996 : 1997-2005 29
Boxster : 1997- 17
Cayman : 2005- 20
NickHappy
PostPosted: Thu Oct 18, 2018 7:43 pm    Post subject: Roof Rail Rubber Replacement Reply with quote
My roof rail rubber is bothering me as previous owners have polished over it and it not looking it’s best with Polish staining etc. I’ve done some investigation as per the below and it looks like a real faff to replace it. Has anybody carried out a DIY to do this? Was it as much of a hassle as it looks or a lot easier.
https://rennlist.com/forums/attachments/997-forum/927641d1428891563-roof-line-rubber-collapse-66-36-19-removing-and-installing-roof-joint-strip-as-of-my-2005.pdf
Alternatively; any ideas on getting the rubber looking good again?
NH
997 turbo Manual.
996 turbo Manual. ex.
v6matt
PostPosted: Thu Oct 18, 2018 8:18 pm    Post subject: Reply with quote
With this sort of thing, just use water on a cloth and add a little car shampoo to rub away the polish.
Then apply something like Autoglym Bumper car to bring the colour back
2008 Carrera 4 - Gen 1 997
TonyC911
PostPosted: Fri Oct 19, 2018 6:38 pm    Post subject: Reply with quote
I would remove the roof rail cover which is straightforward. It will give you the best access to manipulate the rubber and allow you to clean the rail of any polish that has embedded itself between the two surfaces.
To clean the rubber I would recommend two products. A stationery type white rubber / eraser works really well on removing white polish residue from black plastic trim, then you can treat it with a good quality rubber / plastic conditioner. I really like using CarPro Perl on my cars trim, as it can be diluted if necessary and does not leave a really high shine, but a more of a matt black. I also use it at a tyre dressing!
https://www.ebay.co.uk/itm/Carpro-PERL-WATERBASED-SILICON-OXIDE-COAT-500ml/162932373129
Good luck!
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
