996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayman : 2005- 17
Macan : 2014- 3
912-914-924-928-944-968 3
squelch
PostPosted: Tue Jan 30, 2018 10:54 pm    Post subject: Reply with quote
rhino-man wrote:
If you are talking about your GTS, isn't that lower than a 4S anyway by 10mm?
(which I know is 10mm lower than a non S)
Didn't the GTS have some sort of supersport option as standard which was lower still?
The "PASM sports chassis (- 20 mm) with limited slip rear differential lock" was an option on the GTS.
From Stuttgart: 997 GTS, 996 C4S
From Munich: S54 & S50 M Coupes, 535d M Touring, and a couple of bikes from Italy and Germany
rhino-man
PostPosted: Tue Jan 30, 2018 11:06 pm    Post subject: Reply with quote
Which makes it 10mm lower the standard PASM chassis then I think which is 10mm lower than standard. So the "sports" springs could be an option for us in warranty then.
2010 997.2 C4S
2001 996 C2 Convertible
rhino-man
PostPosted: Tue Jan 30, 2018 11:17 pm    Post subject: Reply with quote
A quick glance (so please verify these part numbers are correct) shows 2 different front springs listed for a GTS, around £150 each + vat
99734353150504 Coil Spring, 1 Set - Identification, Red, Red, Green CARRERA GTS | valid for Special model 911 Carrera GTS (I011) / valid for PASM electronic damper control (I475) | COUPE
99734353149504 Coil Spring, 1 Set - Identification, Silver, Silver CARRERA GTS | valid for Special model 911 Carrera GTS (I011) / valid for Sport-type chassis (I030) | COUPE
and same for rears around £120+ each
1 99733353164504 Coil Spring, 1 Set - Identification, Red, Red, White valid for Special model 911 Carrera GTS (I011) / valid for PASM electronic damper control (I475) | CARRERA GTS
1 99733353173504 Coil Spring, 1 Set - Identification, Silver, Silver, Yellow valid for Special model 911 Carrera GTS (I011) / valid for Sport-type chassis (I030) | CARRERA GTS
2010 997.2 C4S
Thefinn
PostPosted: Fri Feb 02, 2018 11:52 am    Post subject: Reply with quote
My new springs have just been delivered so you should all get a knock on the door soon!
997.1 C4S CAB
 Filesize:  235.91 KB
 Viewed:  1560 Time(s)
weebz
PostPosted: Fri Feb 02, 2018 12:28 pm    Post subject: Reply with quote
Thumb Forgot to mention, my arrived yesterday, now need to arrange fitting, may get around to it by the summer Grin
2010 Basalt Black 997 Carrera S - 'J-Lo 2'
2004 Atlas Grey 996 C4S - 'J-Lo' (sold)
badbox
PostPosted: Fri Feb 16, 2018 9:26 pm    Post subject: Reply with quote
are the techart springs also the best suited for a Gen 2 with pasm
ALso does it matter if its a Targa 4s Gen 2?
Targa 4S 997.2 PDK
PostPosted: Fri Feb 16, 2018 10:20 pm    Post subject: Reply with quote
Techart are fine for gen2 but make sure you get the ones for the Awd 4S as the rear springs are bigger the the ones for the 2S Thumb Targa option should be listed if its different to the non targa cars
badbox
PostPosted: Wed Mar 14, 2018 11:43 pm    Post subject: Reply with quote
When I have the stiffer setting actived the car bounces more and seems to hop....is that what I will be getting in normal mode once springs are on?
Targa 4S 997.2 PDK
PostPosted: Thu Mar 15, 2018 12:35 am    Post subject: Reply with quote
MMM what you have just described you need the DSC pasm upgrade module
theres a long thread on here about a group buy a few months ago , they are not cheap but totally transform the suspension . have a read of the thread and the link before deciding what to do next . I really like the way it makes my car feel subtle but how it should have come from the factory
http://www.tpcracing.com/dsc.html
roocat
PostPosted: Thu Mar 15, 2018 1:35 pm    Post subject: Reply with quote
I have the DSC module and I’m having the techarts put on soon. Will let you know the results.
weebz
PostPosted: Thu Mar 15, 2018 4:52 pm    Post subject: Reply with quote
I've had the springs fitted for a while now, no different to OEM in my eyes.
Mix of British and European roads over the last 1000 miles or so.
badbox
PostPosted: Tue Mar 20, 2018 12:54 am    Post subject: Reply with quote
food food I look forward to this
Targa 4S 997.2 PDK
Goto page Previous  1, 2, 3, 4
Page 4 of 4
