997 : 2004- 68
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Early 911 : 1964-1977 2
Classic : 1950-1965 1
Boxster : 1997- 15
Cayman : 2005- 16
Cayenne : 2003- 9
912-914-924-928-944-968 4
Paint Protection & Body Wrapping
sjb993
PostPosted: Thu Sep 07, 2017 2:47 pm    Post subject: Anyone out there got Koni FSDs? Reply with quote
After about 10 years with my bone-shaking suspension setup, I have decided it's time to go for a more comfortable ride.
The car currently has Bilstein HDs, M033 springs and 18" Turbo Twist wheels. I am on the brink of pushing the button on some Koni FSDs. I intend sticking with the M033 springs, and I have a set of 17" Cup IIs that I'll put on.
I'd be very grateful if anyone who has gone from standard OEM shock absorbers to FSDs or HDs to FSDs would give their opinion of the difference in ride quality after the FSDs were fitted.
I have never tracked the car, and have no intention of doing so, so I'm not looking for the ultimate in high speed handling. I just want to be able to do some spirited country lane driving without having the fillings in my teeth shaken out when I go over a rough surface.
I'll be looking at a total cost of around £2K for the FSDs, the various other parts I need (because I'm moving from HDs not standard shocks), the fitting and the alignment.
Before I spend the money, I'd just like a little reassurance that I'll end up with a more relaxing ride.
TIA
Steve.
MattyR
PostPosted: Thu Sep 07, 2017 3:02 pm    Post subject: Reply with quote
If you do a search for Kimbo's old posts re. suspension, he literally tried it all and settled on FSDs. May be worth PMing him. I hear good things about the new classic shocks Porsche have just released. I am on Koni sports shocks which are hard. But then I also lowered to RS ride height!
1994 Aventura Grün C2 993
ragpicker
Paul Ricard
PostPosted: Thu Sep 07, 2017 3:08 pm    Post subject: Reply with quote
I've got them on my boxster. After a few weeks of driving they settle into a lovely little damper. Just like M030 for normal driving but they stiffen up really nicely when pushing on.
As a non-coilover option they are definitely work a look.
996 turbo - slightly modified....
RobIpswichUK
1994 Porsche 993 Carrera 2
PostPosted: Thu Sep 07, 2017 3:09 pm    Post subject: Reply with quote
One mans hard is anothers soft and compliant.
Personally I had FSD's and Eibach springs fitted to replace the originals and it was like night and day (so much better controlled and nicely firm without being harsh). Whether my originals were shot or not is another matter, so difficult to say.
Chris Franklin at CG rates the FSD's and that is good enough for me.
Kimbo ended up on M033 and FSD having tried just about every other option, and even he was happy in the end.
Rob
'94 C2 Iris Blue (+ White Stripes!)
Cup 2's, Big Ovals, FSD's/Eibach, OMP Strut Brace, 200 Cell Powerspeed Cats, 1.75" Hollamby Exhaust bypass, Carnewal FPB.
Mercedes SL (R230)
Mercedes E Class (W211)
TT Roadster
PostPosted: Thu Sep 07, 2017 3:18 pm    Post subject: Reply with quote
FSD get the Thumb from CoG
Me? The 13th Duke of Wybourne? Here? In a sixth form girl's dormitory? At three o'clock in the morning? With my reputation? What were they thinking of?
wozy
PostPosted: Thu Sep 07, 2017 4:50 pm    Post subject: Reply with quote
I spent months searching the net for what I hoped would be a definite answer to this.
I eventually went the FSDs M033 route. I truely believe I made the right decision. Perfect for undulating and crappy British A & B roads.
Are they a zillion miles better than the OE dampers? I'd say they are better and worth the outlay. The surprising thing to me was how much faster I was travelling without realising it after they were fitted.
Just make sure of a couple of things. 1. Its set up correctly and 2. You allow for the fact that other parts are either worn out and/or need to be replaced whilst your in there.
Lastly the suspension needs I found 2-3K miles to bed in fully.
Fill your boots....... and be warned and prepared for possible OCD expense. Smile
https://www.pistonheads.com/gassing/topic.asp?h=0&t=1537100&mid=194694
Porsche Cars of Great Britain launched the 993 in the UK in early December 1993 registering 12 x UK cars on the 6th & 7th of that month; mine is one of them.
993 C2. MBM. C4 mounts, RSRs, RS Short shifter. RS steering wheel. FSDs & M033s
Previous 2.7S, 3.2, 964 and 968CS
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Thu Sep 07, 2017 7:42 pm    Post subject: Reply with quote
Last year I changed from standard shocks and springs to FSD's with M033's.
I don't know how worn my shocks were , the mileage was sub 70k at the time. I won't say there was a night and day difference but then my original setup was quite compliant anyway.
The new set up is somehow even softer on the dentures yet more surefooted. I'd definitely recommend if you've currently got a harsher ride , want more compliant but don't want an out and out track day set up.
As an aside, even my wife noticed the difference .. most surprising.
Let us know how you get on!
'83 W460 LWB G Wagen updated with OM602 engine and 6 speed 'box ...My daily driver
Ex. '99 996 C2 manual coupe.
9xxnick
PostPosted: Fri Sep 08, 2017 7:57 am    Post subject: Reply with quote
I've had FSDs fitted for about seven years and 38,000 miles, and I think they're a very good choice for road use. I believe I was the first customer Center Gravity had worked with on FSDs and recall how impressed Chris was with them on the test drives following the alignment. They were night and day compared to the 68K mile original Monroe units previously fitted.
Nearly 40K miles later the fronts are showing a little wear on CG's damper test rig but the car still drives very well indeed on them.
So FSDs + thorough check and replacement of worn suspension components + proper alignment = great choice, in my experience at least.
ChrisT70
PostPosted: Fri Sep 08, 2017 9:08 am    Post subject: Reply with quote
same here, car drove superbly on their FSD set up
Afraid of dipping a toe- beware Sharks
Ex 993S now sold
ColinC
PostPosted: Fri Sep 08, 2017 9:15 am    Post subject: Reply with quote
Another FSD recommendation thumbsup
The change on my car was noticeable however I did change several components including engine and gearbox mounts at the same time......
94 993 C2 - Black with Marble Grey Leather
Cameltoe & Heel
PostPosted: Fri Sep 08, 2017 10:01 am    Post subject: Reply with quote
I have them in a box ready to fit with new M033 springs and top mounts.
Great to hear all the positive comments above, think they should work perfect for a glass top.
Go for it I say Smile, this many people can't be wrong.
Trev
RobIpswichUK
PostPosted: Fri Sep 08, 2017 11:25 am    Post subject: Re: Anyone out there got Koni FSDs? Reply with quote
TIA
Sundeep's got a set of unused FSD's for sale on another thread
http://911uk.com/viewtopic.php?t=122967
Rob
Mercedes SL (R230)
TT Roadster
madge
PostPosted: Fri Sep 08, 2017 11:50 am    Post subject: Reply with quote
I believe that this was on the car that I'm currently looking after.
They seem pretty good to me. Comfortable without being too soft or wallowy.
I've gone from 17" cup wheels to 18" hollow spokes and I don't find the larger wheel to be uncomfortable with this set-up. I didn't notice much difference at all when I switched.
OP, I'm not far from Reading if you want to see what they are like first-hand, although it doesn't go out in the rain which could be something of a hindrance to a run out at the present time!
Lightening Lightening
Current: 993 Carrera Coupé, Manual, Varioram
Previous: 987 Cayman S
Kimbo
Paul Ricard
PostPosted: Fri Sep 08, 2017 12:46 pm    Post subject: Reply with quote
Great car - hope you're enjoying it Thumb
FSD's all the way but next time I'd couple them with Eibach Sport Springs rather than M033. A bit lower but just as comfy.
Cayman Gen 1 Manual 2.7
sjb993
PostPosted: Fri Sep 08, 2017 7:35 pm    Post subject: Reply with quote
Thanks for all the comments.
Steve.
madge
PostPosted: Sat Sep 09, 2017 7:37 am    Post subject: Reply with quote
Yes, thank you Kimbo. It still makes a great sound - you did a good job there too. Thumb
Kimbo
Paul Ricard
PostPosted: Tue Sep 12, 2017 5:59 pm    Post subject: Reply with quote
That took a year of my life, too.
sjb993
PostPosted: Tue Oct 10, 2017 5:07 pm    Post subject: Reply with quote
Quick update.
FSDs supplied and fitted by Center Gravity, along with alignment set-up. Cup IIs fitted instead of the Turbo Twists.
Absolutely delighted with the improvement in ride quality.
As Wozy said above, it's surprising how much faster I now feel comfortable driving the car around the country lanes.
I must stick the 18s back on some time to see what they're like with the FSDs.
Thanks again for all the responses.
Steve.
