Clanky said:Also, if you want to avoid swirls & spider webbing, bin the cover & just put it in the garage. Dragging a cover over the car each time is dragging fine grit all over the car too.
I quite agree with that but i only ever put the cover on after it's been freshly washed. if the car then gets driven the cover stays off until its washed again :thumbs:
p.s will upload vid of water repelling shortly.
