991 : 2011- 18
997 : 2004- 80
996 : 1997-2005 34
Boxster : 1997- 25
Cayman : 2005- 16
PostPosted: Fri Feb 23, 2018 11:01 pm    Post subject: Reply with quote
Stuart Mackay wrote:
And now trending on Instagram Smile
https://www.instagram.com/p/BfS57tGFPWU/
That video was Cool
markturner1960
2003 Porsche 996 GT3 Mk2
PostPosted: Thu Mar 15, 2018 3:13 pm    Post subject: Reply with quote
Nice pedalling Stuart!
996 Mk2 GT3 Speed yellow
jotaking
PostPosted: Thu Mar 15, 2018 3:37 pm    Post subject: Reply with quote
The yellow wheel trims look great!
Do these protect the rims from kerbing as well?
 Filesize:  222.66 KB
 Viewed:  5849 Time(s)
Stuart Mackay
PostPosted: Fri Mar 16, 2018 1:12 am    Post subject: Reply with quote
Yes they are the self adhesive rimblades, bought on EBay for about 30 quid IIRC.
2007 Speed Yellow 997 Carrera GT3 CS
2002 Guards Red Aerokit 996.2 C4S Cabriolet
2000 Westfield Cosworth
Diggermeister
PostPosted: Fri Mar 16, 2018 8:37 am    Post subject: Reply with quote
Does look really good; they cure that awkward lack of delineation between the tyres and the black wheels.
Stuart Mackay
PostPosted: Fri Mar 16, 2018 10:26 am    Post subject: Reply with quote
I was sceptical whether the adhesive would be affected by the high temperatures that the wheels get to when on Track, so far they have done two trackdays with no signs of departure from their original position. Very Happy
PostPosted: Fri Mar 16, 2018 10:28 am    Post subject: Reply with quote
Perfect for black wheels!
You could even go for a red or white Dont know
Cool
Stuart Mackay
PostPosted: Sun Mar 18, 2018 12:37 pm    Post subject: Reply with quote
Had these parts arrive from the USA this week from Function First to upgrade the GT3 shift to all metal from the stock plastic parts. Sharkwerks sell them also, but I bought direct.
Was thinking about Cup Shift cables, but Matt at Fearnsport advised against it due to noise transmission into the cabin. Particularly so as I am already running a single mass lightweight flywheel in the car.
www.function-first.com/products/engine-trans/shift-right-solution
When installed, I will post a before and after video here to show the differences.
 Filesize:  579.69 KB
 Viewed:  5670 Time(s)
Senoj
PostPosted: Sun Mar 18, 2018 1:55 pm    Post subject: Reply with quote
Interesting shifter mod. The 2 RS shift has metal bearings and is probably a tad cheaper from the OPC. Did you look at that?
Stuart Mackay
PostPosted: Sun Mar 18, 2018 2:22 pm    Post subject: Reply with quote
Yes, I looked at the .2 shifter, but thought going all metal and not just the bushings which the .2 has, would be a more precise option.
Furthermore, the extra time to fit a full metal set up when I have the shifter and centre console all stripped out would be insignificant.
For the marginal price difference, IMO the benefits outweigh 997.2 and so the FF Shift Right was a no brainer decision for me.
Interestingly, the mod is also applicable to the 996 Cup and 997.2 shifters.
https://www.youtube.com/watch?v=zbVjQKf341U
freddie44
2007 Porsche 997 GT3
PostPosted: Mon Mar 19, 2018 1:48 pm    Post subject: Reply with quote
Cor, like this Stuart. Look forward to hearing your thoughts on it..
2007 Porsche 997.1 GT3 CS
1967 Alfa Romeo "duetto" Spyder
1972 Porsche 911 Targa 2.4E
1997 TVR Chimaera 4L V8
2010 Vespa 125
2019 Tiger "Push-bike"
Instagram for lots more pics: @London_Classica
jotaking
PostPosted: Mon Mar 19, 2018 2:47 pm    Post subject: Reply with quote
Cool
Or a set of these in yellow.
https://shop.pirelli.com/gb_en/
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Mar 19, 2018 3:10 pm    Post subject: Reply with quote
Ill be interested to read what you think of this when fitted, also the fitting process. Play in my 996 shift is annoying, but I've never liked the feel of short-shifts either.
Stuart Mackay
PostPosted: Sun May 27, 2018 3:39 pm    Post subject: Reply with quote
Just back from test driving the new Function First metal shifter kit that have just installed.
Wow, the shift has transformed from AK47 to Lee Enfield 303 quality. There is absolutely no slop in the linkages now!
The OEM shifter had slight play in the two white hard plastic bearings necessary due to manufacturing tolerances, with the alloy fore/aft bushings there is no play or lost motion whatsoever now!
The replacement alloy side yoke/lever is beautifully made (6 axis CNC machined alloy) and also fitted with ball bearing. The whole unit replaces the Porsche injection moulded plastic piece.
Everything can be adjusted to remove any slop in the shift linkages and from an engineering standpoint...a thing of beauty!
Everything fitted beautifully and the only change I made was to replace a shakeproof washer with a Belville one as I prefer these as a locking means.
Fitting the new parts took about half an hour at a leisurely pace!
The only play that I could now see is the tiniest amount of side to side in the gear lever to the original plastic yoke. the shift quality is now excellent (it was good before I must add) and any "springiness" in the shift is probably down to the clevises on the cables and backlash in the gearbox. Function First do a mod kit to improve the clevises at the gearbox end. without going the harsh Cup Cable route
Is it any better than the Porsche 997.2 GT3 unit?
To conclude, it is very comparable on price, $295 plus $30 shipping, to the Porsche 997.2 shifter (£300 I believe) the fitting time is irrelevant as you have to have the centre console out anyway and would say the centre console removal is the lion share of the work.
I didn't have to remove the original gear knob from the lever (which is a mission in itself) and,
It is all metal and not just the two bearings as on the Porsche unit.
You decide, but I would definitely go the Function First unit over the Porsche offering if I was doing it again.
 Filesize:  313.71 KB
 Viewed:  4851 Time(s)
Stuart Mackay
PostPosted: Sun May 27, 2018 3:41 pm    Post subject: Reply with quote
Underside of shifter
 Filesize:  364.19 KB
 Viewed:  4848 Time(s)
Stuart Mackay
PostPosted: Sun May 27, 2018 3:42 pm    Post subject: Reply with quote
Side view
 Filesize:  292.99 KB
 Viewed:  4844 Time(s)
Stuart Mackay
PostPosted: Sun May 27, 2018 3:43 pm    Post subject: Reply with quote
Installed and ready for test drive
 Filesize:  422.99 KB
 Viewed:  4842 Time(s)
Roro
PostPosted: Mon May 28, 2018 7:16 am    Post subject: Reply with quote
What does this now look like in situ, is everything exposed like in the pics or does it all look OEM?
Did you look at the CAE shift mechanism, any reason in particular you didn’t go for that?
2007 997.1 GT3
2017 F87 M2
Stuart Mackay
PostPosted: Mon May 28, 2018 10:20 pm    Post subject: Reply with quote
All goes back as standard, you would not know it has been upgraded.
Yes looked at CAE, but too "race car" for my taste (I love my OEM carbon and alcantara Smile ) and 3 times the cost of the Function First kit.
Stuart Mackay
PostPosted: Fri Oct 05, 2018 3:33 pm    Post subject: Reply with quote
https://911porscheworldmag.bigcartel.com/product/august-14-911
Article about the GT3 and Cab in the November 2018 issue, and here is one of the piccies from the article.
 Filesize:  1.16 MB
 Viewed:  3472 Time(s)
Goto page Previous  1, 2, 3, 4  Next
Page 3 of 4
