997 : 2004- 71
964 : 1989-1993 6
Boxster : 1997- 21
Cayman : 2005- 16
Cayenne : 2003- 4
coullstar
PostPosted: Tue Nov 14, 2017 3:38 pm    Post subject: Anyone use a 9in rear wheel or more square wheel set up? Reply with quote
Looking at various OE wheel options and considering a set of Panamera 18in wheels as one of the options (had a set on my Boxster and liked them).
Only thing is rear is 9in wide as opposed to 10in std (although 17in wheels are 9in). Id still use the same tyres @ 265 so to me the affordable grip would be the same.
The fronts are 8in as opposed to 7.5in but again same tyres to be used.
Anyone done this that has noticed anything untoward? To me it just seems a cosmetic change really.
Wheels in question below (not my old car but similar colour to current one)
 Filesize:  240.12 KB
 Viewed:  3822 Time(s)
JKH112
2001 Porsche 996 Carrera 2
PostPosted: Tue Nov 14, 2017 5:45 pm    Post subject: Reply with quote
If they for panamera and noxster are they going to be the correct rear offset for a 996?
coullstar
PostPosted: Tue Nov 14, 2017 6:41 pm    Post subject: Reply with quote
There okay, I'm using spacers anyway at the moment.
thecarfixer
PostPosted: Tue Nov 14, 2017 9:28 pm    Post subject: Reply with quote
The 996 17" wheel has a 9J rear..
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue Nov 14, 2017 10:05 pm    Post subject: Reply with quote
Wheels look nice.
Don't caymans run 8 and 9?
Would probably be fine using oe width tyres. Or maybe run 17" width tyres as the rims are that width - 205 and 255 to balance the car as factory - would a 265 be too wide for the 9" rim? 205 may be too narrow for an 8.
From offsets they look like they wlll fit without spacers, although the front rim will be 15mm closer to the strut.
They look nice, like an 18" version of the 17" carrera multispoke.
What do the wheels weigh? 996 wheels are pretty light: http://www.944racing.de/wheelweights.php
coullstar
PostPosted: Tue Nov 14, 2017 10:54 pm    Post subject: Reply with quote
Yeah they are 8in and 9in. I feel the 265 on the 10in is a little stretched looking. When I had them on my Boxster I had same size tyres as I run now i.e. 225/40 front and 265/35 rear so straight swap.
Weight wise there pretty light, lighter than the Sport Designs for sure.
 Filesize:  1.99 MB
 Viewed:  3664 Time(s)
Stoo.c
PostPosted: Wed Nov 15, 2017 10:35 am    Post subject: Reply with quote
They really suit the boxster well.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
BHZ661
PostPosted: Sat Nov 18, 2017 6:51 am    Post subject: Reply with quote
Look a very nice wheel , thumbsup
coullstar
PostPosted: Sat Dec 09, 2017 6:08 pm    Post subject: Reply with quote
Found a set locally so I'm going to give it a try.
coullstar
PostPosted: Wed Dec 13, 2017 4:27 pm    Post subject: Reply with quote
So heres a before with balloon tyres, not flattering. New tyres on tomorrow and should get them fitted over the weekend. Going with Goodyear F1 Assy3, 225 front and 265 rear as currently fitted.
Hope they look okay as the sports designs have been sold.
Certainly lighter for sure, I'll do a comparison when changing over for anyone thats interested.
 Filesize:  658.95 KB
 Viewed:  2695 Time(s)
wasz
PostPosted: Wed Dec 13, 2017 4:52 pm    Post subject: Reply with quote
Yes - would be interested to see a weight without tyre to see how they compare:
coullstar
PostPosted: Wed Dec 13, 2017 6:28 pm    Post subject: Reply with quote
Won't get a chance without tyres but I'll weight these and sport design with tyres to get a semi accurate comparison.
coullstar
PostPosted: Fri Dec 15, 2017 11:01 am    Post subject: Reply with quote
New tyres on and measured the wheels weights.
Front with 225/40/18 are 19kg. Rears with 265/35/18 are 21-22kg.
I did get one sport design rear of quickly to measure and it was 25-26kg so a good 3-4kg saving per wheel at the rear. I suspect front will be around 2kg per wheel so I would say these are on par if not slightly less than the MY00 5 spokes. Note they are also BBS manufactured as well.
Quick blurry out of focus pic of the two side by side.
Hoping to get swapped over this weekend and car out if the snow and ice go away.
 Filesize:  268.2 KB
 Viewed:  2546 Time(s)
wasz
PostPosted: Fri Dec 15, 2017 1:07 pm    Post subject: Reply with quote
1kg of the saving will be because they are an inch narrower, but otherwise looks to be a saving.
I was concerned they would be heavier but that isn't the case.
coullstar
PostPosted: Sun Dec 17, 2017 10:58 pm    Post subject: Reply with quote
Managed to quickly swap wheels over between family duties and grabbed a few quick photos.
I'm happy, I think they suit the car well. Not drive yet so no idea if they feel any different.
15mm front spacer and 9mm rear that I'm changing to 15mm as well.
 Filesize:  1.95 MB
 Viewed:  2438 Time(s)
 Filesize:  673.72 KB
wasz
PostPosted: Mon Dec 18, 2017 9:11 am    Post subject: Reply with quote
Wheels look great!
On the standard setup the 265 looks stretched over the 10in rim. On these I guess it has a more vertical sidewall.
Car looks fab too, I was looking for one in that colour when I was shopping.
coullstar
PostPosted: Mon Dec 18, 2017 9:27 am    Post subject: Reply with quote
Yes the tyre is more square.
 Filesize:  731.89 KB
 Viewed:  2390 Time(s)
BHZ661
PostPosted: Mon Dec 18, 2017 3:50 pm    Post subject: Reply with quote
They look great on the car thumbsup
