Oil cooler fan
MarkGolf
Sao Paulo
13 Nov 2012
930
Hi all,
When should my oil cooler fan kick in?
It struck me this morning that I have never heard a fan noise from the front of the car, so I am going to assume I don't get hot enough or it's dead.
Short of pulling the arch liner off and stick 12v to the motor, I was hoping someone can let me know when it should turn on.
Also, a few months ago, I saw a 964 for sale which said it had an LED indicator which would light up when the fan came on, is this something someone sells?
Although I'm sure that's easy enough to DIY.
Cheers!
https://p-car.com/diy/fan/
Quick check is to jumper contacts at the relay to see if the low/high speed works. If low speed doesn't work it is usually the balast resistor gone bad. In my case it was a fault with the CCU. I installed a manual bypass which keeps the temps down earlier than it would normally.
Hi
Ours cuts in quite regularly in traffic during this warm weather - now that I've changed the ballast resistor :D I also changed the relay too when I changed all of them 2 years ago figuring that I didn't know how old they were and better to be safe than sorry
Standing by the front wing, the fan is pretty quiet but pushes a huge amount of hot air through the rad when it is on so there is no mistake when it's working - plus of course the temp guage quickly drops
Ours cuts in just over the 9 o'clock position
HTH
Had my car MOT'ed yesterday got it good and warm on the way. Whilst it was ticking over waiting for the emessions test the fan was cycling on and off. As stated earlier my kicks in when the oil temp is at 9:00 oclock. During normal running I have never had it kick in but it's very quite so probaly wouldn't hear it.
Trev
124,598
1,441,975
49,034
briant1000
