997 : 2004- 76
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
jotaking
PostPosted: Sun May 13, 2018 10:49 am    Post subject: Sticky s**t Remover Reply with quote
Whilst washing SWMBO car I noticed brown sticky splash marks on the running board, plastic trim and door panels.
I purchased an Auto Glym Tar remover and it hasn't touched it. I have also tried a clay bar and this hasn't worked either?
I think SWMBO has driven through the "tack" coat for temporary road markings.
Can anyone recommend any products that will shift it? Thumb
 Filesize:  138.43 KB
 Viewed:  2374 Time(s)
 Filesize:  179.85 KB
VPD255M
PostPosted: Sun May 13, 2018 11:31 am    Post subject: Reply with quote
AutoSmart Tardis should do it
997.1 GT3 CS
alex yates
PostPosted: Sun May 13, 2018 2:59 pm    Post subject: Reply with quote
White Spirit.
kas750
Reims
2006 Porsche 911
PostPosted: Sun May 13, 2018 3:14 pm    Post subject: Reply with quote
I have found that WD40 is at least as good as proprietary tar removers if not better.
ColinC
PostPosted: Sun May 13, 2018 3:25 pm    Post subject: Reply with quote
Not sure what that stuff actually is on your wife's car however 3M Adhesive Remover gets rid of tar spots easily and also removes polish/wax from rubber surrounds....
94 993 C2 - Black with Marble Grey Leather
alex yates
PostPosted: Sun May 13, 2018 3:36 pm    Post subject: Reply with quote
I thought it was his Mum's?? Dont know
jotaking
PostPosted: Sun May 13, 2018 4:32 pm    Post subject: Reply with quote
Thanks for the input folks
I had some WD40 so gave it a whirl and it did nothing! Sad
Also...for the record.....its my wife's car. Thumb
alex yates
PostPosted: Sun May 13, 2018 5:37 pm    Post subject: Reply with quote
Grin Thumb Was only said in jest.
911TEL
2011 Porsche 997 Turbo S
PostPosted: Sun May 13, 2018 5:51 pm    Post subject: Reply with quote
Autosmart Tardis vote #2....
Great stuff , would be surprised if it doesn’t shift it ..
997 Gen 2 Turbo S Basalt Black -BBS CHR, Kline inconel exhaust, DSC V1 & Polished Bliss air freshener...
SL 55 AMG Obsidian Black
Brompton S2L Black edition
DucatiRob
PostPosted: Sun May 13, 2018 5:52 pm    Post subject: Reply with quote
Try some white spirit, if it is tar or some oil based substance that should shift it, if not then try paint thinners, but go easy and test somewhere where you can't see it first!
Mercedes CLK DD
Ducati 996
toddy2
PostPosted: Sun May 13, 2018 6:50 pm    Post subject: Reply with quote
Another vote for tardis. Wear gloves though
Current Porsche Line up:
1968 911T
2002 996 4s
1988 944
jotaking
PostPosted: Sun May 13, 2018 7:09 pm    Post subject: Reply with quote
Tardis purchased.
I’ll keep you posted.
jotaking
PostPosted: Wed May 16, 2018 1:36 pm    Post subject: Reply with quote
Tardis didn't touch it Sad
Any other suggestions before I get the sandpaper out?? frustrated
alex yates
PostPosted: Wed May 16, 2018 1:40 pm    Post subject: Reply with quote
Have you tried white spirit yet?
mrgrey
PostPosted: Wed May 16, 2018 1:42 pm    Post subject: Reply with quote
Petrol.
991.1 C2S PDK
997.2 C2S PDK
maldren
PostPosted: Wed May 16, 2018 2:01 pm    Post subject: Reply with quote
Another vote for White Spirit, I have used it on lots of cars and it really shifts tar etc. It won't damage the paint either.
Mike
Mike
Marky911
Watkins Glen
PostPosted: Wed May 16, 2018 2:49 pm    Post subject: Reply with quote
If tardis didn't touch it then god knows what will!
Tardis melted the (non-original) paint on my daily bangers front bumper it's that strong.
Try some brake cleaner. You can get it in aerosols for smaller amounts or 5lt tins for trade.
Halfords will have it. Spray it on and wipe it straight off. Gradually repeat leaving it a bit longer at a time if necessary.
Only use this on factory finished paint though or you could end up like I did with my front bumper.
If that doesn't shift it I'd visit a detailer. Thumb
PostPosted: Wed May 16, 2018 3:12 pm    Post subject: Reply with quote
Just buy a new one, the time and effort saved will be worth it alone Dont know
(when I say new, I mean a good 2nd hand one on eBay)
jotaking
PostPosted: Wed May 16, 2018 3:26 pm    Post subject: Reply with quote
Too busy drinking it!
I'll try that next.
chicb
PostPosted: Wed May 16, 2018 3:37 pm    Post subject: Reply with quote
Another vote for petrol. Failing that, soak some fine grit emery paper with petrol or Brasso which is a little bit more aggressive than T cut. If that works,
polish up with Autosol
