997 : 2004- 63
Boxster : 1997- 26
Cayman : 2005- 20
Macan : 2014- 3
thesmithsUK
PostPosted: Sat Mar 03, 2018 5:10 pm    Post subject: How to test horns? Reply with quote
Is there an easy way to test whether a horn is working?
Just liberated these from the car this afternoon.
The spade connections all seemed OK (at the wheel hub and the horns themselves). And the fuse is intact.
One of them occasionally works. But only occasionally.
1990 964 C4 Cab | Manual | Brilliant Red Metallic on Black
1984 Ferrari Mondial QV Coupe | Manual | Argento Silver on Bordeaux
1984 924 2.0 | Manual | Black on Black
Ex 2004 996 C4S | Manual | Seal Grey on Black
Ex 1991 TVR 450 SEAC | Manual | Cureton Green on Tan
PostPosted: Sat Mar 03, 2018 5:14 pm    Post subject: Reply with quote
jump leads on your battery and the other ends on the spades. Makes sure you do + to +
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Mar 04, 2018 12:30 am    Post subject: Reply with quote
As said put earth and 12v through them and that will test if they work or not.
I had an issue with one (low tone) on my 996, thought it had broke so bought a new one, bumper off and fitted it to find it also didn't work, traced it to the connector having a bad connection.
PostPosted: Sun Mar 04, 2018 8:38 am    Post subject: Reply with quote
When mine have seized up or sounded like a throttled cat, I've just sprayed a load of wd40 down the spout and let it soak for 10 minutes. Always brought back to life.
maldren
PostPosted: Sun Mar 04, 2018 9:26 am    Post subject: Reply with quote
Protect your ears before testing....
Mike
thesmithsUK
PostPosted: Sun Mar 04, 2018 4:04 pm    Post subject: Reply with quote
Armed myself with a digital multimeter...
Switch at steering wheel - fine. Fuse - fine.
One of the tones is dead (no continuity, no sound when wired direct to battery). The other one is intermittent. Cleaned up the connectors, tested (positively) for continuity, also worked when connected direct to battery. So, connected it back up - and it worked. Twice. Then nothing.
Disconnected it. No continuity. Took it apart. Reassembled it. Tested (positive) for continuity. Back in situ. Worked. Once!
Though I guess I could get my soldering iron out and try this: http://p-car.com/diy/hornrepair/
I'm minded just to order two new tones!
PostPosted: Sun Mar 04, 2018 4:06 pm    Post subject: Reply with quote
Yep - that's what happens when you don't squirt some wd40 down the spout to free up the farty bit inside.
PostPosted: Sun Mar 04, 2018 4:08 pm    Post subject: Reply with quote
Also helps if you adjust the tone screw whilst testing but you need to leave the horn blasting whilst you do it. Shove a rag down the spout so not to annoy the wife or neighbours.
thesmithsUK
PostPosted: Sun Mar 04, 2018 4:39 pm    Post subject: Reply with quote
Will give that a try now...before I spend £140!
Magic919
PostPosted: Sun Mar 04, 2018 5:20 pm    Post subject: Reply with quote
That sound expensive. Dearer than 997 horns.
997.2 C4S PDK
thesmithsUK
PostPosted: Sun Mar 04, 2018 5:36 pm    Post subject: Reply with quote
Have taken the trumpet off and opened the unit up. Might actually give this a try before ordering new: https://p-car.com/diy/hornrepair/
maldren
PostPosted: Sun Mar 04, 2018 5:39 pm    Post subject: Reply with quote
Bet they're not Porsche specific, anyone know what other cars share the same horns? Is there a part number on them?
Mike
PostPosted: Sun Mar 04, 2018 6:39 pm    Post subject: Reply with quote
The original ones are not very cheap .
It depends on how original you want the car to be .. any 2 spade horn will fit and if you want the two tone you could still fit 996 ones , have to get the wiring plugs as well for 996 ones as they are not a standard spade connection .
http://www.design911.co.uk//fu/prod12877/Horn-Low-High-Pitched-Porsche-911---928---964/?imt=1&utm_campaign=uk+shopping&utm_source=adrac&utm_medium=cpc&utm_content=
Indy Mechanic .
thesmithsUK
PostPosted: Sun Mar 04, 2018 8:54 pm    Post subject: Reply with quote
Hmmm...half the price. Tempting. But what would the purists say?! At least they'd hear me coming.
maldren
PostPosted: Mon Mar 05, 2018 8:59 am    Post subject: Reply with quote
There are cheaper still on ebay if you want to experiment.
Mike
PostPosted: Mon Mar 05, 2018 5:36 pm    Post subject: Reply with quote
Hmm ..
http://www.design911.co.uk/fu/prod13655/Porsche-Horn-Low-High-Pitched-92863522200-92863522101/
Standard spade connection on these .. and who is going to see them after all !
Indy Mechanic .
thesmithsUK
PostPosted: Mon Mar 05, 2018 9:18 pm    Post subject: Reply with quote
Demort wrote:
Hmm ..
Good call!
thesmithsUK
PostPosted: Mon Mar 12, 2018 8:01 pm    Post subject: Reply with quote
I ended up ordering two new (944) horns from Porsche Exeter - just £46.99 for both, including VAT and delivery! (And my 10% PCGB discount.)
Part numbers: 944.635.205.00 and 944.635.206.00 for future reference.
I also replaced the horn contact ring (a screw and plastic spacer were missing from the original) with this from Germany: https://www.fvd.net/de-en/100498F60102/repair-part-atiwe-horn-contact-ring-formula-steering-wheels.html
Just connected it all up and all working perfectly!
Thanks all for your help and advice (as always).
stuttgartmetal
PostPosted: Tue Mar 13, 2018 11:01 pm    Post subject: Reply with quote
I’ve got a spare pair in my shed.
thesmithsUK
PostPosted: Sun Oct 07, 2018 3:43 pm    Post subject: Reply with quote
Need some advice...
Both horn tones suddenly stopped working.
Found that the fuse (Number 3) had blown.
Simple.
Put a fresh one in (also 15A) but nothing. This new fuse had immediately blown!
I'm guessing the culprit could be the relay? (Number 23 according to the diagram on my fusebox lid.)
Can anyone help?
