997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 20
Cayman : 2005- 16
Cayenne : 2003- 4
k11pol
PostPosted: Wed Apr 25, 2018 1:03 pm    Post subject: Bumper wiring loom/ washer hoses Reply with quote
Does anyone have any pictures of how the lighting wiring loom and headlight washer hoses are run behind the front bumper. I removed it for spraying then dropped if at the sprayers with all mentioned still attached. I never realised they would remove everything without taking pictures. All I have now is a box of bits and no idea how they go back. If I knew they were to be removed I would have done so myself documenting each part as I did with the bumper removal.
Even the clips have all been removed as this would have pointed me in the right direction.
PostPosted: Wed Apr 25, 2018 6:39 pm    Post subject: Reply with quote
Im afraid this is one of those jobs i do but cant really explain , the pipes from memory for the jets run along the base and under tabs on the grills , i found a picture of a bit of it that might help .
Short of waiting till we have one appart in the workshop i can photo ( and theres nothing atm ) then im afraid theres little i can say to help Sad
Right click on image and select veiw image .. the washer pipe you can see running along the base .
 Filesize:  152.01 KB
 Viewed:  769 Time(s)
k11pol
PostPosted: Wed Apr 25, 2018 7:17 pm    Post subject: Reply with quote
That’s perfect De mort, it shows I was hosing it wrong. Due to the long hoses I thought it ran along the top so clearly see that it should run along the bottom.
I contacted the garage that sprayed it and to be fair they were excellent , they told me to drop it of which I did this afternoon and he will do it for me and will be ready for collection in the morning. Can’t be much fairer than that.
PostPosted: Wed Apr 25, 2018 7:27 pm    Post subject: Reply with quote
Good news and sorted ..
Ill add a photo of it to my library as soon as we have one in for future problems .
k11pol
PostPosted: Wed Apr 25, 2018 8:02 pm    Post subject: Reply with quote
Good man, thanks for that
