997 : 2004- 76
996 : 1997-2005 38
964 : 1989-1993 4
Boxster : 1997- 18
Cayman : 2005- 10
TTW
2004 Porsche 997 Carrera 2S
PostPosted: Wed Jan 10, 2018 11:05 am    Post subject: 997.1 Exhaust Heat Shields Reply with quote
Hi Group,
Quick question, BOTH exhaust heat sheilds (the ones that wrap around the box behind the rear wheel arch) on my 997.1s have become loose and vibrate like crazy against the exhaust on idle. one of them became loose last summer, but I managed to secure it (until now)...
My question is, are these absolutly necessary? - are there any members on here whose cars dont have them? - Are they essential or can I just cut them out & end the rattling for good? I know the heatsheild at the rear protects the plastic bumper from the heat, but not sure of any adverse consequences for removal of those that wrap around the exhaust boxes?
Thanks in advance
TTW worship
DucatiRob
PostPosted: Wed Jan 10, 2018 2:36 pm    Post subject: Re: 997.1 Exhaust Heat Shields Reply with quote
TTW wrote:
Hi Group,
Thanks in advance
TTW worship
The heat shields are essential, things get really hot in that area so I wouldn't risk running without them. They are also a pain to replace as the engine needs to be dropped to gain access to the upper fixing bolts. They corrode badly and eventually fall apart, but as long as they are still relatively stable I would look at an interim solution until you need to drop the engine for other essential work. Try to get a trusted mechanic/engineer to have a look and see if there is a temporary fix that might last until you need other work that can be done at the same time.
Mercedes CLK DD
Ducati 996
