997 : 2004- 85
996 : 1997-2005 46
993 : 1993-1998 6
Boxster : 1997- 19
Cayman : 2005- 12
Macan : 2014- 1
Jonnywise
PostPosted: Sun Mar 04, 2018 12:17 pm    Post subject: 997 c4s left rear wheel on the bump stop ? Reply with quote
Hi went to drive my 997 today and notice the left rear wheel if nearly touching the wheel arch ? It was fine last week.
The pasm on the dash says ok when changing sports mode.
Any ideas ?
Cheers Jonny
Thefinn
PostPosted: Sun Mar 04, 2018 12:19 pm    Post subject: Reply with quote
Have you checked the springs one might have snapped
997.1 C4S CAB
Jonnywise
PostPosted: Sun Mar 04, 2018 12:28 pm    Post subject: 997 Reply with quote
The last time I drove it was fine,and it's just been sitting on my drive until today,would it just snap when the car is sitting still ?
Cheers Jonny
Thefinn
PostPosted: Sun Mar 04, 2018 1:04 pm    Post subject: Reply with quote
Just seen a post on the Porsche owners FB page and this has happened to a chap on there while it sat over night on his drive, so it might be worth a look. It might be something to do with the extreme cold weather finishing off a spring that is on its way out at a guess.
997.1 C4S CAB
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Sun Mar 04, 2018 1:12 pm    Post subject: Reply with quote
Quite common on the 997 unfortunately, they can break in the cold weather with the car just sat.
Jonnywise
PostPosted: Sun Mar 04, 2018 4:47 pm    Post subject: 997 Reply with quote
I have had a look and the spring is down the hole length of the shock,
So I don't no if it's broke or were it mounts on the shock is broken,well it looks like a big bill coming my way Sad
PostPosted: Sun Mar 04, 2018 5:05 pm    Post subject: Reply with quote
There is a spring clip at the base of the shock , these let go and the coil just drops down .
No.5 in this link .
https://www.deroure.com/diagrams.asp?TBL=2825&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
At an Indy these days !
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Sun Mar 04, 2018 5:11 pm    Post subject: Reply with quote
Seriously bad design if these spring plates can just drop Surprised Surprised Surprised
PostPosted: Sun Mar 04, 2018 5:18 pm    Post subject: Reply with quote
It doesnt happen very often , only seen a handfull since they came out and from memory you need a new shock as its the groove that wears that the clip fits into .. either way its a pretty small clip that holds it all together .
stucart
PostPosted: Sun Mar 04, 2018 5:21 pm    Post subject: Reply with quote
If it is that by the description,That looks a cheap fix provided that part 5 is easily obtained.? Good job it didn’t fail whilst driving spiritedly!
Edit. Just read DeMorts post knew it sounded too good to be true
997 C4S Tip-S, 2007, Silver/Red and Black Leather, PSE, Sports Chrono, Turbo wheels.
Jonnywise
PostPosted: Sun Mar 04, 2018 6:36 pm    Post subject: 997 Reply with quote
I was driving hard the day before,perhaps that finished it off.
Am I right in thinking I will have to replace both ?
Cheers Jonny
PostPosted: Sun Mar 04, 2018 6:42 pm    Post subject: Re: 997 Reply with quote
Cheers Jonny
Pasm shocks are replaced as a single .. you dont tend to replace both .. in fact if it was a warrenty job then Porsche would only pay for one .
removal is not hard , you can get the shock off just on axle stands .. ive done it before when we ran out of ramps Embarassed
Either way it needs inspection first as we are not 100% certain on what parts are actually neded yet .
Jonnywise
PostPosted: Sun Mar 04, 2018 7:07 pm    Post subject: 997 Reply with quote
Ok
Thanks everyone for your help,il keep you posted on what happens
Cheers Jonny
911TEL
2011 Porsche 997 Turbo S
PostPosted: Mon Mar 05, 2018 7:32 am    Post subject: Re: 997 Reply with quote
Cheers Jonny
Demort,
Seriously mate , you need to be working for yourself , you are a font of instant knowledge , you could go it alone ... think of the trade you would get !!
thumbsup
997 Gen 2 Turbo S Basalt Black -BBS CHR, Kline inconel exhaust, Polished Bliss air freshener...
SL 55 AMG Obsidian Black
Brompton S2L Black edition
PostPosted: Mon Mar 05, 2018 4:33 pm    Post subject: Reply with quote
Bless you .. but being so far south im kinda in the Porsche wilderness down here .
Only 2 people on here live any where near me !
