997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
2014 Porsche Boxster 981
PostPosted: Sat Mar 25, 2017 12:48 am    Post subject: Reply with quote
michelin wrote:
They look first class Jon.
On mine would you recommend the full front set of just the corners?
Ummmm, I don't think there is a central rad in the none GTS boxster ? But it would still stop crap getting behind the bumper. I've not really paid much attention to the other 981 bumpers to be honest.
"Imagination is more important than knowledge" Einstein
#lastoftheaircooled
2014 Porsche Boxster GTS My Journal
nigel99
2009 Porsche 997 Carrera 2S
PostPosted: Sat May 13, 2017 9:57 am    Post subject: Reply with quote
Used this code today for 20%
PT022016
Current: 997.2 C2S, Audi TTS mk3
Previous: Cayman 987.1, Audi TT mk1 , BMW e46
easternjets
PostPosted: Sat May 13, 2017 5:41 pm    Post subject: Reply with quote
Best thing I've bought for my car, when you see the debris that comes out of the shrouds round the front rads you'll be ordering them straight away.
Also my middle rad was shot to pieces with chippings so hopefully the grills will protect from all but the smallest pieces.
997 Turbo Gen 2
997 Turbo Tiptronic S
Porsche 968 Coupe 1992
Porsche 928 S4
Porsche 911 3.2 Carrera 1985
nigel99
PostPosted: Sat May 13, 2017 5:47 pm    Post subject: Reply with quote
My centre grille holds a stick on number plate, I was shocked to see how many holes were in this after only a few months, especially as its made of pretty tough material. The grilles are a must have as far as I'm concerned.
gibbs63
PostPosted: Sun May 14, 2017 6:51 pm    Post subject: Reply with quote
Ive just bought some these mesh grills from Zunsport, does the bumper have to come off to fit these ? Thanks for any help.
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Sun May 14, 2017 7:21 pm    Post subject: Reply with quote
I have a 997.1 and didn't have to remove the bumper to fit. There is a bit of measuring and marking up to do but nothing difficult with a little patience. Thumb They do a good job and look well too boot imho.
997.1 C4S Meteor Grey Manual
-- 997 --
PostPosted: Sun May 14, 2017 7:35 pm    Post subject: Reply with quote
My 997 gen1 with grills..
 Filesize:  728.31 KB
 Viewed:  4342 Time(s)
EGTE
PostPosted: Fri Jan 05, 2018 4:15 pm    Post subject: Reply with quote
PT022016
Still works!
Endex
PostPosted: Fri Jan 05, 2018 11:41 pm    Post subject: Reply with quote
EGTE wrote:
PT022016
Still works!
Great find EGTE - thanks!
Porsche 997.1 C4S, Manual
Scholester
PostPosted: Wed Jan 10, 2018 11:32 am    Post subject: Reply with quote
EGTE wrote:
PT022016
Still works!
Ordered a set today using this 20% discount code after finding leaves snuggled up against my rads Thumb
997.1 Turbo Coupe, manual, black/black. 29k miles under its belt.
Jay.
PostPosted: Thu Jan 11, 2018 12:23 pm    Post subject: Reply with quote
GTRnick wrote:
Both PM'd. Anyone else?
Yes please!
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Follow me on Instagram! @rb.240z
Jay.
PostPosted: Thu Jan 11, 2018 12:27 pm    Post subject: Reply with quote
Endex wrote:
EGTE wrote:
PT022016
Still works!
Quote still works. £200 to £165, thanks!
2004 996 Turbo
Seal Grey
Motec 19" Alloys
AMG Flappy Paddles
1972 Datsun 240z
RB25DET
Devil Z
Steve997
PostPosted: Sun Jan 21, 2018 9:50 am    Post subject: Reply with quote
A member in a previous post suggested you need to remove the black plastic cowl on the centre rad. Is that true does anyone have any personal experience when fitting them?
My car is a 997.1 tiptronic so has the centre rad fitted.
Scholester
PostPosted: Sun Jan 21, 2018 5:34 pm    Post subject: Reply with quote
The instructions state that you may need to nibble a bit off the back of the locating tab on number plate plinth. It is to allow the rim of the grill to nestle into position properly but i think it would have done so anyway.
I am not aware of having to remove any centre rad' shroud but my bumper style will be slightly different from yours.
 Filesize:  985.51 KB
 Viewed:  3230 Time(s)
 Filesize:  960.29 KB
Steve997
PostPosted: Mon Jan 22, 2018 8:08 am    Post subject: Reply with quote
Thanks. I think I will email them for some fitting instructions.
JP_Turbo
PostPosted: Mon Jan 22, 2018 1:08 pm    Post subject: Reply with quote
hedgehogsdad wrote:
It's a shame that they don't do a set for the Turbo which sit inside the PU, rather than in front of it. I think they spoil the front of the Turbo fitting where they do.
Unless I'm missing something....
Yeah I think the same too. Hopefully they will do a re-design but I very much doubt it because of the age of the car anyway
2006 997.1 Tiptronic S Arctic SIlver
Spike
PostPosted: Sun Jan 28, 2018 9:24 am    Post subject: Reply with quote
I’ve just done my tiptronic and there was no number plate nibbling or shroud removal required.
The hardest part is drilling 3mm holes into the inner corners. Before I started I hoovered out a couple of fag butts, a car park ticket & a handful of leaves, and as well as being functional I like the clean look once it’s done.
 Filesize:  1.16 MB
 Viewed:  3010 Time(s)
Scholester
PostPosted: Sun Jan 28, 2018 12:10 pm    Post subject: Reply with quote
Question
Spike
PostPosted: Sun Jan 28, 2018 4:11 pm    Post subject: Reply with quote
Scholester wrote:
Question
You need to drill the upper corners of the lower side grilles for Carrera models
TBE997
PostPosted: Sun Jan 28, 2018 8:10 pm    Post subject: Reply with quote
Spike wrote:
Scholester wrote:
Question
it was quite a mental challenge for me to drill holes in my car...
anyways, after a lot longer than i'd like to admit, i can finally tick that box!
Porsche 997.1 C2S - http://www.911uk.com/viewtopic.php?t=120466
Goto page Previous  1, 2, 3, 4  Next
Page 3 of 4
