997 : 2004- 74
996 : 1997-2005 29
Early 911 : 1964-1977 2
Boxster : 1997- 14
Cayman : 2005- 16
APL911
PostPosted: Sat Nov 10, 2018 1:45 pm    Post subject: Hello warning. Coolant system fault. Reply with quote
I’ve booked my 991.1 c2 in at brooklands on Wednesday.
I’ve got a yellow message “coolant system fault, take to garage”.
After a quick search I can see a few common(ish) faults ranging from a split vac hose to faulty control switches. Not sure how much it’s going to cost yet.
Any obvious checks I can do before taking it in? Question
Cheers.
APL911
PostPosted: Sat Nov 10, 2018 2:42 pm    Post subject: Re: Yellow warning. Coolant system fault. Reply with quote
delete
PostPosted: Sat Nov 10, 2018 3:15 pm    Post subject: Reply with quote
Nothing obvious you can check im afraid .. it will be a vacumn pipe or one of the 8 valves that has failed ( depending on spec ) .
There was a recall on this years ago .. then there was a recall on the recall lol .
markz86
PostPosted: Sat Nov 10, 2018 3:49 pm    Post subject: Reply with quote
I had the same daily on my 991.1 C2 6 months ago. It was one of the solonoid valves as suggested above (£20 Part) so it should be a quick / straightforward fix.
Current:
991.1 C2 Manual - Basalt Black
957 GTS - Basalt Black
Previous:
997.2 C2 Manual - Arctic Silver
997.2 C2 Manual - Basalt Black
997.2 C2 Manual - Guards Red
blackram
PostPosted: Mon Nov 12, 2018 9:51 am    Post subject: Reply with quote
If it is the changeover valve, as mine was, ask to see the faulty part and see how heat damaged it is. Mine had partially melted which was a concern.
991.1 Carrera S Agate Grey
