997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
racdavies
PostPosted: Tue Sep 26, 2017 8:23 pm    Post subject: Violent bumping at high speed. Disappears if I brake. Reply with quote
Hi all, I have a Cayenne 2005 4.5S. Been a great car for many years. Recently I noticed a wobble at high speed and easing off from high speed until about 50mph, then smooth again. Not wheel balance (got that done), not disks (replaced all four).
Here's the odd and important confusing thing.
If I feather the brakes, even slightly, it goes away and smooth. Take foot off brakes and wobble comes back, almost like going over cats eyes or road paint... Like a pulsing bumping. Touch brakes, goes away.
I replaced all front bushes, top and bottom wishbones. Bearings fine as is drive shaft mid bearing.
Two garages seen and none can work out why braking removes wobble / bumping. Please help. Spent a fortune and it's still doing it!
MaxA
PostPosted: Wed Sep 27, 2017 8:05 am    Post subject: Reply with quote
That's an odd one. I can only suggest failing wheel hubs?
2010 9972 C4S PDK: Carrara White, Sea Blue. Mostly driven, lightly modified, occasionally tracked, and usually a bit grubby.
PostPosted: Wed Sep 27, 2017 6:50 pm    Post subject: Reply with quote
Just to confirm .. you do mean the steering wheel shakes at high speed etc ?
Wheel wobble is .. rule of thumb here 62 - 74 mph .. above and below that its fine so can you drive through this ?
Brakeing would have the effect of pulling the wheel central .. locating it if you like and altering the frequency of the vibration .
So .. assumeing this is steering wheel shakeing and so some sort of " wheel wobble " then we have the wheel balence , the disc , the hub and the driveshaft .. cant see anything on the diff that would cause this .
We do have suspension bushes and we do have geometry setup but assuming no tyre scrub and the play has been checked which i would have thought it has been you are left with driveshaft or a hub out of balence .
A little more info on the symptoms please Smile
racdavies
PostPosted: Fri Sep 29, 2017 10:42 am    Post subject: Reply with quote
Thank you for having a think about this guys. MaxA, hub is for sure a possibility.
It's a real head scratcher... I've spoken with Porsche Glasgow now and bearing is a possibility. Rare but possible. The brakes pulling any wobble at higher speed suggest hub being grabbed by callipers is stabilised which suggests hub wobble directly (actually more like a thumping like a flat tyre than general steer wobble like with unbalanced wheel or shot disks)
So specific symptoms from 80mph when easing off (only briefly at that speed to overtake perhaps) the wobble gets violent. If, while it doing it I feather the brakes it goes away completely. Remove foot from pedal and it comes back but at around 50mph disappears, or rather diminishes so I can no longer feel it. It may be there and minimal but road surfaces distort what I feel.
The odd thing is that the good garage I use locally that replaced the front wishbones and all bushes (a previous garage diagnosis thought it was bushes, as there was play in them, so we replaced them) didn't notice track rod ends and they checked drive shaft and said that was ok.
Reason I have not gone to Porsche direct is because I live in Outer Hebrides and it's a 3 day, two nights in hotel and 600 miles and ferry to get to Porsche centre, so am stuck locally).
Really appreciate help. Am thinking Hub / bearing somewhere? Just odd it is fine at lower speeds except psi light and losing power as result.
PostPosted: Fri Sep 29, 2017 4:24 pm    Post subject: Reply with quote
Interesting .. im sure you have had out of balence wheels before and you describe it as like a flat tyre so very different to normal wheel wobble .
Light pressure on the brakes will stablise it .. it happens violently on over run and is not noticable below 50 .. hmm ..
Dont worry this is me listing everything and trying to figure it out .
It a cayenne so it might have the same wheels front and rear .. some do some dont so is it possible to swop front and rear ?
Im thinking something wrong with a front tyre for this .
Air suspension or shocks ? suspension damping will bounce the wheel in a sense , that would probably be unnerveing and would after a time show up as wear on the tyres .
The speed indicates a rotational item though .. it sounds like most of the suspension has been replaced so im guessing no play up / down and side to side on the front wheels ? .
A wheel bearing will normally give a noise or will have play in it .
Steering feels normal .. ie the rack is not heavy to turn at normal or low speeds ?
Why on over run though , out of balence hub wheel , tyre will be the same i would have thought .. over run is the front of the car bearing down and a load on the front diff .. transfer box .. hmm
Ok so assumeing the garage has had a good look over then its nothing obvious ..
Im assumeing its air suspension so any fault codes in this system .. i would also have liked to see the readings for the shocks but that needs a tester .
Im also thinking geometry .. any tyre wear on any of the tyres ?
Is it possible for a passenger to do a video with sound of whats happening ?
you can post it here or mail it to me here ..
De.Mort@virginmedia.com
I know your kinda stuck with the OPC so far away so happy to do my best here .
Johnd52
2011 Porsche Cayman 987
PostPosted: Fri Sep 29, 2017 5:27 pm    Post subject: Reply with quote
Driveshaft Cv joint? Does it get worse in high torque situation - accelerate in high gear at low rpm?
2015 Cayman GTS. No more PDK but still red.
racdavies
PostPosted: Sun Oct 01, 2017 9:46 am    Post subject: Reply with quote
Hi guys, John, It doesn't seem to happen in high torque situations, or rather you can't feel it.
Demort, your initial sentences spot on. The bit about over run down to 50 the key thing that makes this different to any other issue I have ever had with any number of cars. Something is clearly "loose" or moving where it should not so joints and drive shafts along with hub bearings are to be thoroughly examined.
Same wheels front and rear. This is just too violent to just be a wheel I think. Steering feels normal. I'm not sure a passenger could video it or even hear it really? It comes through the chase or wheel and just a feeling like a flat tyre at speed but all tyres evenly worn and tracking been done twice in last few months... It is possible it's a bearing. I can't hear a constant noise but the Porsche engineer said you don't always.
What surprises me though is at least four pro mechanics and two separate garages have known about this and I have specifically asked them to check things over and neither garage has found anything. However, this may be because of assuming it was the bushes, being as they needed replacing. So that didn't solve it, so maybe this next visit they'll be more thorough now an obvious thing (to them) has been ruled out.
I will let you know if it's solved but it is an interesting anecdotal behaviour that is rare it seems.
Many thanks for having a think and once tested with diagnostics again and thorough underneath check I hope to have some closure!
racdavies
PostPosted: Sat Dec 23, 2017 2:30 pm    Post subject: Reply with quote
Well, I have now been to Porsche main dealership twice and they found no faults. On the second visit the head service engineer came with me for a drive in it and he has never come across this before and can't work it out ether (bear in mind for me, this means a 3 hour ferry and 5 hours driving and hotel stay each way and time).
I have had all four wheels re alloyed and balanced etc, new tyres, new bushes, all brake and abs sensors perfect and no faults at all on the system...
The problem is now worse and happens at more speeds and more violently and now the PSM light ***** on and tries to control the car on straight roads sometimes. I now have to book her in for several days and they'll try and diagnose while moving because no faults show when stationary.
The engineer reckoned it could be the yaw sensor (so I am now going to replace that), could be the PSM ABS loom under the bonnet (corrosion) or could possibly be the bearing trigger system. Sensors are all fine so it isn't them.
It did go away completely for one day recently but is back with a vengeance and am fed up of it.
Just thought I'd give an update! :-0
PostPosted: Sat Dec 30, 2017 6:00 pm    Post subject: Reply with quote
My thoughts are it needs a steering angle sensor calibration , that should be done when ever a car has a geometry check or that the wireing going to the PSM control unit has indeed got water ingress.
There was a mod many years ago to stop the ingress ( a design fault ) and it can cause some strange PSM faults.
Yaw sensor would be unlikely without a fault code generated and i assume that so far no codes have been found.
Also .. check the front tyres have similar tread hights and that one is not an N rated tyre and the other isnt as we are talking PSM faults.
racdavies
PostPosted: Wed Jan 03, 2018 12:58 pm    Post subject: Reply with quote
Thanks Demort,
Steering sensor possible but it happens in straight line or in corners and speed seems the most critical. It was also doing it before changing things and also after and also rarely, it drives perfect...
It was not the yaw sensor. New one in place and car behaves exactly as previously. Darn, another wasted day!
Seems to kick in at 55mph plus now (was higher but it's getting worse). It is for sure an electronic issue. Everything physical has been changed now! Tyres, alloys, stripped callipers, new brake disks throughout, bushes.. you name it. The fact zero faults come up with porsche piwis diagnostics is baffling. You'd think water ingress would lead to some faults showing? I am next going to strip out the psm control wiring loom and look... Wish me luck.
Need to rule that out next. The PSM light ***** on now from time to time when cruising along and even the slightest road deviation or dip.... I don't quite understand how water ingress could lead to this behaviour which is pretty consistent (although one day recently, the car behaved perfectly!). You'd have thought it might cause random issues rather than one very specific and strong fault yet leave no fault codes to pick up?
What puzzles me more is why it's getting slowly worse, as though a physical wear thing?
I hope to have time to look at the wiring this week and will let you know. I would hate anyone else to have an eight month, 3 garages (including Porsche) expensive waste of time like this if I can help avoid it. Both Porsche garage trips required 6 hours on a boat along with 13 hours driving and overnight stays and nothing achieved except ruling out faults.
Thanks all for thinking about it.
Rich
EGTE
PostPosted: Fri Mar 30, 2018 12:22 pm    Post subject: Reply with quote
Did you ever get to the bottom of this?
