997 alarm issues
NLW73
27 May 2014
1,714
Just got a 2005 c2s
Alarm keeps going off at night. Any ideas?
It's not windy
Nothing left in there like a phone
Glove box is closer as are the side bins
Drove it today so it's not been sat around either
Any ideas welcome.
Tried plugging a Ctek charger into it :dont know:
May have one for sale if needed :grin:
Interior alarm motion sensor p/n: 997.618.210.01
When locking the car, double click the button, this will disable the interior alarm (check for a couple of days) if the alarm stops going off, then this is the part that will be faulty. It is located inside the centre console (near handbrake).
I bet I am right!!
Mine continued to play up on even on a trickle charger.
Solution so far was a new Alarm Siren module
For mine the part number is 1J0951605A and if you type it into eBay you can buy a new one that fits the Fabia cheaper than a Porsche part :)
Phil
There are several things that can cause it with the above comments being the main ones .
I would add .. make sure there are no coins or anything metalic in the center consol ash tray .. these reflect the signal from the interior sensor as its under there and trigger the alarm .
For me then i would use a tester and look for fault codes first .. then i would look at the list Saying what has triggered the alarm for the last 10 times .
We can see what triggered it and also what faults were there when it was locked ... its called Event memory and Activation memory .
I had a problem with the alarm going off at random times in my '07 Targa 4. Turned out to be a foil biscuit wrapper lodged up against the control unit under the passenger seat. Removed it and the alarm returned to normal and has been fine for the two years since.
Also check that the floor and carpet under the passenger seat are not damp; affects / knackers the control unit.
Thanks all
Nothing in the console but I did have some chewing gum in wrapper in the gap under the centre console
It has foil on it so am guessing that was reflecting sth and confusing the sensor.
Two nights of sleep not disturbed
124,598
1,441,975
49,034
briant1000
