997 : 2004- 66
Boxster : 1997- 31
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Jun 21, 2018 7:06 am    Post subject: Sports seats, change foam and paint backs, how to... Reply with quote
I had wanted some body coloured hard back heated sports seats for some time, but hadn’t found any. So I did the next most obvious thing I bought some non-heated ones stripped them down, change the foams to heated ones, and had the backs painted. I spent a bit of time looking for good online details on how to do this, but didn’t find a lot of information. So here is what I did.
With the seats out of the car go to the back of the seat and lever off the short plastic clips on either side.
Then remove the long section down the middle, this holds the bottom of the centre pad in place.
The centre pad can now be removed, this is clipped on at the top so needs lifting upwards from the bottom, these two photos show the top clip and the wire it attaches to.
If your seats have extra strap on the sides of them which is held on with a press-stud, this must be unscrewed.
Then, starting from the bottom at the back, lever out the leather from the gap around the rear edge, work around the seat to remove it all.
When all of the outer has been removed, move to the inside of the seat back and release the clips which hold the inner part of the rear leather in place.
The rear leather can now be removed. Remove the foam as well, it will be stuck around the edges but comes off easily enough.
I removed the backs from mine completely, before deciding it would be better to paint them in place and replacing them, this is how the backs are removed.
Undo the inside screws, the plastic these attach to is designed to hinge to make removal easier.
Remove the tilt release handles, these just pull out.
The back is clipped in place around the top and the sides.
It will need to be pulled out to clear the levers
Your seat should now look something like this.
To remove the base, pull out the height adjustment handle from the side cover and remove the two screws, the plate can now be removed.
Underneath the seat, remove the centre from the white holders and unclip them.
The base will now lift up, it will need to be pulled outwards at the sides to cover the part where the lever attaches.
The plastic side cover can be removed by pulling out the centre pin.
I then cleaned up the base, clearly had had a dog in the car, it was a bit of a mess.
Those are the main components of the seat removed now. The base and the rear centre pad then need dismantling to change the foams.
MisterCorn
PostPosted: Thu Jun 21, 2018 7:07 am    Post subject: Reply with quote
The rear pad consists of three parts, a plastic backing piece, the leather section, and the foam.
The leather is clipped in all around the outside of the foam, these are all unclipped.
Then the hog rings which are used to hold the leather to the plastic backing piece are removed.
I had to buy a pair of hog ring pliers to do the job for putting these back together.
To pull the leather section through the foam section for reassembly I put a length of wire through the gap and pulled it through, then clipped with the hog rings, this was pretty straightforwards. The new foam is somewhat thicker.
The plastic is placed on the foam, then starting at one end refit the rings.
MisterCorn
The base section was by far the hardest to deal with.
The leather is clipped and stapled around the edge, this is removed all the way around.
The foam section is held in to the base by small white plastic clips which go through the base, shown here
These are removed by carefully squeezing them with pliers and pushing them through. The foam can then be removed from the base.
On my base the brown mesh material was broken so that was replaced with a new one from Porsche.
On the foams I removed from my car, the leather in the base was held to the foam using hog rings which attach to wire rods running through the foam
These were easily removed to separate the two parts.
The new foam didn’t have these rods, instead the two parts are held together with plastic clips which go through the foam, as seen here.
You can also see some red wire here, this is going through the white clips which need pulling through in to the base. With the foam attached to the leather the foam is then put back on the base. The white clips are an absolute sod to get in, I put wire through all of them to pull them through the gaps, and with much heaving and pushing and many snapped pieces of wire I got them all in place
The leather is then clipped back in place all the way around the base.
With the seats all stripped I had the backs painted. I didn’t want the map pocked so I had the fixings for that removed and filled to give a smoother look to the back of the seat. When that was finished it all went back together.
MisterCorn
PostPosted: Thu Jun 21, 2018 7:08 am    Post subject: Reply with quote
First thing when putting it back together is the side plastic piece. Forget this and you will be removing the base again to fit it.
The centre section of the rear leather is then clipped back in place.
The foam then fitted around it.
The leather is clipped in all the way around the back. I found it easiest to start at the top. Some clips had come out with the leather, these were removed and pushed back in to the back before proceeding. The bottom part at the rear is then clipped back on.
The centre section can then be clipped back in, being careful with the routing of the cable. The bottom of the centre section is pushed back in to place. I helped this in to place with a trim removal tool.
The base is then refitted, again being careful not to trap the cables at the back. The screws and height lever are refitted. Finally the rear tilt levers are pushed back in place.
I noticed when fitting the seats to the car that the wiring for the heated seats is not the same as in the car, so either I am missing a piece or I need to modify it, a job to do before the winter.
Martin996RSR
PostPosted: Thu Jun 21, 2018 7:12 am    Post subject: Reply with quote
*****, I wish i'd known you were after a pair of these. I have a pair of heated sports hardbacks in my car that I'm thinking of selling to offset an upgrade to buckets.
Thanks for the 'how to' though, it's stuff like that that really helps the forum.
MisterCorn
PostPosted: Thu Jun 21, 2018 7:16 am    Post subject: Reply with quote
When I did see them for sale, the colour combination was wrong, despite metropole with arctic silver being pretty popular. If you have a pair of black ones in Polar Silver I might still be interested. I bought these at the end of last year, it has taken me until yesterday to finish the job off.
coullstar
PostPosted: Thu Jun 21, 2018 7:40 am    Post subject: Reply with quote
Would love to do this but my youngest is at the right height and age that he knocks lumps put of seat back at the moment.
Good guide.
Martin996RSR
PostPosted: Thu Jun 21, 2018 8:09 am    Post subject: Reply with quote
Yep, mine are polar silver and black leather. Condition wise, they're a little tired. The driver's seat could do with a little leather care and there are some scratches in the paint on the backs.
PostPosted: Thu Jun 21, 2018 8:14 am    Post subject: Reply with quote
EXCELLENT work worship
One of my 'to do's' Thumb
ragpicker
Reims
PostPosted: Thu Jun 21, 2018 9:30 am    Post subject: Reply with quote
My god man, that's superb work!
worship
77szymon
2003 Porsche 996 Carrera 4S
PostPosted: Thu Jun 21, 2018 12:42 pm    Post subject: Reply with quote
NICE Thumb
2003 Porsche 911 996 c4s
2011 Mercedes S350L
2012 Mercedes C220 cdi Estate AMG Sport Plus Pack - wife
C4-STORM
2004 Porsche 996 Carrera 4S
PostPosted: Thu Jun 21, 2018 1:22 pm    Post subject: Reply with quote
Awesome Thumb
2004 C4S Coupe 3.6 Tiptronic S ~ Basalt Black ~ Black Crested Sports Seats ~ Alcantara ~ S/R Delete ~ WEVO Engine Mounts ~ K&N Induction Filter ~ DesignTek Sports Exhausts ~ Quad Tips ~ RUF Hubcentrics ~ RUF Sports Springs ~ Paddle Shift Steering Upgrade ~ Rear Wiper Delete ~ Smoked Rear Indicators ~ Smoked 3rd Brake Light ~ Silver Dash Bar Hack™
Marky911
PostPosted: Thu Jun 21, 2018 3:19 pm    Post subject: Reply with quote
Cracking thread. worship
Your "how to" guides are superb Martin. Thanks for taking the not inconsiderable time to link photos and write it all up.
"They don't make one or I can't find one, so I'll do it myself."
Good old fashioned British ingenuity.
A huge asset to the forum and it certainly beats talking about values. Thumb
Locosaki
PostPosted: Thu Jun 21, 2018 4:22 pm    Post subject: Reply with quote
What he said, absolutely spot on mate.
Brilliant read following your posts worship
Carrera 4 MY99 with full Hartech rebuild
Kilsoj
PostPosted: Thu Jun 21, 2018 8:57 pm    Post subject: Reply with quote
Brilliant post -
just finished something similar , I want sports seats, fitted them and wasn’t happy with functionality or the condition of some parts of leather - so frankensteined the top half of sports seat with the bottom half of my comfort, very pleased with them now.
As an aside anyone know where you can buy replacement hard backs?
abcarrera
PostPosted: Thu Jun 21, 2018 9:43 pm    Post subject: Reply with quote
This is a great write up on a project well done!
Awesome step by step guide and photographs!
Did you spray the seats backs yourself or did you get a paint shop to do them for you?
Current car: 2004 996 GT3 CS
Boxster S 2015
BMW 535d Msport remapped 360 BHP 😊
Gone but not forgotten
2002 996 C2
1998 996 C2
2005 987 Boxster S
2007 997 Turbo
1990 964 C2 Cabriolet
1995 993 C2 with factory RS rep kit.
1987 911 3.2 Carrera
1982 911 SC X 2
1981 924 Turbo X 2
1991 944 Turbo, S2 & S2 Cabriolet
1981 924 Carrera GT.
MisterCorn
PostPosted: Thu Jun 21, 2018 9:49 pm    Post subject: Reply with quote
Thanks for the nice comments guys.
I didn't do the painting myself. There is a body shop next to my work who do it all for me, great prices and great work. Painting centre consoles is about my limit.
kas750
Shanghai
2006 Porsche 911
PostPosted: Thu Jun 21, 2018 10:05 pm    Post subject: Reply with quote
Well done on such a comprehensive write up Thumb
New997buyer
Banned
PostPosted: Fri Jun 22, 2018 5:20 am    Post subject: Reply with quote
Cracking work Martin. Looking forward to learning how you resolve the wiring as well. thumbsup
pzero
PostPosted: Fri Jun 22, 2018 5:51 am    Post subject: Reply with quote
+1
