996 : 1997-2005 33
Boxster : 1997- 18
Cayman : 2005- 17
Ruda
PostPosted: Tue Sep 11, 2018 1:07 pm    Post subject: Wiper Problem Reply with quote
Hi All
I have a 2010 Cayman 3.4S and it has developed a little problem with the wipers. Intermittent/auto works perfectly, as does the 1st and 2nd speed but unfortunately, the wipers are now coming to rest at the vertical instead of the horizontal an anyone point me in the right direction to get it to rest at the bottom as it used to ?
Thanks in advance
Ruda
mangobay
PostPosted: Tue Sep 11, 2018 5:24 pm    Post subject: Reply with quote
Have you checked the manual, as I seem to remember there is a setting which enables you to position the wipers in the 'up' position for blade changing purposes? there is a button press sequence to reverse it.
May be wrong...may be remembering some other car.
991.2 GT3 manual
ex GT4
ex 997.1 Turbo manual cab
ex 997.2 C2S
PostPosted: Tue Sep 11, 2018 6:41 pm    Post subject: Reply with quote
Not something ive ever seen before ..
I take it what ever you use .. intermitant , 1 or 2 speed it always parks vertically ?
Has anyone worked on the car that might have caused this .. ie wiper mechanism removed ?
My only guess is the wiper motor is connected 180 degrees out on the arm .. but someone would have had to do this .. if the arm goes loose it will just flop about or not work .
If the wiper arms are loose again they will be all over the place .
It feels more mechanical rather than electrical to me .
Ruda
PostPosted: Tue Sep 11, 2018 7:30 pm    Post subject: Reply with quote
Thanks. I will definitely have a look.
Ruda
PostPosted: Tue Sep 11, 2018 7:33 pm    Post subject: Reply with quote
No they were working perfectly on a trip to the Nurburgring this weekend and then decided to start "resting" in the vertical on auto. they were still working perfectly in every mode but all speeds but just rested at the vertical. Had to take the passenger side one off as a result.
Steve
Ruda
PostPosted: Tue Sep 11, 2018 7:44 pm    Post subject: Reply with quote
This seems to be for cars who's wipers can't be lifted clear of the bonnet. Some VW's for instance.
Thanks anyway Mangobay
