997 : 2004- 58
Boxster : 1997- 27
Cayman : 2005- 22
freshy
PostPosted: Sun Oct 08, 2017 7:24 am    Post subject: Reply with quote
Thank you, great write up Salut
2005 996 'C4S Plus' Cab Manual in Atlas Grey X51
Zub-911
PostPosted: Thu Feb 15, 2018 11:19 am    Post subject: Reply with quote
Great write up,
If you don't feel confident, these guys can do it..
http://www.revolution-porsche.co.uk/upgrades/retrofit-cruise-control-and-on-board-computer
NB: Prices are + VAT
Anyone had any experience ?
MY03 - 996 - C4S
ian_alex
PostPosted: Thu Feb 15, 2018 10:32 pm    Post subject: Reply with quote
This works out at £449 plus VAT for the 4 stalk version.
Using Leon's excellent "how to" and a used stalk I did the job including coding for less than £200 and had all the fun???
Osh
Paul Ricard
PostPosted: Thu Mar 08, 2018 6:41 pm    Post subject: Reply with quote
Hi Leon
Thanks for the call the other day; I've now got all the parts assembled. Will be doing this over Easter.
I'll let you know how I get on
Osh
Tim_s
PostPosted: Fri Mar 09, 2018 9:34 am    Post subject: Reply with quote
Good write up - I can do the coding (and lots of other coding like keys/fobs etc) if anyone needs it done. In Twickenham or Bristol quite regularly.
A few things I'd add are:
-The £20 looms from 'MDB diagnostics' / ebay save a bit of faff with building your own to save a few quid (especially if you're doing a pre-2002). I used one on a boxster (which needed the wires ran to the dme) and it worked well.
-I always put rags under the clocks on the dash when lifting them in/out to prevent any marks on the dash, and use plastic dash removing tools to remove. The dashboards and plastics on these seem to mark so easily!
Pelican parts articles:
https://www.pelicanparts.com/techarticles/Boxster_Tech/92-ELEC-Cruise_Control/92-ELEC-Cruise_Control.htm
and
https://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/92-ELEC-Working_Cruise_Control/92-ELEC-Working_Cruise_Control.htm
are v helpful.
Osh
Paul Ricard
PostPosted: Sat Mar 31, 2018 11:28 am    Post subject: Reply with quote
Just started doing this project. Anyone else thinking of doing it, it's a good tip to
a) check your socket set to make sure you have a 24mm socket PC
and...
b) then check you have an extension bar so the ratchet clears the steering wheel case... PC PC
Piccie later Grin
Osh
Leon1davies
PostPosted: Mon Apr 02, 2018 2:19 pm    Post subject: Reply with quote
Ha Grin
How’s the project going?
Run into any other issues at all?
millerman
PostPosted: Fri Apr 13, 2018 1:30 pm    Post subject: Reply with quote
Great write up, cheapest stalks I could find was EuroCarParts at £227, and rather than buying individual VW cables, theres a chap on Ebay making a loom for £20 all labelled...so, just done the job, but haven't had it coded by my Indie yet. When I switch it on , on the stalk, should it light up or won't that happen until its coded ? Cheers Andy
Osh
Paul Ricard
PostPosted: Fri Apr 13, 2018 4:22 pm    Post subject: Reply with quote
My carpartsforless stalks have just turned up today - will be fitting this weekend
Osh
millerman
PostPosted: Fri Apr 13, 2018 10:07 pm    Post subject: Reply with quote
Stalks are only £200 this weekend at carparts4less !!!
Nice
Halcyon
PostPosted: Sat May 11, 2019 5:34 pm    Post subject: Reply with quote
I *finally* got around to doing this!!
I fitted the stalks last weekend (Used from BoxterBits) and I used the pre-made loom as others have suggested.
I had it coded today. (@ Marque 21 in Bridport)
Note: on a tip-tronic, cruise has to be enabled in the gearbox section of the DME too.
I used Leon's excellent guide from start to finish Thumb Thumb
BobTB
PostPosted: Sat May 18, 2019 6:52 am    Post subject: Reply with quote
Any one got a good source for these?
design 911 are selling them for £320+vat now.
I'll check out the OPC later today. Hopefully they haven't gone the way of the 6 pot caliper
maldren
PostPosted: Sat May 18, 2019 9:21 am    Post subject: Reply with quote
OPC or Carpartsforless, Eurocarparts or Frazerpart.
D911 are rather expensive (as so often) and then add VAT!
Mike
Leon1davies
PostPosted: Sat May 18, 2019 10:27 am    Post subject: Reply with quote
ah excellent! Did everything generally go to plan? pleased with the mod?
Halcyon
PostPosted: Sat May 18, 2019 10:51 am    Post subject: Reply with quote
Very pleased Leon - the fitting was straight forward as I followed your guide. Getting the rubber grommets into place was a faff, but nothing major Thumb
Goto page Previous  1, 2, 3
Page 3 of 3
