996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
Should I replace my rusty manifolds?
Yes, the car is going to be much better with new
15%
 15%  [ 3 ]
No, you won't really notice any difference
84%
 84%  [ 16 ]
Total Votes : 19
APL911
PostPosted: Fri Apr 13, 2018 1:15 pm    Post subject: Rusty Manifold. Should I bother replacing Reply with quote
Hi all
I am in the process of getting quotes to replace my heavily corroded exhaust manifolds.
The flanges are complety wrotten, and the fixings are in terrible shap.
My question is this. Should I bother? What is the worst that can happen if I just leave it? It's not blowing, and it's pretty solidly rusted in place.
I do like the idea of nice shiny new manifolds, but I'm not really sure what difference it will make and if it is worth the £1,000+ it is likley to cost.
What are your thoghts?
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Fri Apr 13, 2018 1:19 pm    Post subject: Reply with quote
I would wait until something needs doing on it. That is the plan with mine anyway.
INWB
PostPosted: Fri Apr 13, 2018 1:26 pm    Post subject: Reply with quote
If your car is a keeper then you may want to bite the bullet.
My car is better after doing them. Used the Top Gear ones. The biggest bill was the labour and GCR took pity on me and only charged me the estimate (which was eye watering enough). Every bolt snapped.
So glad I did mine now. (resprayed the support brackets for the mufflers at the same time)
2003 Manual 996 C4S Midnight Blue
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Apr 13, 2018 2:00 pm    Post subject: Reply with quote
Theres two schools of thought:
Leave it, might never happen, they can look really really bad and not leak.
Or
Do it now so you are not left in the middle of France with a 996 that sounds like a tractor.
Has anyones got so bad it has leaked this badly?
When I do get around to mine, I'll be buying/borrowing a jig and buying the finest, sharpest drill bits money can buy.
wasz
PostPosted: Fri Apr 13, 2018 2:02 pm    Post subject: Reply with quote
Plus there is always the risk that you will spend 2 days drilli
ng on your back with swarf in your eyes, then 2 months later a head needs to come off anyway for something else. Or you drop the engine for something else and put it on a stand.
Then you will be cursing not being able to do it on the bench.
Mine is staying put until it leaks (if it ever does).
freshy
PostPosted: Fri Apr 13, 2018 2:21 pm    Post subject: Reply with quote
Mine doesn't look pretty, personally I'm leaving it alone until it starts to blow.
2005 996 'C4S Plus' Cab Manual in Atlas Grey X51 + Rusty PSE
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Fri Apr 13, 2018 2:47 pm    Post subject: Reply with quote
Plenty of other higher priority jobs on mine.
It can stay rusty until it actually starts blowing, or until the engine is out for some other major work (heaven forbid!)
g911omr
PostPosted: Fri Apr 13, 2018 2:50 pm    Post subject: Reply with quote
If it were me, I'd leave them until they need doing. New ones do look smart though.
 Filesize:  174.79 KB
 Viewed:  1946 Time(s)
alex yates
PostPosted: Fri Apr 13, 2018 3:23 pm    Post subject: Re: Rusty Manifold. Should I bother replacing Reply with quote
Da fook!
Where you getting it done - Harrods?
Cost me £356 for parts and labour.
Stoo.c
PostPosted: Fri Apr 13, 2018 3:29 pm    Post subject: Reply with quote
I'm guessing he's including the price of having his bolts all drilled out which can easily reach £500 so £1000 all in isn't far off of what one might expect.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
g911omr
PostPosted: Fri Apr 13, 2018 3:41 pm    Post subject: Reply with quote
If all the studs come out in one piece then it isn't a challenging job.
I bet they don't though....
sackerley
PostPosted: Fri Apr 13, 2018 3:47 pm    Post subject: Reply with quote
I'd leave it. Mine are a mess and look terrible but I'm going to leave it until it really needs doing.
Far more things to spend the money on!
1998 Artic Silver 996.1 - manual - carbon interior - Momo Protopito
alex yates
PostPosted: Fri Apr 13, 2018 3:49 pm    Post subject: Reply with quote
Stoo.c wrote:
I'm guessing he's including the price of having his bolts all drilled out.
So was I!
arry
PostPosted: Fri Apr 13, 2018 6:48 pm    Post subject: Reply with quote
Exactly how I've treated my wife for 13 years.
2001 Lapis Blue 996 C2 Manual
2012 Orange KTM 990 SMT
2016 Marsh Grey Royal Enfield Bullet 500
PostPosted: Fri Apr 13, 2018 6:53 pm    Post subject: Reply with quote
If there was an option for .. Good God Dont Touch It Unless You Have To ... then i would have voted for that !!
Its rusty .. it dont look pretty .. short of getting run over by the car or its on a ramp then whos going to notice .
I see shed loads of mainifolds in a poor condition .. i can count the number of times ive seen an exhaust leak from them on one hand !
They have to come off to do certain types of work .. they have to come off if you are modifiying the exhaust .. if none of these then dont bother .. probably plenty of other areas you could spend the money on .
Flange gaskets and bolts can be replaced .. thats not a problem as you dont need the mainifold off to do that .
Did i make my point Question Floor
APL911
PostPosted: Fri Apr 13, 2018 7:00 pm    Post subject: Reply with quote
Thanks guys. Decision made! Floor
alex yates
PostPosted: Fri Apr 13, 2018 9:22 pm    Post subject: Reply with quote
Those manifold bolts are like ingrowing toe nails. The sooner it's addressed, the easier the pain. You're just ramping the bill up leaving it.
INWB
PostPosted: Sat Apr 14, 2018 7:22 pm    Post subject: Reply with quote
I have new manifolds (see above) but they have gone very dark - even look rusty! Is that normal????? I was expected the shiny manifolds to stay shiny
alex yates
PostPosted: Sat Apr 14, 2018 7:37 pm    Post subject: Reply with quote
The clue's in the name - Stainless, not Stainproof.
INWB
PostPosted: Sat Apr 14, 2018 8:12 pm    Post subject: Reply with quote
Thanks Alex. Smile I'm not that good with stuff like that. Can I get bolts that don't corrode? The new ones already have surface rust.
Goto page 1, 2, 3  Next
Page 1 of 3
