last night and replaced the frame, which had blown.
Still no horn.
The instrument displays dim a little when I press the steering wheel - so there's a load being taken somewhere.
Where does the horn relay live - that's my next thing to check.
Usual progression - 205 1.9 / Corrado VR6 / Audi B5 S4 / RS4 / 996 C2 Coupe.
PostPosted: Fri Jul 27, 2018 7:01 pm    Post subject: Reply with quote
I guessed at a 2002 model and the wiring diagrams are below.
Relay board is o/s/f and above the fuse board .
GP2 .. or any GP on a wiring diagram is an earth point with the number as the location .. an earth basically .
Brown wire.
 Filesize:  325.76 KB
 Viewed:  1544 Time(s)
 Filesize:  206.47 KB
easttorks964cab
PostPosted: Sat Jul 28, 2018 2:57 pm    Post subject: Reply with quote
may I throw my two-penneth in? I had a similar problem with mine. The horn would sound under braking and also if you put any slight pressure on the horn. This was much worse in hot weather. It turned out to be the airbag bracket. This has a couple of rubber bushes on it, that you are pressing against when you push the horn. These become worn and, in hot weather, soft, so there is less resistance against the horn.
Its is a cheap part and quick fix. Its worth considering.
hope this either helps the OP, or someone else with similar problems.
Thomp1983
PostPosted: Sat Jul 28, 2018 7:37 pm    Post subject: Reply with quote
If it's the black standard 4 spoke wheel you've got I've got a known working one under the bed you can have including airbag
searider
PostPosted: Sat Jul 28, 2018 9:27 pm    Post subject: Reply with quote
Brown wire.
Thanks, mines a 1998, I’ll have a look.
I assume that if I can hear the relay clicking it’s ok?
searider
PostPosted: Sun Jul 29, 2018 11:59 am    Post subject: Reply with quote
PM sent re wheel.
PostPosted: Tue Jul 31, 2018 7:39 pm    Post subject: Reply with quote
Brown wire.
Erm .. no .
It may click but if the contacts inside the relay are burnt it wont make the connection between 30 and 87 .
You should have 12 volts on term 86 with the earth on 85 only there with the horn pressed .
term 30 will be 12 volts with term 87 being the output to the horn .. if you bridge term 30 and 87 with a bit of wire then the horn should work ..
searider
PostPosted: Tue Nov 13, 2018 2:36 pm    Post subject: Reply with quote
Brown wire.
Erm .. no .
Thanks all,
To close this out I changed the relay which made no difference.
Two new horns and the problem is sorted.
Duncan
