Homelink 'hack' - done!
Easto
18 Jul 2017
157
Purchased switch out of parts section and my friend did the business with the wiring.
Removed the inners of the fob and got it into the space behind the light module without undoing any screws. Easy future battery change.
Works great - very pleased for a £25 outlay and a beer to my pal ! :goodjob:
I did this mod about 5 years ago on my 4S great thing is it's a two minute job to move it to the turbo when a sold the 4S👍
Sorry, I don't understand. You've done what?
Bought a homelink button for the blanking plugs in the light cluster where the sunroof is and directly wired the garage fob onto the switch and put the circuit board (wrapped) behind the switch panel.
No more fob rattling around in the drivers pocket and a simple
Press tomopen and close the garage door.
Works like OEM for £25
It's the little things :)
Easto did you get yours to illuminate with the lights on? I never bothered.
Here's a couple of pictures for anyone thinking of this useful little mod.
No... it's not connected to the 12v of course so didn't want to drain battery so didn't even consider it.
Tbh I'm not sure if the light comes on for an instance when I press it. I haven't noticed but will check.
silvermilnec said:
Gollom122 said:
If you wired red and blue rather than red and yellow then the button would illuminate when pressed.See previous thread
http://www.911uk.com/viewtopic.php?t=86476&postdays=0&postorder=asc&highlight=homelink&start=60
Cheers for that👍 Did no one get it to light up through pin 3 connected to the lighting circuit? Not a big deal anyway!
Nope - from memory that would require a 12v feed from the headlight circuitry and a ground. You'd still need the fob battery for door operation and I think combining the two power sources could prove troublesome so did not bother trying.
thought so, it is a great little mod though! Thanks for the reply 👍
124,559
1,441,507
48,971
Bristolsparks
