power steering leak
johne
7 Apr 2008
289
wonder if any one can help I have a leak which seems to be coming from the metal pipe which enters the rack in the middle .not a 100percent sure.the rack was rebuilt by fernsport just before I purchased the car which was a year and six months ago .has anyone had a similar problem .and do you think I should phone them and talk ?
I had my rack refurbished last year, I did the removal and install myself, not a difficult DIY if you are OK with spanners and follow the information available on the net. I did a write up on here of my work. I have attached a picture below of my rack so you can clearly see the pipes and the banjo connections. If the leak is coming from any of those just get a 10mm spanner if I remember correctly and nip them up.
Good luck.
ATB :)
thanks so much .it seems like its the nut in the center of the rack ill find your write up and have a proper look
well I tightened up the bolts managed to get to 3 ok hopefully it will work .I think it would be to much for me decgraham to rebuild and for that price I would do the same as you . I owe you a pint :thumbs:
124,559
1,441,507
48,971
Bristolsparks
