997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sat May 19, 2018 6:58 am    Post subject: 996 top mounts. Original/Tarret/Rennline Reply with quote
Does anybody have experience of the difference between the alternative uniball top mounts? OEM appear to be about twice the price of aftermarket, are they much better or is it Porsche tax?
Any other suggestions welcome. I will need front and rear.
angry
PostPosted: Sun May 20, 2018 10:02 am    Post subject: Reply with quote
I replaced my originals with Tarret, but at the same time as changing to Bilstien PSS10s, so no comparison on stock suspension.
They are ok, no loss of comfort.
The only thing I didn't like is the camber adjuster allen bolts. When fitted to the car you cannot get to them to adjust them, you have to drop the strut out.
This is ok if you go to someone like Centre gravity for set up, once they've set up you can just leave them be.
They look very hard wearing as there is no rubber parts.
Advise you buy a pair of new https://www.design911.co.uk/fu/prod10934/Shock-Absorber-Angular-Contact-Bearing-Porsche-99634350100/
996 Turbo Previous
993 C2.
MisterCorn
PostPosted: Sun May 20, 2018 1:15 pm    Post subject: Reply with quote
Thanks for getting back to me. I should have been explicit but it is the GT3 top moints I am looking at rather than the turbo ones. The standard GT3 ones are monoball but dob't know how they compare with the other options. I will probably consider these when the turbo ones next need doing though.
MaxA
PostPosted: Mon May 21, 2018 6:31 pm    Post subject: Reply with quote
I got Vorschlags, as they were actually pretty competitively priced for adjustables.
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
